Got my new Markham Tooth Bar mounted
   / Got my new Markham Tooth Bar mounted #1
Chris2520
Platinum Member
Marietta GA.
Finally got time to mount the new Markham tooth bar. had them make it a little narrower than normal. i wanted to weld the gusset plates to the inside. 1/4 inch plates worked perfect. :) I thought the 1/2 inch plates thay sent was a little over kill. i wanted a clean look on the outside of the bucket. I did not use the bolts that came with it. i used the large grade 8 bolts from the big JD tooth bar. i have not even put it in the dirt yet. and i know i am going to like it much better. i got where it just slips off with ease. i had to pry the JD bar off and beat it on with a hammer. and it weighed a ton. way over kill. this one is heavy. but not to heavy to carry around. it looks well made. The JD bar only had 6 teeth. this one has 7 teeth. thay are a plesure to work with.
I think i am going to like it. here is a few pics.....;)
Chris....:)
   / Got my new Markham Tooth Bar mounted #2
did you jus get this one because i remember in the pics you sent me you had one in there how did you like the other one and this one
Yes i just got it..:) and yes i got another one made by JD it is to heavy. its to heavy for a 3000 seris. and it has 6 teeth. this one i have now has 7 and is easier to work with. i think i will like it better. the JD bar has teeth the size of a 963 Cat. way over built for compact tractors of any size...;)
Chris....:)
   / Got my new Markham Tooth Bar mounted #4
Chris, that new toothbar really looks good on there, and you did a great job with the install as usual. It looks much better matched to the loader than the JD one did.
Thanks Chuck...:)
I agree , its a much better fit than the JD bar was. it looks like it should be on a compact tractor , and not a bulldozer...;)
Chris....:)
   / Got my new Markham Tooth Bar mounted #6
Was that original a standard toothbar that JD makes specifically for your bucket... or just one the JD dealer came up with that happened to fit? :confused: Maybe a JD skidsteer toothbar???
I agree. Excellent installation job. Did you pay extra for an additional tooth? Or are 7 teeth standard in your size? :cool:
Dougster
   / Got my new Markham Tooth Bar mounted #7
Chris,
This is the last pic we expect to see showroom shiny! Now go and get that toothbar dirty! :)
Dougster
Dougster , it is a JD toothbar for a 61 inch bucket. thay also make a 73. I do feel there for a skid steer. the bar is way over built. its more than you need on a 4000 seris compact tractor.
as for the markham. yes i paid 26$ more for the extra tooth. it puts the teeth closer together. i think it will help digging in hard ground. also the teeth are alot sharper. the JD teeth are very blunt. i feel it was made for something with alot more power than even a 40 Hp tractor...;)
Chris....:)
JDFANATIC said:
Chris,
JDF , this is why i took the picture today.
I know its never going to look that way again.....;)
Chris...:)
   / Got my new Markham Tooth Bar mounted #10
Chris, I know you posted this before, where did you get your bucket hooks. JC
RoGator RG1100C (A55302)
RoGator RG1100C...
Giyi Telescopic Boom (A53316)
Giyi Telescopic...
20 ft. Shipping Container (A53117)
20 ft. Shipping...
2021 Kubota SSV75 (A53314)
2021 Kubota SSV75...
2-Stertil Koni lifts (A50775)
2-Stertil Koni...
