Good morning!!!!
   / Good morning!!!! #193,521
The ford video was interesting.
96 deg out, deck temp 123deg, trex sample is 133deg.
water softener tank dropped 7" for the last regen. Will keep an eye on it so it doesn't keep adding water like it has been.
swapped buckets catching the condensate drain outside. 2 gallons since yesterday.
only code on the geothermal is it's not performing well. loop water is not getting very much cooler.
downstairs unit doing OK.
made the yearly property tax payment, so will be eating hot dogs for awhile..
water softener tank full again. this getting frustrating. has to be either rotor, seals , or both, guess i'll replace the seals now.....
   / Good morning!!!! #193,522
A little something to lighten the day/evening
   / Good morning!!!! #193,525
The AC is still not cooling as it should. Got it checked by 2 more advanced techs and they think it is the blower motor on the evaporator. It pulses and goes up and down in rpms but not nearly fast enough. They will call Mitsubishi tech support tomorrow to confirm their suspicions
They also recommend cleaning the evaporator and blower wheel. Should be done yearly they say. Seems that is something I can do
It works but not enough to cool it down so installed a window unit to help out while this gets sorted out
   / Good morning!!!! #193,526
Looks like Sophie will be cleared for surgery p. Had a problem with her white coat blood pressure, never got a good reading.
Dr suggested we start monitoring at home.
So ordered this
Another Prime special. His only guidance was to get upper arm cuff. Anyone here care to comment?
   / Good morning!!!! #193,527
RNG, not only do I use environment Canada but I also use The Weather Channel & Ryan Hall, Y'all.
Our winter nasty weather comes from Western Canada and also mostly from Colorado. Summer nasty stuff usually comes up the Mississippi River valley and then swings easterly. Ryan Hall gives me the advance warning I need. Anything that hits Marquette MI usually hits me, too. I am about 40 miles south of Marquette and as the crow flies 388 miles east.
   / Good morning!!!! #193,530
They left for the day garage temp 96. They have just have a little trim work to do and door handles to put on. Over 230 sq ft of storage space added to garage. Finishing up tomorrow and then I can organize and load them up.
While they were doing the installation I was busy chipping away rock on the hearth room fireplace in order to remove the glass to clean. It was apparent this was the first clean in since it was built. It took me 4 hours to chip away the obstruction rock so we could pull the glass panel up and out.
The pool looks too good to pass up. Water temp is 90, going to turn the spa on for sore shoulders from all of that chipping with s hammer.
New/Unused Electric 3-Wheeler (A57453)
New/Unused...
2024 LS MT242E MFWD Compact Utility Tractor with LL3003 Front Loader (A55302)
2024 LS MT242E...
LOT: (17 approx. ) Chain Link Fence Panels (A59076)
LOT: (17 approx. )...
Case skid steer wheels and tires (A56435)
Case skid steer...
METAL STORAGE CABINET (A58374)
METAL STORAGE...
2021 Freightliner Cascadia 116 T/A Day Cab Truck Tractor (A55973)
2021 Freightliner...
