Loader got the loader, now need the hydraulic connections for a L3600
   / got the loader, now need the hydraulic connections for a L3600 #1
SailormanEd
Raleigh, NC
Kubota L3600DT, Kubota L2850DT
I just acquired a used FEL but the hydraulic stop at the quick disconnects ( the tractor ends stayed with the PO). So I need to order 3 hoses with disconnects. What thread to I need to connect to the Kubota? (under the right side operator platform). I also want to add 2 hyd circuits to the rear at the same time (tilt and one to operate on an implement) I really do not quite understand "power beyond". How do I plumb all this together?
thanks in advance. Ed
   / got the loader, now need the hydraulic connections for a L3600 #2
Can you post pictures? That will help.
   / got the loader, now need the hydraulic connections for a L3600 #3
If you dont get replies, try posting in hydraulics section. Wish I could help.
Here is a view of the hydraulic ports and the ends of the hoses from the loader joystick: P1110237.JPGP1110238.JPG
set of 4 tractor trailer tires Roadforce (A56435)
set of 4 tractor...
2013 Ford F-750 Pak-Mor 16 Yard Rear Loader Garbage Truck (A56858)
2013 Ford F-750...
25 DUAL AXLE GOOSENECK TRAILER (A58214)
25 DUAL AXLE...
CASE IH MX220 MAGNUM TRACTOR (A58375)
CASE IH MX220...
2005 Freightliner M2 106 Ambulance (A56858)
2005 Freightliner...
Bucket (A55973)
Bucket (A55973)
