Got a clunker?
Status
Not open for further replies.
/ Got a clunker? #121
In response to Westcliffe
After taking a class on ICF construction (insulated concrete forms) I no longer can conclude that R value has much meaning. Air moves through open cell insulation freely, heated air rises, fiberglass is really a mediocre medium at best to insulate in todays world.
Somewhere I saw you mention what you pay to cool your home as well as the other needs throughout the summer months. The rude awakening will hit when/if your coal fired electrical plants are eliminated. Expect your electricity to exceed 30 cents a KW. Ask me how I know this, mine is about 32 cents a KW after transmission and distribution are factored in. You will discard your electric water heater. You will not heat with a heat pump, you might convert to a gas dryer, you will cool your home only to 80 plus degrees, you will consider solar but realize it is not cost effective, You will come to the conclusion that both wind and solar only work when the winds blowing and the sun is shinning, when it is not, you will need 100% backup which means a natural gas fired, a co generation or similar electrical generator, hydro or nuclear will need to be built to provide that 100% backup when alternative measures fail to produce. It gets complicated fast. Do expect to see much, much higher electrical rates. This will apply even if the US invades Canada and takes all their oil, invades Venezuela takes all of their oil and drills off the California coast. :)
In other words, GO NUCLEAR BABY!!!
/ Got a clunker? #122
Way too many political posts by people who think the TOS don't apply to them, i.e., A Thread Filled With Clunkers.
Thread closed.
Status
2000 Yale GLC030A 2,500lb Propane Foklift (A61572)
2000 Yale GLC030A...
FUEL TANK (A68842)
FUEL TANK (A68842)
PAIR OF TRACTOR TIRES AND RIMS (A67714)
PAIR OF TRACTOR...
2018 PETERBILT 567 FLATTOP SLEEPER TRK (A67714)
2018 PETERBILT 567...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A65056)
KNOW BEFORE YOU...
2014 RETESA 210BBL CRUDE TRAILER W/ PUMP (A67714)
2014 RETESA 210BBL...
