Good morning!!!!
   / Good morning!!!! #23,291
Thanks. There are lots of dog lovers here, so I'll post a link and a section explaining why aggressive treatment is needed. Canine Uveitis - Eye Care for Animals Uveitis must be treated aggressively in order to prevent glaucoma, scarring of the uveal structures, and possibly blindness. Different medications may be used to treat the underlying, original cause of the uveitis and to attempt to control the inflammation itself. Aspirin (not aspirin substitutes) and corticosteroids minimize the inflammatory process. Corticosteroids may be administered by injection under the lid of the eye, by drops in the eye, or as an oral medication, depending on the suspected cause of uveitis. Topical use must be postponed if damage to the corneal surface is present because the corticosteroids prevent healing of the ulcer. If certain systemic diseases are suspected, oral corticosteroids may be postponed until test results become available. Atropine dilates the pupil and helps prevent scarring of the iris. This medication may be contraindicated, however, if glaucoma is present as it may further decrease the drainage of aqueous humor from the eye. Oral and topical antibiotics are employed when a bacterial infection is present in the eye. The first symptom we noticed was a swollen/puffy lower eyelid. So, we thought probably a fly bite or similar. The next day the eye got weepy with excess discharge in the corner, redness in the white of the eye looked like she had been on three-day bender. So, off to our local vet who diagnosed uveitis (an interior infection in the layers of the eye). The local vet is a small operation and they don't have the equipment to measure internal eye pressure, for example. One of Sharon's friends in the Leonberger Mafia had experienced this and her dog lost sight in the infected eye, likely because the treatment was too delayed and not aggressive. She advised if we didn't see improvement in 24 hours, get to an eye specialist. We saw no improvement and the eye now had a bluish cloudy color. I'm glad we went to the specialist. Wallet is $975 less glad mostly due to all the different tests that need to be run to try to identify the infection agent. :(
Thanks for the info, Dave
That sounds a bit different and far more serious than what ours experience, more of an ulcer(looks like a tiny scratch) right on the pupil. Treated with drops or ointment, but sometimes a combination seems more effective. Common enough our vet will refill the prescription if I call in. Interesting about the aspirin. We have found over the years that a baby aspirin (84mg) is often more effective than the prescription stuff. The coated aspirin does need to be crushed or broken up as dogs will pass the coated pill intact.
David Sent from my iPad Air using TractorByNet
   / Good morning!!!! #23,292
Woke up a couple of hours ago ... am on my second cup.
71 degrees and completely overcast with a strong thunderstorm headed in our direction.
Wife got home from work relatively early for once ... even she couldn't figure it out ... thought the time must have changed or something.
Need to grab a shower and then head on over to Home Depot to pick up my drawer dividers. The joy of cleaned and cleared workbenches awaits.
Weldmart got my credit card number wrong ... but still shipped out my order for the plaz cutting guide and consumables anyways ... good folks and the owner Larry is a real hoot. Managed to remember to order a new nozzle and gas diffuser for the MIG as well, since the threads were pooched. Need to pull the lower side panels on it and clean out any mouse nests before I fire it up.
Hopefully I'll be able to get that last section of 3/4" copper run tonight and get the air compressor hooked up ... it would be handy to have some air while I'm cleaning.
Larry,
Hope your mom is alright and recovers fully.
   / Good morning!!!! #23,293
rswyan, I've not been following this thread but if you are cleaning up a shop or outbuilding and going to be using an air compressor - be careful. Three guys - in this county, within the last 12 months came down with Hantavirus doing just that. The force of the compressed air can aerosolize the urine & feces of Deer mice. They can carry this virus and it can be deadly. Two survived after months of recuperation - one did not. Suggest either do not use compressor to assist in cleaning or use tight fitting dust mask.
This is no joke!!
   / Good morning!!!! #23,295
oosik,
This is no joke!!
Thanks for the input ... I definitely don't consider it a joke.
A month or so ago when I started cleaning the shop I started going thru all the shelving - which is particleboard - and giving each shelf 3 (or more) additional coats of polyurethane. The reason I did that was back when we installed the shelves, I had my oldest son (who was in highschool at the time) and some of his friends poly the shelves. Being young and dumbazzes (like someone I know once was) they did a completely unacceptable job (1 coat only) - despite being told specifically what was needed and wanted.
This wasn't readily apparent until much later ... after the shelves had been loaded up with stuff and the mice began pizzin' and crappin' on them ...
There was one spot, on one shelf, in particular that they initially decided to use as a latrine ... that shelf section was essentially destroyed over a single winter, as their urine penetrated into the particleboard, causing it to turn into sawdust ...
When I built the shelves and workbench in our garage a couple of years ago I used plywood (3 or 4 coats of poly) ... and I'll never use particleboard in that application (shelving) again, other than a spot repair of existing work.
Before I recoated these shelves up in the shed I went thru and cleaned them off, first with the Shop Vac, and then with a sponge and Murphy's Oil Soap (twice) ... and then finally with a rag and PPG enamel reducer.
Generally, when cleaning up in the shed, my go to tool is the Shop Vac ... why just blow the dirt around when you can pick it up and actually get rid of it ?
Because of the above I'm generally disinclined to use compressed air for most cleaning tasks, save for a limited few - stuff like blowing oily metal chips that I otherwise can't pick up with a magnet off of/out of the nooks and crannies of the drill press or bandsaw ...
Having said all that, according to the CDC, Ohio, where I live, has seen no reported cases of hantavirus (as of April 21, 2014) ...
CDC - U.S. HPS Cases, by State of Exposure - Hantavirus
But even so, with something like hanta, who wants to be the first one ?
   / Good morning!!!! #23,296
Good evening all. Missed this morning's temp, made it to 84F light breeze. met with real estate agent for 2 hours, rode, and worked on house selling stuff.
   / Good morning!!!! #23,297
2014-07-31, 0329
50 right now....high today will be low 70's and maybe some rain.
The dealer is servicing the z920A (which I thought was going to be delivered yesterday) so, It should be delivered today or Friday...
   / Good morning!!!! #23,298
59 this morning high of 80 later today, clouds and yuck move in for tomorrow
   / Good morning!!!! #23,299
58 degrees heading to the high 70's and chance of thunder bumpers later in the day!
Roy when you have a chance post a pic or two of the zero turn.
   / Good morning!!!! #23,300
Coffee is brewing. 49° with mostly clear skies this morning. Heading to 76° with some sun and chance of rain in the evening. Instead of buying mulch yesterday. I decided to cut down part of 2 trees that died this spring. Got branches chipped into mulch. When done I was hot, dirty and tired. Today will be a day of rest. Will wait for cooler weather to cut rest of the trees down.
Good Morning All.
2019 Ford F-350 XL (A50120)
2019 Ford F-350 XL...
2025 Swict 72in Bucket Skid Steer Attachment (A50322)
2025 Swict 72in...
Appalachain 2 Axle Fender Trailer (A50774)
Appalachain 2 Axle...
1986 East Tri Axle Semi Dump Trailer (TITLE) (A50774)
1986 East Tri Axle...
2019 Fecon BH74SS Hydraulic Mulcher High Flow Skid Steer Attachment (A51691)
2019 Fecon BH74SS...
2007 IC Corporation PB105 Passenger Bus (A51692)
2007 IC...
