Got the B2620 yesterday
   / Got the B2620 yesterday #1
kakabeka
kakabeka falls, ON
2010 Kubota B2620
The new B2620 was delivered yesterday, FEL, MMM and box scraper. Mowing the lawn took less than 3 hours compared to 7 on the JD L120. Did the initial revamping of the 900ft driveway and moved a pile of soil already. At this rate I'll be scratching off most of the Honey Do List by the end of the weekend, and then it'll be play time.
kakabeka
   / Got the B2620 yesterday #3
Pics or it didn't happen!
Rules are rules.
   / Got the B2620 yesterday #4
Congratulations on your new tractor and equipment. You will never run out of things to do with it.
Ok I know, no pics it didn't happen
Kakabeka
   / Got the B2620 yesterday #6
heh heh, awesome. Congratulations :thumbsup:
Hope you took lots & lots of pics, because it will never be that pretty & clean or have that much paint ever again.
P.S. if your FEL hoses are close to dragging the ground you might want to sling them up over the loader arm.
   / Got the B2620 yesterday #7
Nice looking machine. I saw in your pics that your mower deck looks different than mine. It doesn't have the height adjustable anti scalp wheels, which can be turned sideways to roll the deck out from under the tractor. Do you know what deck is on your tractor?
The MMM is a RCK54-29B. it's a roll over installation, it's 300 lbs too heavy for me. Tried it a couple of times as well as removing and installing the FEL and box scraper. I have the most problem with the scraper. It's just practice i guess.
Antiscalp wheels are only adjustable up and down. Suspended deck works with the 3pt hitch, so no box scraper when mowing.
I moved the hoses after my wife mentioned it.
Kakabeka
   / Got the B2620 yesterday #9
Kakabeka
Can't you lock your deck in the up position so you can use your 3-point?
The height knob for the deck has a TOP position that locks it up.
kakabeka
   / Got the B2620 yesterday #11
kakabeka
That is what I do when I want to use a box blade or something else on the 3-point; I rarely bother to remove the MMM on my BX and the clearance is a lot less than on a B.
   / Got the B2620 yesterday #12
Yeah, short wheelbase is pretty forgiving of low ground clearance. I leave mine on as well.
larry
John Deere 4510 (A53317)
John Deere 4510...
2011 FORD F-550 (INOPERABLE) (A55745)
2011 FORD F-550...
2013 Chevrolet Silverado 1500 Pickup Truck (A59230)
2013 Chevrolet...
Bobcat E42 (A60462)
Bobcat E42 (A60462)
2004 Ford F-450 4x4 Venturo ET18KX 2 Ton Crane Service Truck (A59230)
2004 Ford F-450...
2019 JCB 457 (A60462)
