Good morning!!!!
   / Good morning!!!! #63,431
43°F and clear skies this morning, going up to 73° today.
New Amp Day yesterday! My new guitar amp arrived intact while I was at work. Wife cooked some delicious ribeyes, broccoli, and new potatoes for dinner, we ate, cleaned up, and I retired to the bedroom to play with my new toy ... er, tool, I meant to say. I like it quite a bit so far.
Another good accomplishment happened yesterday as the boy finally got his old beater F150 running. It's been sitting in the driveway in front of the garage door for about a month while him and a friend chased down a fuel issue. They've replaced both tanks, pump, and lines, and just after I crawled into bed last night, I heard it fire up. It'll be good to get the driveway back, and his Mom won't have to play taxi anymore.
   / Good morning!!!! #63,432
The low this morning was 30*, yesterday's high was 66*. Today's is going back into the 60's and sunny.
It was nice to look out the window and see a doe feeding this morning. She is all by herself. We have had a doe and fawns coming in at night for the last little while.
Going to look at the outlets in the garage and see if I can find anything wrong with them. That would cause them to burn out the block heater in the tractor. Also check the timer and the extension cords.
Hope everyone has a nice day.
CWB.
   / Good morning!!!! #63,433
I can sympathize with you, Ron. When we're sitting in the living room, my wife is sitting on the sofa under a blanket and I'm sitting right under the ceiling fan in shorts and a t-shirt. Our HVAC thermostat stays on 76 degrees, 24/7 year round. I do like the dual A/C system in our Ford Escape because we can not only have the temperature set differently for her side of the car, we can actually have it blowing hot air on her side and cold air on my side.:laughing:
Same thing here, I'm hot she's cold.
   / Good morning!!!! #63,435
Thomas as my mother used to say we should all take time to smell the roses
AMEN to what your mother said,but sometimes takes a good kick in the back pockets to realize it.
   / Good morning!!!! #63,436
We started the thermostat wars earlier this year. I'm quite comfortable at a consistent 73°F. She, however, seems to prefer wide swings in the settings. She gets hot, She'll turn it down to 68°. She gets cold, it goes up to 76°. No happy medium. Her Kia Sorento has dual zones in the front. It also has heated and cooled driver's seat, and heated front passenger seat. My Soul, though, only has one common system, and she's never happy with it regardless of where it's set. :confused3:
   / Good morning!!!! #63,437
66°F and another .12 inches rain since midnight.
Started another round of mowing, but short lived. Seems a nylok nut managed to go missing from a bolt (M16x80) holding one of the hammers. As it was the very end and from my experience installed backwards, instead of falling out the bolt wore agains the flail housing until short enough to slip from the hangar. Quite a noise. Had to cut bolt to remove. Able to find replacement at Fastenal in town. Raining when I got home so 1st task this morning.
Be safe
Have a great day
   / Good morning!!!! #63,438
Good Morning!!!! 71F @ 10:00AM. 0% Precip. / 0.00 in. Sunny. High 79F. Winds SW at 5 to 10 mph.
Thanks for mentioning that bolt, David. Time to give my flail mower hammer bolts an inspection!
Dr. appointment and errands in town this afternoon, but first have to pack all the electrical tools and supplies back into the truck so I can continue working on the van at the mechanic's. Looking forward to see the progress made on the engine, but not optimistic there's been much.
Happy Hump Day!
   / Good morning!!!! #63,439
Hello all.
Down here I don't get the gorgeous fall leaves that y'all have. However sunsets are spectacular.
   / Good morning!!!! #63,440
Husky 372xp reassembled, even fixed the screwed up fuel line routing.
Runs good, strong saw.
Now just have to see how bad it leaks oil.
2007 Mitsubishi Fuso FE84DW Crew Cab Landscape Dump Truck (A56858)
2007 Mitsubishi...
2022 ALLMAND LIGHT TOWER(INOPERABLE) (A58216)
2022 ALLMAND LIGHT...
Case 950 8 Row Air Planter (A56436)
Case 950 8 Row Air...
1981 LINK BELT HSP 8028 (A58214)
1981 LINK BELT HSP...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
Nalco 400G Rectangular Tank W/ 44" Stainless Flowmeter 5/8"Tube G00927 (A59225)
Nalco 400G...
