Good morning!!!!
   / Good morning!!!! #150,981
68F and sunny @ 12:15, supposedly heading up to a high of 76F for the day. Winds out of the NNW @ 5 to 10 mph.
Attic ventilator just kicked on.
Got some more tomato seedlings repotted last night, maybe 8 or so. Kind of cheated though: one peat pot had four seedlings growing in it so I just removed all of them, lock, stock, and barrel and put all four in a larger pot. Will let them grow/root further before I try anything else. Many of these seedlings (in the peat pots) are not deeply rooted ... probably because the soil dries out so fast.
Not sure what all I'll get into today.
Probably move the soil amendments off the bale of peat moss and get that opened up and put in the trash can. Maybe a little clean up in the garage as well.
Then add some peat moss to the latest batch of potting mix in the tote.
At that point I'll be ready to get the last 30 gladiolus bulbs tucked into their grow bag.
Squash and pumpkins will all need watered, along with the 4 bags of glads.
Hopper feeder probably needs refilled. I did notice that the orange half I put out yesterday made it through the night without being molested by the coons.
Relatively light winds would seem to indicate that it might be a good idea to refill the hand pump sprayer and try and to get a little spraying done. The perimeter of the northwest planting bed and around the peach tree on the east side in front are both candidate, along with the oak trees up along the road.
Once I get that peach tree sprayed screened compost can be added around it and some bulbs planted.
Need to tighten the clamp on the hose on the Water Buffalo, fill it, and check for leaks.
Grass down here around the house looks like it could stand to be mowed. Might save that for tomorrow though, when it will be warmer ... ;)
Hope everyone has an enjoyable, productive, and safe Saturday ... (y)
   / Good morning!!!! #150,982
I've used ramps which are ok for cleaning the deck...but too low for changing the blades.
Same here, although I did manage to get the blades changed as well (barely, since the 1/2 impact almost didn't fit.
Was a guy on craigslist here that had a MoJack listed awhile back, think he was asking $150 and it looked to be in good shape (original box, etc)
Still kind of kicking myself that I didn't go for it.
No matter what you use, make sure those wheels are chocked!!
(y)
   / Good morning!!!! #150,983
Yep...you missed a good deal assuming it was in good shape and all the parts were there
I've had a Mo-Jack for a few years. IIRC, I bought it shortly after a long time TBNer (can't recall his name) was killed using his FEL to lift his mower. Again, IIRC, the mower was a ZT and the tractor's hydraulics failed. The cause of death was, IIRC, compression asphyxia.
I've used the Mo-Jack once to pull the blades (my impact wrench won't fit using ramps. Even with the Mo-Jack's safety features, I still use jack stands. I think my Z920 commercial ZT weighs around 1200# or more...I sure don't want that on my chest
   / Good morning!!!! #150,984
Mowed the front yard and a bit more. The front yard has, for the most part, little shade so it was dry after yesterday's soaker.
The sides and back are 50%-70% shaded...still a bit wet. It's a bit breezy, so by tomorrow, should be good to mow.
Nice day! About the mid-70's right now...
   / Good morning!!!! #150,986
so, it's been raining / wet for most of May, all of June (so far) ... today was beautiful and the local car cruise club that I belong to planned our first ice cream run for tonight.
I was deciding between these two vehicles ...
View attachment 748842 or View attachment 748845
The Tracker was getting the opportunity tonight. Then 1 hour to go and ... THUNDERSTORM and HAILSTORM.
The cruise was cancelled, we'll try again next week.
Nice El Camino, we have a 1970.
   / Good morning!!!! #150,987
toppop52 - great photo of your El Camino
   / Good morning!!!! #150,988
I really need to learn to weld. My last heavy duty steel mailbox had the hinge rust off.
Finally got this job done. Forgot to take picture of how I use the backhoe to take flagpole down. Basically a loose ratchet strap around BH and the pole, so it holds the top from falling over when I pull it out of the ground sleeve. then holding the bottom, I can drop the boom to lower it some. I’ll check for security cam footage.
   / Good morning!!!! #150,990
three ton chocks on both side Roy
I have all the equipment I need, just a faulty neck which means I can't lay down on my side and work under a deck any more.
Maybe after I get an epidural on my neck I could try it. Not sure that would be overly smart either.
Look to the movies.
Get a winch and a tree.
Just stop it before it gets to high!
2016 Hino 195h Truck, VIN # JHHSPM2H5GK001607 (A51572)
2016 Hino 195h...
2008 JLG 450AJ SERIES II MANLIFT (A51246)
2008 JLG 450AJ...
2018 FORD F-150 (A52472)
2018 FORD F-150...
Approximately 250 Traffic Cones (A51573)
Approximately 250...
New Land Honor 3'' Semi-Trash Water Pump (A53002)
New Land Honor 3''...
Tires (A50322)
Tires (A50322)
