Good morning!!!!
   / Good morning!!!! #207,831
Good (Sunday) morning. Overnight Low was a frosty -0.6C and it's presently 'warmed up' to -0.3C :D [predicted High of 15C]. It's clear and calm with the sun just coming over the tree line.
Synod went fine yesterday. I'm glad that I left a wee bit early as it was very foggy through most of the Fingal valley = reduced speed. As it says on most Tassie rural speed signs "Drive To The Conditions". The Synod did end around 1700 and I did arrive home just after 1900.
So, as per usual, I'm off to Church in about a half hour and then the rest of the day is His... although, because I was away yesterday I let the fire in the woodheater go out. I'll need to give the flue a good 'whacking' and cleaning before firing it up again.
   / Good morning!!!! #207,832
Good Evening,
Of course, if they’re all the same, I’d be happy for the spares…..
Paul, that crate alone is over 150 lbs.
Take it to a metal shop and see if they can make a copy, then you have 2 gazebo's..
Dennis, they didn’t send the other box that contains the leg stations and other parts. So out of luck in that department! 🥲
It’s all together and will post a picture later or tomorrow. Just need to install the curtains etc but all done for the most part ! Hopefully it makes Kathleen happy 🙏
   / Good morning!!!! #207,834
61F clear sky.
Been good afternoon front field banks trim extra trimming needed soggy,had little zip left in me mow the front field couple place had to back off front tires making deep ruts.
Plans for the evening deck feet up enjoy smooth cigar maybe later share bowl ice cream.
Enjoy your weekend all.
   / Good morning!!!! #207,836
only 2 ft of screen left, so won't be able to do another.
unstairs AC not keeping up again. Some days it's ok, some days not. Guess I need to spend some time troubleshooting.
moved a shelf upstairs to another wall, then put up another shelf unit that's a box about 2x3 that has shelves. That was my wife's project for me for Monday, so I told her now I can take Monday off. :ROFLMAO:
   / Good morning!!!! #207,838
Drinking fresh brewed coffee. 51° with clear skies this morning. Heading to 81° with a few passing clouds. Got all the grass trimming done yesterday. Got mowing tractor out to put pallet forks on. Found that it had a leak in hose to FEL control valve. Messicks has the hose in stock. Should be delivered later this week. Pond Maintenance in morning. Should be a good day to enjoy conserving energy on back porch. Along with some NASCAR in afternoon.
Prayers and best wishes for everyone.
Good Morning All.
2014 FREIGHTLINER 108SD CONCRETE MIXER TRUCK (A59823)
2014 FREIGHTLINER...
EXCAVATOR QUICK DISCONNECT (A58214)
EXCAVATOR QUICK...
2007 CHEVROLET 3500 DUALLY 4X4 DIESEL TRUCK (A59575)
2007 CHEVROLET...
Unused 2025 CFG Industrial QH12R Mini Excavator (A59228)
Unused 2025 CFG...
HYDRAULIC AUGER FOR MINI EXCAVATOR (A58214)
HYDRAULIC AUGER...
(APPROX. 480BF) 1X6X6-16 WHITE PINE TONGUE & GROOV (A52706)
(APPROX. 480BF)...
