Loader got the loader, now need the hydraulic connections for a L3600
   / got the loader, now need the hydraulic connections for a L3600 #1
SailormanEd
Raleigh, NC
Kubota L3600DT, Kubota L2850DT
I just acquired a used FEL but the hydraulic stop at the quick disconnects ( the tractor ends stayed with the PO). So I need to order 3 hoses with disconnects. What thread to I need to connect to the Kubota? (under the right side operator platform). I also want to add 2 hyd circuits to the rear at the same time (tilt and one to operate on an implement) I really do not quite understand "power beyond". How do I plumb all this together?
thanks in advance. Ed
   / got the loader, now need the hydraulic connections for a L3600 #2
Can you post pictures? That will help.
   / got the loader, now need the hydraulic connections for a L3600 #3
If you dont get replies, try posting in hydraulics section. Wish I could help.
Here is a view of the hydraulic ports and the ends of the hoses from the loader joystick: P1110237.JPGP1110238.JPG
2015 Ford F-350 Cab and Chassis Truck (A56858)
2015 Ford F-350...
1992 DFI PULL SPREADER (A57192)
1992 DFI PULL...
2011 JACK COUNTY 130BBL VAC TRAILER (A55745)
2011 JACK COUNTY...
1604 (A57192)
1604 (A57192)
M998 (A55852)
M998 (A55852)
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A55302)
2000 Kenworth W900...
