Good morning!!!!
   / Good morning!!!! #97,331
Good Morning!!!! 72F @ 7:00AM. Sunny. High 102F. Winds SSW at 5 to 10 mph.
Hope those on the mend continue to make progress.
Finished mounting the drip tubing on about half the back of the house, and after digging up the sprinkler valve box, hooking up the drip tube to a suitable PVC line and testing. It worked great, so now there are two of the four circuits completed. After lunch, the east side of the house was half in shade, so up and down the ladder I went wire brushing the eve on that side of the house. Today I hope to get a coat of primer on it. Moving those heavy ladders really did my back in, so around 3PM I hit the shower, took a big dose if ibuprofen, and took a nap.:thumbsup:
I was starting to think about those ribs when I got a text message from a neighbor asking for help with a repair he was attempting on his backhoe. It seems that a pin that holds the bucket to the loader arms had worked out on one side, and when it let go, the full bucket bent one of the arms and partially separated the bearing housing. It was actually a spare pair of loader arms he was working on, as the ones on the tractor had cracked all the way around the welds that attach a tubular stiffener to the arms right in front of the tractor grill. Apparently this is a known problem on Cat backhoes of that vintage, and since his had already been repaired once, he thought fixing the other set might be easier. His problem, though, is that both bushing housings had rusted in the ID around the grease groove, and the three inch diameter bar he'd purchased as an alignment rod wouldn't pass through either of them. I went over with a dial caliper and a set of inside gauges, and we learned that if the rust could be removed, the rod would fit perfectly. So I came back home and packed a variety of sanding drums and flapper wheels, and the one in the Foredom flex shaft turned out to be the perfect solution. In a matter of minutes the rod was sliding in both bores, and he was starting to cut the damaged bearing housing from the bent loader arm. This is the same fella that'll end up drilling the holes for the solar grid foundation pipes, and it was a good feeling to know I'd helped him out of a jam. I warned him that welding on that bearing housing would move it all over the place, and offered to help him sequence the welds to keep it aligned, so that's where I'll probably spend the rest of the day after my little painting job is done this morning.
It was late when I made it home, but by then I was really thinking about those ribs. I got one of the smaller pieces out of the 'fridge along with an ear of corn and popped 'em both into the microwave, and minutes later was rewarded with a delicious dinner. It's nice when things work out like that.:D
If such a thing is possible, I hope everyone enjoys a restful and productive weekend!
   / Good morning!!!! #97,332
73°F and .23 inches rain. In between storms. Erick has passed to the South, Flossie enroute and tracking to pass North.
Meet BIL for lunch at Pizza Hut later.
Drew, I’ll bet your neighbor is really excited about your package offer.
Prayers for all
Be safe
Have a great day
   / Good morning!!!! #97,333
Happy birthday to your son Farmer same for Kyles mom
   / Good morning!!!! #97,334
I need to burn a burn pile, but it won't happen this weekend. Much to prepare to burn it.
Don't burn it anytime soon or you will get a big fine. The county has enacted a burn ban.
Lots of tractor work moving gravel, rocks, vegetation, and mulch in the garden this morning.
RNG, that is exactly the epoxy I uses and it worked perfectly on the front bumper.
Today's tractor pic from the Gardens with the bees in the foreground and the gardens in the background.
A baby snake on the street while walking Whipper this morning. It kept trying to strike me. I could not identify it.IMG_3080.JPG
   / Good morning!!!! #97,335
Eric, did the sandbags divert the water enough so the erosion did not progress?
Yes, the puddle clay core is holding up at the moment and work is underway to temporarily reinforce the failed spillway by grouting between the hundreds of bags of ballast dropped by Chinooks yesterday and overnight. Pumps have lowered the water level 1m, but unfortunately more heavy rain is expected.
One person from each house below the dam has the option to return to their homes for 15 minutes to gather pets and a few possessions. Not recommended for anyone who isn't fit or hard of hearing as the escape plan is that the emergency vehicles will give 3 blasts with their sirens if the dam wall bursts, then they have to get out and run to higher ground before the water hits :eek:
   / Good morning!!!! #97,336
I don’t have any possessions in my home that would require me to go back until the all clear is sounded.
Hopefully no one is injured.
   / Good morning!!!! #97,337
Good evening all. 74F for the start, calm wind rain with thunder. About 1/2 inch rain fell, bike ride delayed until 9:30 to miss the rain. After bike ride and lunch came the nap :) , then energy conservation mode.
Buckeye sorry about back pain, hopefully you get released in 3 weeks.
Randy where are you? and how are you doing?
Farmer happy birthday to your son.
Don glad your repair worked.
Eric hope you don't have issue with flooding.
Prayers for all
   / Good morning!!!! #97,338
Storm just went thru. Got some early sleep, now cant get comfortable.
Got nats baseball replay on, watched Os earlier.
   / Good morning!!!! #97,339
Good morning. No wind this morning and a very heavy feel to the air following yesterday afternoon's rain. I don't usually pay much attention to the humidity readings as it's not often much of an issue for us and from this table I can see this would only be a very average start of the day for many on here Average Relative Humidity USA
CWB, you look to have the best morning air. We haven't heard from you for a while, are you still busy helping out neighbors ?
BEF, You have gnats playing baseball ? That must be a really tiny bat :)
What's today's entertainment ? Watch | David Attenborough’s Natural Curiosities: The Flea Circus - YouTube
   / Good morning!!!! #97,340
71 (humidity 95%) going to 89. Need rain.
Eric, now you know our secret on how we raise gnats to be able to play baseball - high humidity! Interesting to hear how the flood is being managed.
BEF, I watched the O's, too...always glad to see them win one. Thank goodness for Mancini.
Happy birthday Farmer's son and Mother of Kyle.
RNG, you're a good neighbor...glad you finally got to eat those ribs.
I think I got my mowing done for a while. Might do an early oil change and lube later.
Enjoy your day!
2136 (A58376)
2136 (A58376)
2837 (A58376)
2837 (A58376)
2012 INTERNATIONAL PROSTAR+ (A58214)
2012 INTERNATIONAL...
New/Unused Quick Attach Auger with Three Bits (A57453)
New/Unused Quick...
2186 (A58376)
2186 (A58376)
2011 Ford Escape XLT SUV (A54815)
2011 Ford Escape...
