Governor-carb question on 2n
   / Governor-carb question on 2n #1
SteveM
Upstate NY
Kubota B7100DT
Thanks for all your help so far with my 'new' 2n. I am closing in on the carb-gov. problem - so close I can taste it. Here's my question:
I took the gov apart again and removed all washers above the thruster. bingo, I now have all the power in the world! BUT, when I throttle down - it abruptly falls off RPMs and begins surging. When it is surging, the governor is moving back and forth a half inch or so, causing the surging....
1) Should I put one thin washer back in?
2) Is there not enough tension on the spring?
For background info, the carb and all ignition is new, and I recently had the carb jets checked by a trusted mechanic. The problem is in the gov. setup; at higher throttle settings it runs fine....thanks for your help! /forums/images/graemlins/wink.gif
   / Governor-carb question on 2n #2
I havn't actually worked on a gov. for a 9n/2n.. and they are a bit different than the 8n.. but lets see what we can get going anyway.
These N engines like to idle at a minimum of 400 rpm.. and that is on a rebuild.. probably closer to 500.. even 600 on a tired engine. ( Might get as low as 350 with an electronic ignition... some guys on the ytmag N forum have reported that ).
My guess is that the idle is too low.. machine 'thinks it is dieing.. and the gov throttles it back up... too much.. dies off again.. etc. I.e. surging. Could try upping the idle adjustment for more rpm a little.
If you think it is alread idleing at the correct rpm, when you took the gov apart, did the flyballs look ok? As for the spring, there should be no tension, and also no slack.. pretty much adjusted neutral.
If none of that helps, go ahead and try the washer.. can't possible hurt..as they were int here before.. and you can always pull em' back out.
good luck.
Soundguy
PALLET OF(3) CABINETS & (5)BOXES OF CARPET SQUARES (A60432)
PALLET OF(3)...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
KUBOTA SVL75-3 SKID STEER (A60429)
KUBOTA SVL75-3...
2014 BMW 5 SERIES SEDAN (A59905)
2014 BMW 5 SERIES...
2011 MULTIQUIP LIGHT PLANT/ FUEL TANK TRAILER (A58216)
2011 MULTIQUIP...
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
