Good time to by WWF for loading tires
   / Good time to by WWF for loading tires #11
LBrown59 said:
I tried the orange stuff once / never again.
It left a white milky film on the windshield and the glare from on coming head lights was so bad that i had pull over off the road as i couldn't see a thing through the glaring film .
//www.hubcapcafe.com/i/2001/storycty/chev6001a.JPG rear view
MY TRACTOR http://www.jenningsequipment.com/storepics/ksBX22.jpg BX23
evaporation.
SPYDERLK said:
Im not sure how that works out. Seems like it would be more.
You are correct. 0.69 x 120= 82 bucks. Still less than the $320 retail price for 120 gallons.
I may have confused myself as at one point I was going to buy less of the -30 stuff and dilute it to -15 or -20 which is all I really need. In the end it was so cheap I just bought more.
   / Good time to by WWF for loading tires #14
IslandTractor said:
I bought all 60 gallons of the orange stuff (I have a Kioti and it had to match:D ) QUOTE]
Are you sure its not Kubota orange:D
I am glad you got the Kioti orange and not the New Holland blue or the John Deere green stuff:D :D :D
Sorry had to say it. I am looking for something to load my tire with. I have been looking at the rim guard also but still looking at the WWF due to the less expense.
   / Good time to by WWF for loading tires #15
Larry, don't tell anyone but these guys are putting this stuff in their tires. shhhh
   / Good time to by WWF for loading tires #16
Astonishing as it may sound some people are actually putting it in their windshield washers.
I tried it once.
Worked too except for the bad filming of the window.
OUR FIRST CAR http://www.hubcapcafe.com/i/2001/storycty/chev6001.JPG Convertible front http://www.hubcapcafe.com/i/2001/storycty/chev6001a.JPG rear view MY TRACTOR http://www.jenningsequipment.com/storepics/ksBX22.jpg
   / Good time to by WWF for loading tires #18
I bought 24 gals of WWF today at Advance Auto to load my new turfs. The response from the guy working there, "You want how much?!?!?!?"
I'm going to try what a co-worker did to load the rears of his JD X595. He let the air out, broke the bead on one side, and just poured it in. Then the old ratchet-strap deal to re-seal the bead. Or maybe I'll try the starter fluid :rolleyes: (to reseal, not to load).
   / Good time to by WWF for loading tires #19
I just ordered new tires for our 8N & pulled off the wheels this morning, which to my surprise were partly loaded. The dealer here still uses calcium chloride which I don't really want to use, & is how I ended up on this thread.
The wiper fluid seems like a good idea. See if I can find some off-season stuff.
Also, they go through alot of RV anti-freeze around here winterizing summer camps & I think it is around the same price per gallon as some of the prices quoted earlier in the thread for the WWF. I think it is a -50F product so it could be slightly diluted. Has anyone tried/heard of using that?
Also how full do you try to get them?
Totally full for the weight or half-full for the lower center-of-gravity?
Antifreeze in the form of propylene glycol or ethylene glycol should work fine as tractor tire ballast. It typically is a bit more expensive than methanol based freeze resistant fluids but if you can get it cheaply there is no reason not to use it.
Regarding how much to put in a tire: never fill it completely. 75% is max fill for weight. 50% would be right to maximize stability.
KENWORTH T/A DAY CAB ROAD TRACTOR (A57192)
KENWORTH T/A DAY...
2011 Toyota Camry Sedan (A56859)
2011 Toyota Camry...
2013 Ford C-Max Energi Hybrid PHEV Hatchback (A59231)
2013 Ford C-Max...
2020 DRAGON ESP...
2021 JOHN DEERE 6145R TRACTOR (A59823)
2021 JOHN DEERE...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
