Good morning!!!!
   / Good morning!!!! #89,141
Workin' on the third inch of rain since 9:30PM yesterday. No sign of it lettin' up anytime soon, but the rate may drop off. No flooding on this hill, but hard to say what's happening on the way out to the main road. There was enough wind last night and this morning to topple trees, especially those weakened by the fire.
Not a good start to the morning: No water pressure when I went to brush my teeth. Turned out to be a clogged filter, so I pulled it out and will pick up a couple more in town tomorrow. Also found out the fuse is blown in the gate opener again when I went up to open up for the solar salesman. Too wet to work on it now, so I just disconnected it. Still need to go up and close/lock the gate, but I'll let the rain die down a little first.
The young man had done his homework, and came up with what I thought was a very affordable proposal. He was able to answer all my questions, except the battery ones, mostly because they mostly have sold grid tied systems so far. The CEO lost a home in Paradise that had the new Lithium technology they're proposing, so there's not much to learn there, but another system with the same batteries is already having problems with one of the two batteries it uses. I gave him some homework to verify that whatever inverter/charger they're proposing will also work with tried-and-true lead acid batteries, and gave myself an assignment to read some reviews to find a good brand. And to also look into David's recommendation for a carbon battery, though I really want to stick with proven tech, as I consider this upgrade a safety system since my fire suppression system will depend heavily upon it in an emergency.
Hope everyone is staying warm'n'dry...
   / Good morning!!!! #89,142
jbrumberg
$13,000 estimate for all the discussed tree work here. Considering all the tree trunks already under load, the tangle of wild grapes, winter berry, autumn olives, and hung up widow makers in that thicket this seems reasonable, but I/We need to evaluate the entire project. Any opinions/experiences would be appreciated. Should I save a “Specimen Ash” tree? The chemicals used to minimize emerald ash tree borer damage is expensive and needs application every two years. I did not know this, but now OSHA advises against climbing any ash tree dead/dying from emerald ash borer damage due to risk posed by the trunk splitting.
Was the quota from Lic. tree company,was stump grinding also in the price?
Our area about thousand dollar tree down and clean up w/out stump grinding.
   / Good morning!!!! #89,143
About 1500 per tree here. I usually end up taking one down a year. Around the farm house and cottage. Have six left that are in need of yearly trimming and inspections.
   / Good morning!!!! #89,144
This was indeed PITA storm little over 7" :( but everything shovel snow blown plow and the next nasty mess arrives Friday :(...kinda looking forward tomorrow for some rest. ;)
Don't forget tomorrow Val,Day. ;)
Now watching mother Doe and her 2 young slowly making there way to feeder...interesting.
Dinner about an hours watch little tv plan on hitting pillow around 9pm.
Enjoy the evening all.
   / Good morning!!!! #89,145
riptides
If tree good enough for log/logs or fire wood do you get discount?
   / Good morning!!!! #89,146
Unfortunately no. These are silver maple types. We do get payment plans since we are a long-term customer. LOL.
I do use the wood for the fireplace, but again, it is Silver Maple. More like kindling.
   / Good morning!!!! #89,147
Most LED lights need their own drivers, some can be built in, others are separate. There is no need for ballasts on LED's. It's a new world when it comes to lighting today.
ALL LED's require drivers or DC power supplies. The Plug n' Play tubes have an internal driver. Some, more expensive lights have external drivers to power multiple LED Lights.
Some of the replacement LED tubes are powered by 120 Volts AC, 60 Hz. applied to the two terminals on one end of the tube. The other end simply mechanically secures the tube. These tubes would have a distinct "power end".
Others require "hot" to one end and "neutral" to opposite end. This is most likely the style of the Costco replacement tubes.
The question is, when using the Plug n' Play tubes, is whether to disconnect the ballast and connect the tombstones directly to the 120 VAC incoming power.
The ballast (electronic or magnetic), if used to power the LED's has significantly higher power consumption than the LED's direct connected to 120 VAC, reducing the lower power benefit of LED lights. Some LED tubes may not even work with some old "magnetic" ballast in older fixtures.
Another issue, for consideration, is that at "power on" the ballast output can be 300 volts or more, to "fire" the fluorescent tube. Then the ballast output drops to 90-100 volts to keep fluorescent tube lit. Powering the LED tubes at 90-100 volts will reduce light output almost proportionally. Reducing the voltage from 120 VAC to 100 VAC would reduce output by about 20%.
A fixture using 2 x 1700 lumen tubes or 3400 lumens total would be reduced to an output of 2720 lumens at 100 volts.
LED's are rated in lumens per watt and seems most of the plug n' play tubes are about 100 lumens / watt. Increase watts .... increase lumens.
I also suspect that hitting the LED driver / DC power supply with 300+ volts every time you turn it on could / reduce the life of the driver?
   / Good morning!!!! #89,148
I just pulled the tubes and stuck in the FEIT LEDs on mine. I can confirm the fast on and much improved brightness, but I didn't do any before and after comparisons on power consumption with the ballasts still in there. I suppose the other liability is that if the ballast quits, you need to replace it with another ballast? Clearly, you should do summore research for us, Rick!:laughing:
I have RNG. See my response to Mr. Steppenwolfe.
   / Good morning!!!!
Wow. I had 5 trees taken out this year for $1500. 70+ feet tall, a couple of them multi trunk trees. All of them too close to my house and garage for me to do it myself. They chipped all the small stuff, under about 4 inches. Everything else was cut into 5 to 8 ft sections. No climbing, all bucket work. I’ll turn the trunks into firewood over the next few months. I guess things are just cheaper here.
   / Good morning!!!! #89,150
Had to take a couple of rain breaks and no painting, but progress
CATERPILLAR 627K SCRAPER (A52707)
CATERPILLAR 627K...
Unused SDJ-4000 9,000lb Two-Post Electric Auto Lift (A55851)
Unused SDJ-4000...
2024 Keystone RV Hideout Trailer, VIN # 4YDTH1H17RW242459 (A57453)
2024 Keystone RV...
2020 Kinze 3505 High Speed 6/11 Planter (A56436)
2020 Kinze 3505...
Predator 2000 Inverter/Generator (A57454)
Predator 2000...
2021 ASV POSI-TRACK RT-120F FORESTRY SKID STEER (A52709)
2021 ASV...
