Good morning!!!!
   / Good morning!!!! #75,601
Wng, it would certainly make sense to have a filter to catch sediment before it gets in to any other pipework.
Intriguing though as to how the purity of water from the well could be affected by a power outage. Possibly you don't have a non-return valve in the well pipe run, so that once air enters the house pipes, the water rushes back down under gravity and out through the pump to stir up the sediment in the well.
   / Good morning!!!! #75,602
Ron, good to know you use the word "tap" too, which is the only word we use for that thing that lets water out of the pipes in a house. In the US, is there a difference between a tap and a faucet ?
   / Good morning!!!! #75,603
Really busy right now unscheduled surgery on my back healing nicely drain tube out human body is a funny thing. This put on hold removal of latest skin surgery removal by two weeks
We have a whole house filter system for grit acid water etc. system works very well limited maintaince required. Never stopped working cannot afford to would get too far behind
Very dry around here another fire burning north of us 1600 acres and growing
Prayers for all those in need
   / Good morning!!!! #75,604
32 and going to a high of 50. Wind E 8 mph. 30% chance of showers.
Well the dump run is done along with picking up 20 bags (40 lbs ea) of black earth for the garden.
We got the fencing on the deck finished except for the gate yesterday. The gate will get done today and the BE unloaded and piled.
The 15' Crestliner fiberglass boat that I have had forever is full of dry rot. This is the same boat that the Carver replaced. After I unload (backhoe and thumb work) the big rocks that are in it, off to the dump it will go, motor and all.
Eric; tap is easier to spell than faucet. That is why I use it.
Have a safe and happy Sunday all
   / Good morning!!!! #75,605
Probably got it from my mother. Her parents came for Upper Michigan and Belgium. My Dads side of the family came from England in the 18th century.
As far as I know they mean the same thing. But you will not find anything on a store shelf called a TAP for water.
   / Good morning!!!! #75,606
Get well Buppies!
Thanks for feedback on filters, taps and faucets. We say faucets...we generally use tap to describe a nice dance or a light knock.
   / Good morning!!!! #75,607
I only say "tap" after watching too many British shows on PBS.
Drew do the frozen food companies blanch?
64˚ sunny.
   / Good morning!!!! #75,608
Speedy recovery Buppies. :)
   / Good morning!!!! #75,609
2018-05-06, 0812
49 right now...high in the low to mid 60's and rain coming through....quite a bit cooler than yesterday.
I'm going to mess around with that genny I wrote about yesterday...see if I can get it started. I reckon the first thing I should try is fresh gasoline.
   / Good morning!!!! #75,610
50F cloudy low 60's for high on/off rain most of the day.
Todays plan...Tractor Supply for oils and battery,check game cams,puttering in shed,maybe watch some NASCAR,take the day as it comes.
Enjoy the day all.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2023 Kubota LX2610SUHSD MFWD Compact Tractor with LA535 Front Loader (A56438)
2023 Kubota...
Landoll 7130 Harrow (A59814)
Landoll 7130...
Forklift (A59228)
Forklift (A59228)
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59228)
2006 iDrive...
Year: 2016 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55853)
Year: 2016 Make...
