Good morning!!!!
   / Good morning!!!! #201,911
PopG, I had a conversation with my supplier to see if the refinery or supplier put anything in the oil before it gets to me. NO was the answer. He also didn't recommend a biocide, in fact he was totally against it.
I had the same discussion with my supplier, but with a different outcome. I get ultra low sulphur heating oil, and add biocide, lubricity and cold flow additives to make it suitable for my common rail diesels that require the lubricity. The other additives might not be necessary, but they cause no harm other than cost, but I can be assured of the quality of my fuel. I do not use it for heating oil at all.
   / Good morning!!!! #201,912
Morning all;
Interesting temps last night early evening got down to 15F then by midnight it "warmed" back up to 21F which is were it's at now. Forecast for a high of 27F and low of 18F.
As far as electric bills ours for Dec. was one of the higher ones that we have had, $382.25 for 1935 kwh.
Not sure how much is from the new car. I haven't set up a new charging station for it and I am considering putting some metering on it to track the parasitic charging for the battery maintenance after it's charged and the % efficiency of the charging setup in the car.
   / Good morning!!!! #201,913
got the fence crew working. They brought the wrong fence.
each board top was supposed to be scalloped. They brought what they said was scalloped and the entire
eight foot section had a dip in the center. Not what I wanted at all.
faced with send it back or live with it, I chose to live with it.
plus I thought the sections had some air between the boards, this was almost solid cedar.
this is why CAD drawings on quotes are so helpful...
just too cold to stay out there with them, 20 with wind chill of 12.
They said no problem with concrete hardening. ok
I ordered oil and filters for new car. Spec was identical to Ford oil in V10 motorhome,
a motorcraft semi syn 5W-30. I'm using full syn Pennzoil instead, forums recommend it.
biggest priority is to change transmission oil, which I will have shop do. Several 4wd components
with fluid reservoirs that also need attention. Over my paygrade, plus I don't have a lift.
   / Good morning!!!! #201,914
Good morning! Yikes! it was not supposed to freeze, I'll have to remember when they say 36˚ my back yard will say 32˚. All plants are out of the garage and uncovered, oh well will see. It will warm up quickly to the low 60s already 47˚ with mostly sunny skies.
The "Farm" came out with the February schedule and I'm on it. February will be the month of "Baby Animals" and "Tulip Fields" festivals. I hope all my scheduled days are above freezing.
   / Good morning!!!! #201,915
Wow, woke up at 10:00, but went to bed after 1 am
10° set our new low for the year. Looks like next week will beat it.
Geo kept up with pellet stove on high.
Better fill it soon
   / Good morning!!!! #201,916
There is the difference, I do use it in my furnace. THE primary use is the furnace and secondary is the Kioti.
   / Good morning!!!! #201,917
64°F and no rain.
Need to test run my generators this morning. By the time I got them hooked it yesterday my batteries had a full charge. All I could do was verify proper voltages at the proper terminals but not actual charging although I could hear inverter clicking to accept. Then I need to wire in the auto start.
H&F at friends later
Prayers for all
Be safe
Have a great day
   / Good morning!!!! #201,918
rip, what are you doing with the electrics??? Are you heating with electric? Lighting up the neighbourhood? Supplying the neighbours with electricity, too?
Looks pretty bad, eh?
Our properties are total electric. Running three HVAC systems and two mini-splits.
Even with a renovation on the Farm House, it's still cold in certain rooms. Circa 1920 build. The newer parts are toasty, though....
   / Good morning!!!! #201,919
fence in, looks nice, I'm making believe those are waves on top...
ordered three climbing roses from Jackson & Perkins for the Spring.
feels great getting my privacy back
KOMATSU WA270 (A58216)
2237 (A58376)
2237 (A58376)
New/Unused Electric Golf Cart (A57453)
New/Unused...
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
2227 (A58376)
2227 (A58376)
2013 Dodge Durango (A53317)
2013 Dodge Durango...
