Good morning!!!!
   / Good morning!!!! #176,013
Enjoying a slow day here
Got power to hot tub. Seems breaker was sticking, not sure why. Will have to keep an eye on it. Decides to drain the tub again and refill. I refill with hot water from the on demand heater.
Chemistry for the pool getting close. Have to start thinking about adding the salt and making the conversion. Need to modify the electric a bit, add another receptacle to accommodate the chlorinator and charger for the cordless pool vac.
Need to load up some trash and make a detour to dump on the way to town
I use E0 in everything including truck and car. Fortunately readily available
   / Good morning!!!! #176,014
Good Evening Guys,
M7040, thanks so much for those beautiful Model A pictures !! I’ve had mine for 2 years, have done a brake job, functional signal lights and alternator ! Need to repaint the hood and install a set of the original shocks on all four corners ! 🙏❤️
   / Good morning!!!! #176,016
70F partly cloudy.
Been slow motion day,,,prune dozen spruces 4 maples trees, took nap,made pot seafood chowder Mrs. made home made rolls...yup slow motion day.
Heading for the deck soon enjoy smooth cigar wait for the critters.
Enjoy your evening all.
   / Good morning!!!! #176,017
RNG, to replace the little nub as you call it or key, you just have to lower the spindle quill down slightly and remove a set screw to gain access to that key ! Should be fairly straight forward !
That's what I thought, too. We even found three set screws in the quill that we hoped were the extened nose Allen screws. Nope. Downloaded a copy of the owner's manual for this old green PowerMatic, and saw that the quill has a sleeve inside, and the sleeve has the extended nose Allen screw. Probably wouldn't be a bad idea to take it apart for cleaning and lubrication anyway. I'm just glad it's not mine.
   / Good morning!!!! #176,019
Unleaded gas raises H with older gas engines, but it's illegal to use leaded gas or leaded additives on the street. So how do you fly boys keep the EPA off your backs?
Don’t ask don’t tell.
shoot, shovel, shuddup.
loose lips sink ships
   / Good morning!!!! #176,020
Good Evening RNG,
If memory serves me well this evening, on a Bridgeport mill, you loosen the set screws to remove the large threaded ring at the base of the quill. I believe that gives you access to the key we are talking about that drives the collets ! The Powermstics are very similar ! Have been retired as a modelmaker since 2008 so my memory is not quite that sharp anymore ! 😂
New/Unused SD Lanch 20x30 All Steel Carport (A57454)
New/Unused SD...
2012 Range Rover SUV (A56859)
2012 Range Rover...
2015 MACK CXU613 TANDEM AXLE SLEEPER TRUCK (A59575)
2015 MACK CXU613...
(1) HD 24ft Free Standing Corral Panel (A57453)
(1) HD 24ft Free...
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
John Deere Metal Truck (A57454)
John Deere Metal...
