Got rocks?
/ Got rocks? #1
GregbkH
Wisconsin
2010 New Holland 3045
When tilling one of my food plots a couple months ago I ran into some rocks that were rather bothersome. So today I decided to go up there and try to remove them. "Up there", meaning on the top of my hill. Some of the locals that have seen my place think that I'm nuts for climbing that hill with a 4-wheeler much less a tractor. But I have some pretty big stones and I needed to get those rocks out of there!! :)
Going up.
Coming down
The rocks. For comparison, my grapple is 48" wide.
/ Got rocks? #3
Those rocks would make a beautiful wall. All I've got is big round ones with few flat spots..
Great pics, BTW!
/ Got rocks? #4
Got rocks? We grow them here. :laughing:
Doesn't seem to matter how many I pry from the ground, there are always more that pop up shortly after I pass by. This is why I cannot keep a decent set of blades on my mower.
/ Got rocks?
You see rocks; I see building material for a wall, fire ring, etc.
You're right, those rocks are piled up there for a reason. My boss already has plans for them. Here is some of her work. Thanks for the comments.
/ Got rocks? #7
When you are blessed (?) with as many as I have, I see them as gulley fillers.
/ Got rocks? #9
Getting the tractor UP the hill is one thing....How did you carry those nice stones DOWN the hill? (not in the grapple I assume?)
/ Got rocks? #10
How else would he get them down?
I suspect the trail isn't as nasty as it appears though I'd be seriously considering using the hoe to widen it. It never ceases to amaze me what my little machine will climb over and through with a load on. But when I go climbing, I am crawling at snail speeds with almost no momentum. Works exceptionally well.
That trail looks like an old logging trail you might have seen a mule pulling a log or two down.
/ Got rocks?
Yes, I carried the rocks down with the grapple.
The trail is actually a bit worse in person that what the pictures show. It's not for the faint hearted. My tractor is a hydro and I go up and down in the lowest range. Going up, PTO speed (2500 rpms), 4wd with diff lock engaged. Right near the top it gets a little sandy and without diff lock the one tire wants to spin and tear up the trail.
/ Got rocks? #14
Man, that is just awesome.
Wish I had hills and rocks like that on my property.... and a bad *** TLB setup with a grapple.
Thanks for sharing the photos, very cool.
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
2020 KUBOTA KX080-4 EXCAVATOR (A65053)
2020 KUBOTA...
PJ Trailers 84"x15' Roll Off Dumpster (A60462)
PJ Trailers...
(2) BUCKETS OF ASSORTED ROOFING NAILS (A64281)
(2) BUCKETS OF...
2019 CAT 305E2 CR Mini Excavator (A62613)
2019 CAT 305E2 CR...
(3) 6"X34'-1/4" THICK STEEL TUBING (A64280)
(3) 6"X34'-1/4"...
