Got stuck in the mud?
/ Got stuck in the mud? #1
yooper jim
U P of Michigan
BX2660
Just thought you might enjoy this video. I don't think I'll be trying this soon! Enjoy spring. Even though it is snowing as I write this. :D
/ Got stuck in the mud? #2
Yeah...about the 5th time this video hs been posted in the last 2 months or so...
/ Got stuck in the mud? #3
Very informative and entertaining video. I would have never thought of this solution for this problem, never, never. I don't think.:) Glad I have 4wd.
/ Got stuck in the mud? #4
I've never seen it before Roy. How did I miss it on the Kubota forum. Roy, was it on this forum?
Glad he posted it again so I could see it for the first time. Guess it can be good to keep posting the same things over for those of us that miss them the first couple of hundred times. I vote for reposts.:)
I vote yeah to yooper jim's input/contribution to the forum:thumbsup: and nah to Roy's positive and up lifting contribution/input.:thumbdown:
/ Got stuck in the mud? #5
Roy: What about this one? How many times have you seen it? You being a JD man, is this your tractor?
Will you admit it if it is?
Actual it is the third time. Sorry if I wasted your time Roy. I should have done a better search, so as not to waste your time. ;)
/ Got stuck in the mud? #7
Roy is a JD man anyway so he's just a snooping:) guest over here in the Kubota forum. Guests should act better. I'm glad you posted it and ------Roy.:laughing:
/ Got stuck in the mud? #9
I don't speak the language very well but I think he said. "That's gonna cost you 2 goats and a sheep but you can keep the log"
/ Got stuck in the mud? #10
/ Got stuck in the mud? #12
He might have been better served by putting some logs crossways underneath the tractor to make a corduroy road. Then he could have gotten back on top of the "crust" and not had to use the chain for as long.
Aaron Z
That would be an idea. But. How would you get the driven wheels on top of the logs in the first place?
/ Got stuck in the mud? #13
He might have been better served by putting some logs crossways underneath the tractor to make a corduroy road. Then he could have gotten back on top of the "crust" and not had to use the chain for as long. Aaron Z
That methodology is sound. They used too thin a log & chains too near the center of the wheel. 7" green oak & chains around the tire -he'd have driven out in a real low gear. MikeD74t
/ Got stuck in the mud? #14
With the chain like he used. The problem with his method is that his diff lock was broken and he kept chewing up the crust.
If he had used the chain to pull the tractor onto the logs that would have let him get the whole tractor on the crust and back out from there.
Aaron Z
/ Got stuck in the mud? #15
It was posted in the owning/operating and rural forums, IIRC. It's a pretty old video. Not the first one I've seen using a length of wood to get a tractor moving.
Apparently not a new trick at all...but with cams and vids (and the internet), one sees a lot of things like this.
I like tractor snow plowing and snow blowing videos (keeps me occupied when the weather is bad). There are hundreds, if not thousands, of tractor related videos on YouTube.
/ Got stuck in the mud? #16
I like it. I would never have thought of doing that. I'll file that in the archives. Even 4X4's get stuck sometimes! ;)
2014 WESTERNSTAR 4900 (INOPERABLE) (A65643)
2014 WESTERNSTAR...
2018 RAM 2500 (A65643)
1999 International 5000 SFA Day Cab Truck, VIN # 1HTTWADR6XJ004085 (A65563)
1999 International...
2007 Peterbilt 378 (A62679)
2007 Peterbilt 378...
FIFTH WHEEL ATTACHMENT PLATE (A65643)
FIFTH WHEEL...
YALE FORKLIFT (A63291)
