Good morning!!!!
   / Good morning!!!! #112,331
Thanks for the heads-up, RNG. I have two sets of those. Guess I need to check the part numbers when I get home.
2x ... on all counts ... :thumbsup:
   / Good morning!!!! #112,332
RS, any recent pics of the tank room? Last pic I remember seeing was when you were still setting it up. I am being too lazy to try and search for them ....
Nope.
   / Good morning!!!! #112,333
Got the grass mowed, now time to pop the bucket on and get to work.
Supposed to rain tomorrow and Saturday. I’ll try to remember to take pics as I go along.
Made it to the mid sixties, clouds and sun. At least the wind is tolerable today.
   / Good morning!!!! #112,334
67° and .63 inches rain. Nice to see sun this morning.
Trip to PO this morning then back to the canopy project. Hoping for 2 coats paint on the frame. Get the Ezgo top cleaned up, primed and painted.
I can see the grass will be calling my name especially if we get significant sun today.
Prayers for all
Be safe
Have a great day
   / Good morning!!!! #112,335
RNG, better to break something on the tractor than your neck, I'd say go for the widest wheel setting possible unless you intend to plant a vineyard.
No vineyards here, Eric, and with my black thumbs, there's not likely to be anytime soon. Lots of rocks and poison oak, though.
Oddly, the wheels on the M62 only mount one way, so there's no adjusting the track width. But Kubota did choose to mount the rear wheels with the dish facing out, so that they would create the widest track possible.
   / Good morning!!!! #112,336
Mostly nice large mouth
   / Good morning!!!! #112,337
RNG, the tooth bar goes in front of the bolt on edge and attaches to holes drilled into side. It is true the bolt on edge is protected by the tooth bar and you will never need to replace it. That is the same type of upgraded heavy duty bucket I had on the Kubota L5030. The top of the bolts are in-between the teeth and the bolt measurement is needed so the teeth do not interfere with the bolts.
My bar was actually behind the bolt on edge. (only pic I could find)
   / Good morning!!!! #112,338
Ran across this, blast from the past:
   / Good morning!!!! #112,339
RNG, thanks from me, too, on the recall. I have those 6 ton ones...always thought they were too easy to release.
Buppies, sounds really bad...been hearing about the dam and flood on our local news.
   / Good morning!!!! #112,340
Correct ...
TASK FORCE TABLE SAW W/ STAND (A58374)
TASK FORCE TABLE...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
JLG 660SJ (A58214)
JLG 660SJ (A58214)
2012 John Deere 624K (A55272)
2012 John Deere...
2009 International 7400 Altec A77-TE93 92ft. Material Handling Bucket Truck (A55973)
2009 International...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A56435)
Neckover GL24-2-7K...
