Good morning!!!!
   / Good morning!!!! #97,052
   / Good morning!!!! #97,053
Here's the RM43 label, for reference RNG.
I had an empty mustard jar with flip cap that I cleaned well and, filled about 3/4 full, with a small funnel, from the gallon jug. When I mixed up 10 gallon batches of mix, adding the marker dye was easy and neat.
The RM43 label didn't show up, Rick.:confused2:
Be careful with that mustard bottle so it doesn't find its way into the refrigerator.:eek:
   / Good morning!!!! #97,055
Re stabilizer. Had thoughts re a magnet or landscape rake. Area is very rough. The potato farmer did not leave smooth, lots of furrows. Plus the cut grass sits on top and quite thick. Would be near impossible to roll the magnet. Figured the LR would collect lots of grass and with my luck the stabilizer would just slip between the tines. I’ll be keeping an eye open as the mowing improves, but do’t have any immediate hopes.
   / Good morning!!!! #97,056
You can by gallon size RM43 at Amazon and Home Depot for $55.
The 2.5 gallon size was $102 at Amazon, and Prime shipping was free.
I was pretty sure that RM43 wouldn't be available in Kalifornia, so went the Amazon route without even checking TSC...
   / Good morning!!!! #97,057
   / Good morning!!!! #97,058
Re stabilizer. Had thoughts re a magnetic or landscape rake. Area is very rough. The potato farmer did not leave smooth, lots of furrows. Plus the cut grass sits on top and quite thick. Would be near impossible to roll the magnet. Figured the LR would collect lots of grass and with my luck the stabilizer would just slip between the tines. I’ll be keeping an eye open as the mowing improves, but do’t have any immediate hopes.
With your rains, how long for the cuttings to decompose David?
   / Good morning!!!! #97,059
RNG, sounds like your excavation project might be a good test for the M62. Maybe a 4 in 1 bucket? One of those projects you work in small progressive bites. Still love it when a tool gets the job done cheaper then hiring out and I get to keep the tool. Being retired our time is our time. Of course wife tends to disagree from time to time when she’d like a shorter time frame.
   / Good morning!!!! #97,060
This is our dry season, so longer than I’d like. Mowing will likely be quickest route but thinking it might be several times with rotary before switching to flail. The guinea grass needs work. Still about 17 hours shy of 50 hour service so some additional motivation
2011 DOOSAN G25 GENERATOR (A58216)
2011 DOOSAN G25...
2018 MACK CHU613 (INOPERABLE) (A58214)
2018 MACK CHU613...
1997 Perkins 75KW Towable Diesel Generator (A56857)
1997 Perkins 75KW...
2007 Hino 268 Truck, VIN # 5PVNJ8JT072S50704 (A57453)
2007 Hino 268...
(INOP) 2005 JCB 508C TELESCOPIC FORKLIFT (A58375)
(INOP) 2005 JCB...
2005 CHANDLER 500 BBL FRAC TANK (A58216)
2005 CHANDLER 500...
