Good morning!!!!
   / Good morning!!!! #123,291
Sounds similar to here.
Any area where the surface has been disturbed (aka "excavated" ... :confused2:) is immediately disqualified from consideration.
Not sure exactly what the thinking is behind that, but I suspect it has something to do with whether or not the subsoil, undisturbed, would naturally perc on it's own ... :confused3:
Hope you are able to get it all worked out.
That is what I was told about digging pre perk, it wouldn’t be considered until such time as it returned to its natural state. Whatever that is.
On the land I just got an early buyout on was perked right before I bought it and was told it needed a mound. Perk is good for five years. So I went to another area and took the clay off the top and back filled with a sand and topsoil mix. When it was perked for the new owners 7 years later the first area still needed a mound, so I had them come over 300’ to my “prescription” soil and it perked just fine. After thinking about it I told the buyer more or less what I did in case he had trouble with the drain field, which I didn’t think about until later. He ended up just doing the mound. But I had fun digging and filling and planting grass.
   / Good morning!!!! #123,292
That may have had something to do with the answer I got from the local Health Department ... the point where I was talking to them was fairly shortly after the gas company had installed the well and the area bordered the road they put into to access the site.
Also, IIRC, there was a transition to a different soil type on the parcel.
   / Good morning!!!! #123,293
Best leg/lap warmer ever:
:laughing:
   / Good morning!!!! #123,295
Weird weather for Winter. We're having mornings just below freezing, then afternoons in the 70s. All summer, I mowed my yard one notch higher than the neighbors on either side of us, and we did have a thick, spongy yard. So yesterday, I decided to mow it for the last time of the year. Of course I hadn't mowed in more than a month, and I lowered the mower one notch. And I was a little disappointed in my EGO battery powered mower in those conditions. I had to keep changing batteries and keeping 2 of three on the chargers all the time. The mower, and I, struggled a bit. But I did finally get it all mowed, edged, and trimmed, and filled 4 of the big contractor bags as full as I could stuff them. When I finished, I came in the house and went straight for the shower because I knew if I stopped or slowed down, I'd never be able to start again. Sometimes I think my wife is right when she says I'm gettin' too old for this. I went to bed hurtin' all over, but pretty well recovered except for still being tired today.
   / Good morning!!!! #123,296
Good to know ... will take a look ... :thumbsup:
Was just looking at the RIGID's from Home Depot ... would love to have them for the adjustable height ... but at $40 a pop per saw horse, they're a little rich for my blood at this point ... :(
I’m sure a man of your varied talents could craft an appropriate solution, perhaps using EMT. Remember it is the saw that’s important. Initially, any support can be sufficient and eventually replaced.
   / Good morning!!!! #123,298
LO I have a Pug that insists on lying on me just like that but I can only take it for so long as he weighs 10 kg and at 72 I am finding it just a bit much now.
   / Good morning!!!! #123,299
Bird, you are lucky to have grass to mow really. The drought here has devastated our lawn so we finish up with dirt and dust. Of the acre + around the house I mow a tiny portion now and again. Yesterday I mowed about 150 Sq meters just to knock the purple weed down. I used to mow the entire lawn regularly years ago but haven't had to do that now for around 5 or more years at least. Just a touch up now and again. Should I be grateful? I do love a nice lawn but it is only memories now. This heat is hard on nature and man. A good lawn keeps the heat down around the house.
   / Good morning!!!! #123,300
My neighbors system was closer to $20K here, they seem to see $$ signs when work needs to be done in my area. Too bad my neighbor and I are in the tiny houses, can't afford the monstrosities across the street.
Honestly, I was shocked at how low the price came in. We had budgeted about 8K, hoping not to hit 10K. You're in Bucks, right? That would explain a lot.
2010 LAREDO 5TH WHEEL (A55745)
2010 LAREDO 5TH...
20FT X 30FT STEEL CARPORT (A58216)
20FT X 30FT STEEL...
2008 Ford F650 XL Landscape Dump (A55272)
2008 Ford F650 XL...
TANK MANIFOLD (A58214)
Survey Kit (A57149)
Survey Kit (A57149)
2005 INTERNATIONAL 4300 SBA 4X2 FLATBED TRUCK (A58375)
2005 INTERNATIONAL...
