Good morning!!!!
   / Good morning!!!! #112,601
Almost 11 inches so far Thomas
   / Good morning!!!! #112,602
Update: I found out that he went to an appointment today and is not hospitalized. I kinda back doored them to find that out. I was able to leave a message on his phone this time.
Thanks so much, Randy. I’m sure he’ll have quite the stiry to share with us.
   / Good morning!!!! #112,603
RNG, surprise to hear your bent the arms. Somewhere on TBN in a discussion of lift arms, Quick hitch, Pat’s is also reference to a European method that seemed quite popular. Pretty sure someone put on a Kubota.
   / Good morning!!!! #112,604
Taking a lunch break with wife.
Building wire harness for my canopy accessories.
Found 2 vacant switched fuses in fuse box, EHL and Power Shuttle. Also wanted a non switched feed for my USB socket. Decided not to run new line from battery. In the fuse box the 4 way flasher is always on. Never felt I really needed them to warn the wildlife so I’m splicing into that. Unfortunately the panel switch holder I got is too large, need to find right size for the factory hole, using the one just above throttle level.
Will post pics later.
   / Good morning!!!! #112,605
Thanks, RS. Me neither.
But which QH to get?:confused2:
Before you go with a conventional quick hitch check these out,
https://www.tractorbynet.com/forums/kubota-owning-operating/425066-new-l6060-top-tilt-euro.html?highlight=New+L6060+Top+and+Tilt+and+Euro+Style+Hook-end+Quick+Hitch
My Branson 8050 came with them stock and I just threw a quick hitch on it when I got the tractor and never tried to use them.
One day after I got thru hooking up to the regular drawbar and having to crawl thru the quick hitch getting the pto hooked up
when I disconnected I removed the quick hitch to try the Euro style hooks and I have never gone back.
I can back into an implement with the top of a hook and push it till the other hook lines up lift up and the lift arms are hooked up,
I do have to get off the tractor to connect the top link.
But the access to the back of the tractor for the pto and hydraulics are so much nicer without the quick hitch in the way.
   / Good morning!!!! #112,606
RedNeckGeek
Is something chewing on your siding, Thomas?:confused2:
When Mrs. mowing lawn discharge couple small rocks.mention it more than once discharge away from the house. :confused3:
I put a rock thru the back window of my truck once while mowing.
   / Good morning!!!! #112,607
That’s good news!!
   / Good morning!!!! #112,608
Spanner wrench delivered ... looks to be decent of quality, is a "Martin Tools" brand ... :thumbsup:
Fits ok into the pin hole on the boom cylinders, wasn't going in on curl cylinders :eek: (but I didn't try real hard :)) ... hopefully may just be due to paint ... will find out more once I give it a tap or two with the plastic-headed hammer.
Grocery order placed for pick up on Thursday, shepherds hook moved to the front entryway, hummingbird feeder cleaned out, new batch of juice made, feeder filled and hung, cats and fish all fed (except for the bristle nose cats, whose tank I still need to vacuum), load of laundry done, clog cleared from kitchen sink, whole house vac emptied and container washed out, trash taken up to the can and mail retrieved.
More progress made on pantry - including swapping out an incandescent for an LED - under watchful eye and strict supervision of The Squeak:
... who is also fully qualified to ... luxuriate ... no matter where she finds herself ...​
... - but still a little ways to go to finish it up.
Another something for tomorrow ... :rolleyes:
   / Good morning!!!! #112,610
I bent the sliding stabilizer on the L3940 3ph arm. It caught on the BH bracket. Because of the cab, kubota puts an extender on to move the BH further back. I’ve only had BH off and 3ph on two times. With the ZT, might not take BH off again.
2018 Nissan Pathfinder SUV (A56859)
2018 Nissan...
2016 GENIE S-65 TELESCOPIC BOOM LIFT (A52709)
2016 GENIE S-65...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A56436)
2023 Unverferth...
New/Unused CFG Industrial MX15RX Mini Excavator (A57453)
New/Unused CFG...
CHINESE 125 ATV (A54757)
CHINESE 125 ATV...
KUBOTA KX057-5 EXCAVATOR (A52709)
KUBOTA KX057-5...
