Good morning!!!!
   / Good morning!!!! #18,782
good evening all. 5F this morning got to 20F this afternoon. warming trend starts tomorrow.
Had 6AM meeting at church, then off to work. Code issues have been fixed. Data base start up put off 1 month still a lot to do will have a small pilot run in the meantime and more training for the users.
   / Good morning!!!! #18,783
It is a learning experience that takes years.find the biggest parking lot that is empty and do donuts and see how to correct yourself in a slide.
Back when we had clay roads I was pretty good with slides. With rear wheel drive you would turn into the slide. The clay roads have been gone for years, so I don't know what a front wheel drive would do. But I have heard that for most folks the front wheel drive is better in the snow. As long as you have enough ground clearance.
Larro
   / Good morning!!!! #18,784
Thats is a fact Larro also anti lock breaks help if you start to go in to a spin, tap break and it straightens right out.
   / Good morning!!!! #18,785
sodamo 61F Now let's get to the important stuff. So what temperature is the hot tub?[/QUOTE said:
Trying for 95, but raining to hard today. I still have some electrical work yet. At this point, taxing on my off grid system, so not turned on. I figure to further void the warranty by putting together a solar HW and plumbing that to the spa and add some more PV panels.
David Sent from my iPad Air using TractorByNet
   / Good morning!!!! #18,786
OK, just listened to local Wx report forecast up to 6 inches snow on Mauna Kea tonight.
Still raining.
   / Good morning!!!! #18,787
This was posted on You Tube by one of the guys I know from Tomahawk Nation. Kind of funny if you like dry humor.
Larro
   / Good morning!!!! #18,789
2014-01-29, 0346
-8 right now...definitely a bitter chill. High will be 16 degrees.
For you guys not used to driving in the snow...I have a few rules:
If conditions require 4WD, I maintain about 35 MPH. I'll have more time to react if I do slide (and 4WD vehicles surely do slide) and hopefully, recover. You might be late, but you'll likely get there.
Do not use overdrive and sometimes shift to a lower gear.
Use engine braking as much as possible.
And NEVER...NEVER stop when going up a hill!
You can't do anything about other drivers, but just let 'em by if they're in a hurry.
   / Good morning!!!! #18,790
Good rules, Roy
Especially the last. Just before I retired, stationed in No Va. They got a pretty good storm and the government announce lax reporting. Called my boss and told him, I wasn't coming in. His reply was, Why, not, you have a 4x4? Told him, my driving wasn't my concern, but they other idiots that didn't have a clue. I stayed home.
2018 Ford Explorer AWD SUV (A50324)
2018 Ford Explorer...
Farmall 460 Tractor (A50514)
Farmall 460...
Rears 1000 Gallon Orchard Sprayer (A50120)
Rears 1000 Gallon...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52577)
2019 INTERNATIONAL...
2015 JLG 6042 Telehandler (RIDE AND DRIVE) (A50774)
2015 JLG 6042...
1992 Effer 7600 2S Knuckleboom (A51691)
1992 Effer 7600 2S...
