Gooseneck dump suspension mod
   / Gooseneck dump suspension mod #1
nisaacs
Platinum Member
Snowflake, Arizona
970 John Deere 4x2, 970 John Deere 4x4, 4320 John Deere, 995 Case/IH
Dinged my tailgate with my gooseneck dump, twice....grrr... I think I have fixed the clearance issue. Drilled my hitch at 1-3/8" between the existing adjustments. I didn't want to move it 2.750" the oem holes in the hitch"
So, after this adjustment my trailer is high in the front, hate that.
To help level it out I modified my equalizer by flipping it end to end and mounting my springs in a different location. With a 2" rise on one end of each spring, I should net about a 1" lift on the trailer.
I do need to get new equalizers and center pin. The nylon bushing and pin is badly worn. This will work fine, until I get some parts and I can monitor the mod to see if all is well. I did turn the bushing and pin 180 degrees to get away from the worn spots. My rear spring slippers are getting thin, I will need to do something about that next.
First picture is oem, second one is the mod. Instead of the top of the equalizer as the front slipper, I have (3) 3/4" nuts and a washer on each side of them, clamped/supported by the bolt. That is my new slipper. The shinny bolt, I drilled and added, to insure the spring can't jump out of the equalizer.
Give me torsion axles.
So, I tackled my slippers on my dump, like I said, they are getting thin. Not a fan of this old school system at all. You would think they could upgrade to something better. For a home owner, they work fine, but for commercial duty, not so good.
So, I made some home grown bushings to take the place of the slipper. I just used some simple pipe nipples and pvc pipe to make a trial set, some R&D work:D
:D
If it works good and I think it will, I will order some heavy wall tubing and some standard trailer bushings and build a heavy duty set, but the design will stay the same. I will go with 3/4" ID x 1.5" OD, 3/8" wall. The oem bushings (9/16" IDx3/4" OD) and spring bolt (9/16") will work. Unlike the friction slipper, this bushing will roll with the spring movement. Repair will take about 10 minutes for the future.
I did have a struggle cutting the slipper out. I had to use my reciprocating saw because my grinder wouldn't fit inside the hanger. I takes two blades and a lot of time to cut that weld out. I did move up some on the hanger to move away from the hard welded location. It drilled pretty good. The actual spring mount location is the same as before.
I have all my parts to make permanent, my hoke slipper spring conversion, to roller. Smooth bore, heavy tubing (no welded seam) for the rollers, standard 9/16's spring eye bolts and 9/16's x 3/4" trailer suspension bushings. They are only 1.750 long and I need 2" so I had to cut some, to make them long enough, two piece. 2" is not available in the size I chose, that would fit the tubing size available. I did have to buy a new tubing cutter for the bushings, for some reason my old one (1970 model) cut too much well pipe and was dull:D
   / Gooseneck dump suspension mod #4
Looks good and well thought out.
Parts are installed on the trailer. Should be an easy repair in the future. Parts are easy to come by and very reasonable.
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A58216)
2013 ORTEQ ENERGY...
2024 JCB 35Z (A60462)
1996 FORD F-SERIES FLATBED TRUCK (A52706)
1996 FORD F-SERIES...
Landoll Lowboy Trailer (A56438)
Landoll Lowboy...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
Gravely ZT XL-52 52in Zero Turn Commercial Mower (A59228)
Gravely ZT XL-52...
