Good morning!!!!
   / Good morning!!!! #94,921
Condolences to PJ and wife. 72 is just too young.
   / Good morning!!!! #94,922
PJS, sorry for loss of wife's uncle.
   / Good morning!!!! #94,923
Bird, did NOT know you should lube air tools when done
In many cases, especially if you use the tool every day, if you have a dryer on your air lines, etc., it may not be a big deal at all. But as with many things, moisture, which leads to corrosion, is your enemy. So after use, if you put 2 drops of oil into the air intake, give it a very short blast of air to distribute the oil, and put it away, it'll last many, many years. My only impact wrench now is a very old Ingersoll-Rand (IR 231) which became one of my favorite models when I was working on them. Incidentally, you CAN NOT hurt anything by putting too much oil in the air intake, any surplus will just be blown out the exhaust. Of course it might be a little messy but it sure won't hurt the tool.:laughing:
   / Good morning!!!! #94,924
Air Tools should always have at a minimum a few drops of oil before using.
two or three drops is all that is needed in the air input connector, connect the air and spin it up with a few short burst, then get to work. If your work time is long and strenuous, add some more but less than when you first started.
IF you find oil spraying out of the air exhaust... too much oil, use less the nest time.
After the use of the tool oil could be a good thing, just remember not to use as much to get started !
Too much oil isn't bad, except for the mess it can cause.
   / Good morning!!!! #94,925
Thoughts and special prayers for PJS family.
   / Good morning!!!! #94,926
Bit of a stall today, BP kept dropping but I got some work in.
Prayers for the poor little girl with sepsis, I knew it had potential but I’m finding out more every day.
Ellen’s bringing Gracie to visit, can’t wait!
Prayers guys I’ll check in ASAP.
   / Good morning!!!! #94,927
My dad stepped off that boat a 19 year old farm boy, but he lost his youth and innocence that morning. But he was a heck of a man, worked hard, not much nonsense, loved his family, add that to saved the world, it makes a pretty strong resume!
   / Good morning!!!! #94,928
92, feels like 102, did some mowing, got soaked in sweat, that was enough.
Toppop keep swinging.
Seriously skeeved out this afternoon. Dermatologist took one look and smiled and said oh that's not what you think it is...
Gross beyond gross I had a large tick dug under my skin between my shoulder blades where I couldn't see well. And it really hurt pulling it out.
He put me on antibiotics just to be safe.
   / Good morning!!!! #94,929
Rain stop around 9ish and blue sky appear quickly w/light wind temp 73F.
Trim almost 4 hours wet 8"+ grass and the turkeys weren't to far behind :rolleyes: than cut up pine which took down several trees lower end of the field,I am all clean up and plan on just kicking back the rest of the day.
BBQing will be must this evening. :licking:
Enjoy the evening all.
   / Good morning!!!! #94,930
toppop52
Hard to keep good man down. :thumbsup:
2025 JMR Single Cylinder Grapple Bucket Mini Skid Steer Attachment (A56857)
2025 JMR Single...
2013 PRIME TIME RV LACROSSE (A58214)
2013 PRIME TIME RV...
Giyi 43" Disc Mulcher (A57149)
Giyi 43" Disc...
2011 Wanco WLTC4 Towable Light Tower (A56857)
2011 Wanco WLTC4...
Unused 12x20 Carport With 10' Fully Enclosed Side Walls (A55272)
Unused 12x20...
New Holland TS6.120 Power Shuttle 4WD 120HP Agricultural Tractor (A56857)
New Holland...
