Good morning!!!!
   / Good morning!!!! #129,621
Had somewhat the same problem with out Craftsman rider,pedal to mower deck I gave all moving parts good cleaning heavy dose WD40 work fine.
That would an easy fix if it works, I'll give it a try on the next road trip, thanks.
   / Good morning!!!! #129,623
From the age of 14-16 ( late sixties) I worked at an AMOCO station, except for a couple of short gas wars the price stayed the same, 29.9 regular and 35.9 for unleaded premium. That was a penny higher on premium than Texaco and ESSO and most brands. Sunoco 250 and 260 were a penny at each step higher.
We had a lot of customers that came for the “white gas”, (unleaded premium).
We called gas regular and high test.
Did you work at the station in Elizabeth City?
Our local station was an Esso, and was 29.9. But I used to go to the Amoco to buy the "white gas" to carry in an aluminum bottle to fuel my backpacking stove...it was a Svea.
   / Good morning!!!! #129,625
Rained out by time I finishedlunch.
   / Good morning!!!! #129,626
Oops... hit post before I was done...
Don, my Craftsman had a problem with the seat safety switch, just wouldn't make contact. I removed it from the seat, put a small block of wood and compressed the switch.... then duct taped it tight...
It's been that way for 4-5 years now... never had another problem with it.
Another thing to check would be if the transmission is free... you may be able to reach under and turn the pulley on the tranny (Not when running). Is it a hydro or gear tranny?
I jumpered past a faulty switch on my husqvarna.
   / Good morning!!!! #129,627
Now that you got me thinking of it it is probably the kill switch to the clutch. It does not sound or feel like a bog down from a clutch. It is not a hst it is at least 10 years old gear model, probably belt clutch.
Now how do I fix it? It does work when I depress the clutch and lets the motor start but the releasing of the clutch activated the kill.
Probably seat switch, it thinks you aren’t sitting in seat so pto switch engaged kills it.
   / Good morning!!!! #129,628
New Yearly record high of 78.3 today.
Buppies, good luck tomorrow.
Worked a little late today. Home after dark.
2 more packages never showed that post office says were delivered. This is getting old.
   / Good morning!!!! #129,629
75 for high today but very dry fire danger very high
prayers for all our Country
   / Good morning!!!! #129,630
Full service, S&H, and we had Gold Bond. I was partial to going to the Sunoco station when young as it had cheapest gas, 180 or 190 I think it was called.
We had both of them too. Down in Alabama they also had plaid stamps, picture of dude in a kilt on the signs.
2014 Glasstream 360 SCX Twin 400R Mercury's with Triple Axle Aluminum Trailer (A56859)
2014 Glasstream...
Sukup 8R Subsoiler (A59814)
Sukup 8R Subsoiler...
Heavy duty ratchet straps (A56858)
Heavy duty ratchet...
2015 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2015 UTILITY VS2RA...
2013 BMW 328i Sedan (A55853)
2013 BMW 328i...
Giyi 27" Mixing Bucket (A57149)
Giyi 27" Mixing...
