Good morning!!!!
   / Good morning!!!! #23,411
62*F. The morning fog is burning off. Headed to 80 today with 50% chance of t-storms late this afternoon.
The contractor who is pulling the stumps and cleaning up in my field project called yesterday to say he is coming here this morning. Been a bit of a wait so I'm looking forward to it. Naturally there is a decent chance of rain in the forecast all week. Like Roy, the scattered t-storms have been scattered elsewhere lately--probably focus on my lot like a laser now when it matters. :laughing:
So, Drew has no taste for being a "mow by wire" early adopter? Theoretically at least, you would never leave the ground like the fly by wire planes do. What could possibly go wrong? One of my FIL's favorite old farm tales was telling of an uncle who when driving a tractor (instead of a horse team) for the first time, went through a fence yelling Whoa!
Have a good one.
   / Good morning!!!! #23,412
65 going to 86. Dried out nicely by late afternoon yesterday, so got most of mowing done. Off to the vet now.
Drew, next time you're headed to Greenville - check out the Agri-Supply store. Big place, easy to get to on your side of Greenville.
   / Good morning!!!! #23,413
63 and cloudy had rain over night.We will have Showers off and on Today with a high of 75.
   / Good morning!!!! #23,414
Good morning, 66F when I left for work, heading to 82F with a chance of rain. Civic holiday here, working on a premium wage today.:thumbsup:
   / Good morning!!!! #23,415
59 degrees and partly cloudy ... real humid/wet ... I could see fog rising up off the ground in the headlight last night when I drove the Simplicity CFC 18 ZTR - which has a steering wheel BTW :D - up to the shed at 10 or 11 PM.
Got the MIG cleaned out/up the night before last ... Grabbed some mothballs when I was at the Big Orange yesterday to see if we can avoid anyone taking up residence inside in the future. The only thing that required much work was the wheels ... they had got pretty chewed up from it getting dragged around in/on gravel ... so I pulled 'em off, ran a bolt thru 'em, stuck on a flat washer and nut so they wouldn't spin on the bolt and then chucked that up in the drill press and hit 'em with a large file for the rough pass, and then used some drywall screen for the final pass. Rolls much more smoothly now.
Last night I fixed the frayed cord on the Sawzall and pulled the rubber nose cover and metal workstop off in preparation to repack the gearbox with grease ... which I also have to do with the angle grinder. So there will be a trip to the Milwaukee Service Center up by Cleveland later today to pick up the correct grease for each. Probably should grab a set of brushes for both of them if they are reasonable. Also cleaned up the framing and finish nailers.
Day before yesterday I started doing a little refurb on my Tool Gypsy bandsaw. With the shed being unheated, anything with bare metal had started getting a little crusty from the condensation and humidity that comes with the seasons:
But nothing a little sandpaper and elbow grease wouldn't handle ... along with a coating of mineral oil to see if we can avoid having to do it again any time real soon. I noticed while I was doing this the rear blade guide on the bandsaw set back quite a ways from the material being cut ... and if it wasn't for the rear backing plate/jaw in work clamp being fixed, the saw could actually cut something wider than the 6" it is rated for - at least on a straight 90 degree cut. So while I was at Home Depot today I picked up some really nice steel spacers and longer bolts for the rear jaw ... and viola ... The Super Cut mod was born:
Cutting a 7 1/2" wide piece of 1/2" plate ... which will be the mounting plate for the new stand for the bench vise I'm building ... to get it off the bench:
A very mild feed rate is critical to keep it from stalling out ... but it works:
Did some measuring and fitting for the SSQA build project, cut and drilled some steel for the mount for the diverter valve on the loader and got a bunch of junk cleared off/put away from the main work bench.
And the very last thing I did last night before coming back to the house was burn all the scrap/trash wood/cardboard/paper to reduce the combustibles in the building ... and it sure didn't take too long for it to get like a sauna inside.
Got rid of a couple old broken axe handles and a rake handle that was bad ... I also burned about an 1/8 can of Minwax Poly that had skinned and gelled up ... and a can of All-Purpose PVC cement that had gone south ... but was still very volatile ... which was fairly entertaining ... :rolleyes:
   / Good morning!!!! #23,416
I agree about Agri- Supply...I sure wish I was closer...I sure would go often...I order from their catalog on line all the time..
We have Tractor Supply Here but lots of Cigarette Smokers and their smoke just outside the door all the time...I thought most folks have quit the nasty habit...!
   / Good morning!!!! #23,417
... lol ...
   / Good morning!!!! #23,418
Good day today, no emergencies to tend to makes it a "day off" from work. I was able to get up and get some tractor time in brushhogging an old trail on the property that hasn't been cleared in about 15 years. It started life as a horse trail a couple hundred years back. About 50 years ago it was widened to access with trucks and tractors and only used for about 20 years. Then it was back to being a horse trail for about 15 years, and neglected with no use for the most recent 15.
   / Good morning!!!! #23,419
71F and .53 inches rain last 24 hours.
At least I had a couple hours of mowing :)
Looks like 2 major storms headed our way.
Be safe
Have a great day
David Sent from my iPad Air using TractorByNet
   / Good morning!!!! #23,420
Not raining, so maybe it will dry enough to finish mowing later.
2013 Ford F-350 XL (A50120)
2013 Ford F-350 XL...
2015 Kenworth T400 T/A Vactor 2100 Plus Combination Sewer Jetter Vacuum Truck (A50323)
2015 Kenworth T400...
2014 DOONAN (CHAPARRAL) 502BBNHTTBZF 50FT CONESTOGA XP SPREAD AXLE FLATBED (A52141)
2014 DOONAN...
2016 KLEEMAN MS192 MOBILE SCREEN (A51242)
2016 KLEEMAN MS192...
2018 Kubota RTV500-A (A47384)
2018 Kubota...
2017 Yamaha VX1050B Deluxe Jetski (A50324)
2017 Yamaha...
