Good tie-down locations in a new ck35
/ Good tie-down locations in a new ck35 #1
TN8Man
Tennessee
TYM T494C, EA Root Grapple. JD445
Where are good front and back tie-down locations for a new ck35? I need to trailer my ck35 over I40 for about 100 miles.
Thanks
/ Good tie-down locations in a new ck35 #2
This is how mine was delivered the back ones may have been over the axle.
A strap should be over the loader as well.
Thanks for the feedback!
/ Good tie-down locations in a new ck35 #4
Hi guys this Kenny living in Pa. I know you have moved your tractor by now. Here's some interesting input.
As of Jan 1 2016. and according to my state rep this came from the federal level.
You can not pull a trailer that has a gross wt larger than you pickup gross GVW. So if you have a 7000 GVW trailer then you can't pull it with a truck like my Nissan which has a GVW of 5815. Now I can pull a 5000 GVW trailer as long as I don't get over 5815 on the truck and 5000 on the trailer. Now that weighing the rig now they can get you on the axle weights. If the axle is allowed 2250 then you need to watch tongue weights as you could over load the rear axle.
Now as for chains and binder equipment must be chained with chains capable of holding the load and must be series 7 stamped on the chain.
You must have 4 chains and binders on the tractor hooked to a anchor point. Hitch, tow hook on front. Now as for the bucket it also must be anchored down with 2 chain and 2 binders. Years ago I used 1 chain across the hook in the rear and one across the front and that was good enough. I always figured the loader can't go any where since its hooked to the tractor. But explain that to a D.O.T. cop.
A year ago I purchased a new 7000 trailer to haul my CK25 with cab 5200 LBs and got DOTd and had to get rid of that one and get a 5000 trailer. Now I can only haul the CK2510. and That 3000 with the mower. trailer is 1800 and I am towing with a Nissan Frontier. So I load center over the axle.
My friend/neighbor got hammered he had a track hoe boomed down with the chains on the track pads, and that was not considered a anchor point so his fine was close to 3000.00 with all the add ons.
Around here there making a killing on this towing stuff, they check the break-a-way switch, they look under the truck to make sure the hitch is rated for the capacity of the trailer, they make sure the ball is rated for the weight of the trailer. They check the coupler for its rating, So I no longer make hitches for trucks. If they can prove you make money with the implement then they want a DOT number on the door. I mow for our tractor club for nothing and I had to get a statement stating that all I get is the fuel. And by the way they are allowed to look on the door sticker to check for your axle weights. I think it should be illegal.
/ Good tie-down locations in a new ck35 #5
Interesting government overzealous? trailering information. Wow. Who owns a chain stamped with a "7"?
Those black soft straps shown above in the pic wouldn't qualify as a load tested chain.
I'm about to buy another tractor and having towed lots of wrecked vehicles home, I "thought" I knew what floats...
I was thinking my challenge on the newer, shinier tractor I'll bring home was to keep it on there w/o damaging the orange paint. It will not be coming from PA, BTW.
/ Good tie-down locations in a new ck35 #6
There is a difference in the laws in PA for hauling commercially, which includes your own business, or private/personal. In PA, you need four separate chains for the tractor, each capable and rated for at least half of the tractor weight, and each connected to the tractor frame/axle separately with separate trailer connection points. Billrog's picture above shows two straps connected to another just going around the brush guard. If one strap breaks, you lose all the front tie down. Therefore the reason for each to be separate. Kind of dumb but the fel bucket is to be chained down and if you have a bh, the bucket has to be chained down. The laws may have gotten crazy but maybe if followed, I wouldn't have had a bulldozer laying on it's side in my front yard. If you have any hauling questions, just call the state police in your area. Around here, they're always willing to answer a question or advise you how to stay legal.
/ Good tie-down locations in a new ck35 #7
Federal rules are that if the tractor weight is over 10000 lbs you must have four chains attaching it to the trailer. Under 10,000 pounds 2 chains is fine. Either way the bucket, backhoe boom, a bush hog or other impliment on the back all need to be chained down separately from the tractor no matter the weight, but one chain is fine if its rated for enough weight.
Can you point me to the part of the law that talks about that?
Some states say that you cannot tow a trailer that has a weight rating higher than your tow vehicle is rated to tow and I would guess that the law says something like that.
If it was as you say, you could not pull gooseneck trailer with a pickup truck because a loaded 30,000# gooseneck trailer will weigh more than a 9000# pickup truck.
Aaron Z
/ Good tie-down locations in a new ck35 #8
Yes I think you would need a combo license, my friend has to have one. My argument is the trailer has brakes designed for the GVW of the trailer and the truck should not be actually stopping the trailer. If I am pulling to heavy and ruin my truck that my baby not the states. There are federal rules and there are states rules and it depends which one they wish to enforce. When I was working 18,000 you needed a CDL for federal but for the state it is 26000 so the were getting the university for garbage hauler they bought trucks under 26000 and they all had to get CDL I had a 14000 GVW ford and sold it cause I needed a physical card for driving it and needed combo tags for hauling a trailer. They say its all for safety i think the right spelling is MONEY. The federal thing was supposed to equalize the states but they do what they want. kenny
/ Good tie-down locations in a new ck35 #9
Given the experience showing in this thread:
I need to move a tractor from out of state and when I called my buddy who always kept a trailer I could use- he had sold it.
I live in a very rural area and will make some calls to nearest towns on Tuesday but for now I'm wondering if a U-haul car hauler might do this haul?
The tractor is a Kioti DK35SE which is 3,915#'s plus FEL which I'm guessing (google fails me on FEL gross weight for a KL351 w/66" bucket) to be ~ 1,000#'s for total of ~5,000 #'s. U-haul site says they'll haul 79.25" wide max, 133" wheelbase (I think they are 19' total length?). The owner says he's toted it on an 18' & a 20' that he owned.
might have to "fudge" the rental specs. when U-haul punches it into their system?
Distance is cost prohibitive to hire a hauler. I did see a 26' stakebed truck from Enterprise which will be pricey me thinks. I'll be calling several trailer dealers to see if they have rentals.
What say you on ideas beyond my local rental search?
/ Good tie-down locations in a new ck35 #10
The questions would be how wide are the back tires, will they be too wide for the tire channels on the trailer? And what is the inside to inside width on the front tires? If those measurements are good you can probably back it on and be good.
Aaron Z
/ Good tie-down locations in a new ck35 #11
Tractor data on web says 61" wide.
/ Good tie-down locations in a new ck35 #12
The bigger issue is usually the front tires being too narrow for the wheel channels.
Aaron Z
/ Good tie-down locations in a new ck35 #13
Call tool and equipment rental stores, they should have trailers that would work for your needs.
Thanks for the feedback. I did tow my ck35 with no issues. I used 3 chains and 3 binders. Two in the front connected to each side of the loader frame under the tractor. The 3rd chain went through a heavy duty clevis connected to my tractor towing receiver. For where I live this was overkill.
/ Good tie-down locations in a new ck35 #15
Wrong! I've been all morning on this. Not any of the large, nationwide equipment places will rent for use across state lines. Even with trailers tagged out of state to begin with. My choices at present are: U-haul auto transporter and lie that it's not for a tractor & hope no wrecks, or buy a new or used trailer or pay through the nose for a rented truck. I'm currently sifting through CL ads looking at a used trailer to use, then sell it off. I really have no use for a large trailer.
The measurements for those interested: Kioti DK35SE- 16'8" from back of a land pride box blade to front of the bucket.
Tire tracks are: front-66" outside to 42" inside/ rear-69" outside to 34" inside.
I do find many 16' trailers are too light as the weight of the trailer, tractor, FEL & blade come to over 7,000#'s on a trailer with dual axle 3,500's axles even though it will fit on them.
/ Good tie-down locations in a new ck35 #16
#14 I used to do it that way also, until I keep getting DOT,d You actually should of had 2 on that clevis, and a separate one on the bucket. I have a friend that is a local DOT cop and if the chain is not series 7 he take the size and looks it up and goes for half of what the book says. By the way the state wants at least 1 dot cop with inspection license, and dot certification in each jurisdiction, I don't see it actually happening. Also you should of had 2 on the bucket. Heck I cant afford all the chains and binders needed. Another thing if money is made with the truck, trailer, load beware there pushing for a DOT number. Down at the auction today they were checking the Mennonites that haul the Amish around for a small sum of money, you need a DOT number. This country is in sorry shape.
Kenny kkegris@yahoo.com
/ Good tie-down locations in a new ck35 #17
Any way you can give a source for that? I can't find any semblence of a written law like that, makes me wonder if someone is just repeating alarmist blather they heard.
This country is in sad shape as long as people get worked into a lather over fiction they can't lookup themselves.
/ Good tie-down locations in a new ck35 #19
I only know whats happening in this area, I have a friend who is a district justice and she told me when at the hearing ask to see the law they are citing me under and many times they will back down As I have said before I really believe they make some of this stuff up as they go. I have this happening on Tuesday at the auction. I wont even pull my trailer through the local town on Tuesdays because I know they are there about every Tuesday. I will look up Title 75 and see what that says. It is possiable that I got Dot numbers mixed up with PUC numbers. I know first hand I mow at our tractor club for fuel only and got stopped and they wanted a PA number or A DOT number and because I was woring for nothing they left me go after 15 minutes of hagling.
Kenny
/ Good tie-down locations in a new ck35 #20
Rock knocker, I looked up as you suggested 4903 -C3 states that the separate bucket on a hyd machine must be boomed down. and 2942 states that The towing pickup cannot pull a 7000pound trailer if the the gross is only 5815 that why I had to get a 5000 trailer. I don't quite understand post 17. I just know whats happening in my area. I know they mix Fed rules with the state ones because sometime they are cutting you a break. because some of the add ons to fine are not applicable when cited as a federal statue. When I went to the state rep he said a lot of these rules were handed down under the federal Highway safety act.
light tower (A56857)
2020 BOBCAT T870 SKID STEER (A60429)
2020 BOBCAT T870...
1999 Ford F-140 4x4 Pickup Truck (A59230)
1999 Ford F-140...
2022 Ram 2500 4x4 Crew Cab Service Truck (A55852)
2022 Ram 2500 4x4...
2021 CATERPILLAR 313GC EXCAVATOR (A60429)
2021 CATERPILLAR...
2007 JCB 3CX BACKHOE (A60429)
2007 JCB 3CX...
