got tongue weight?
/ got tongue weight? #11
personally I use a Sherline Trailer Tongue Weight Scale - Sherline Products don't remember, but I think I have the 5,000lbs one. Easy enough to change... 1 square inch piston just means putting in a different size pressure gauge & pressure = weight 1 to 1. Probably more effort to use, but much more portable & adaptable to other junk.
I use the Sherline also, along with Weigh-Safe Trailer Hitches - Towing Peace of Mind in the 2.5" shank model when setting up a new trailer. Both models approximately agree with each other on the tested tongue weights.
/ got tongue weight? #13
I was scrolling down the thread and was going to ask how would you go about measuring exactly what the tongue weight was, then saw this.
I have a 10k trailer with a 7k jack. Loaded with a tractor that weighs 5,700 lbs I would still be able to jack it up safely correct?
/ got tongue weight? #14
I assume you mean with the tongue jack. Should not be a problem as the weight is distributed on the jack and trailer/axles. Your trailer is probably 2800# - 3200# empty, depending upon any mounted boxes with stored items. Tongue weight loaded is probably ~ 900# - 1400 # (10% - 15% of towed weight) if loaded correctly. Mine is similar but a bit heavier and have no issues.
/ got tongue weight? #15
Yes, with the tongue jack. Trailer is 2,650 lbs empty.
2017 Bobcat E55 (A60462)
2017 Bobcat E55...
2015 JOHN DEERE 35G EXCAVATOR (A52707)
2015 JOHN DEERE...
12' Truck Box (A60352)
2015 Kubota L4701 (A60462)
2015 Kubota L4701...
2011 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A60736)
2011 DRAGON 150...
JOHN DEERE 772GP MOTOR GRADER (A58214)
JOHN DEERE 772GP...
