Good morning!!!!
   / Good morning!!!! #68,191
TXDON, how much snow is forecasted for you?
Good second morning! Went back to sleep, the heater was not turned on last night and my wife was surprised that I had got up and made the fire. It was a comfortable 68˚ inside. The WBS is a much more comfortable kind of heat than the electric heat. Maybe it's because I don't feel all those dollars slipping away.
24˚ now, I don't think it snowed last night but we did have frozen rain and there is a coating of ice on everything. You can still see the frozen rain in-between the blades of grass. The north windows have a second pane of ice on them and look like antique windows. I don't know how the roads are but I'm glad we canceled my mom's dr. apt today. She does not need to slip and fall on ice with her walker. On the news I saw a lot of Austin overpasses closed. Kyle any culvert crossing closed in Giddings?:D
   / Good morning!!!! #68,192
Our local utility is Warren Rural Electric Company Co-op. Our area is all monopolies so no choices. They buy their power from TVA. Last month was 138.00 plus the propane. Ain稚 got a clue on that as it痴 filled with the chicken coops and all billed together and a fill up usually last more than a month.
I suspect all the "Co-op" electric companies are about as good a price as you can get; maybe better service, too, in many cases because they are owned by the customers and controlled by local residents. We used to have the Navarro County Electric Cooperative.
Navarro County Electric Cooperative, Inc. | Welcome!
Each month, when we got the bill, there was a place on it to write in the current meter reading when you returned that portion of the bill. In other words, we read our own meters. I asked, and was told that they were supposed to send someone to check each meter twice a year, but in reality didn't get around to it even once a year. And in 6 years, I never saw anyone check a meter.:laughing: And when I wanted to replace the pole my meter was on, and replace the master breaker with a different one, I called before breaking the seal on the meter to see if they wanted to come check it, and they did not; told me to just go ahead with whatever I needed to do. So I did.
   / Good morning!!!! #68,193
I'm staying home too today Don. No sense in chancing it. It is sleeting now, but looks like a band of snow is near.
   / Good morning!!!! #68,194
When I lived in PA I was hounded all the time by companies with the legal right to compete against PECO, Philadelphia Electric. Basically the deal seemed to be about a ten percent cheaper rate in the first year, then seemed to go back where it was. Wasn't enough for us to switch to a no name. You had to call PECO anyway if anything broke...
Farmer, I'm worried about using stronger fertilizers, maybe for no reason in this sandy soil.
Many years spent boating in the Chesapeake taught me the perils of too much farm fertilizer washing down into the Bay and causing all kinds of excessive nitrogen problems, fish kills, and algae blooms. Huge effort was made to control that in all contiguous states and it seemed to work, Bay is much cleaner now. So I worry about yeah it might be easy to double down on my fertilizer to get better results, but....the ditch on the edge of this field where all water drains is the very beginning of what they call locally the Blue Line system of water drainage ditches, all of which wind up sooner or later down in the Pamlico River. They are inspected and maintained. Probably only a big issue if there's a gully washer, but I can see in local fields where clearly a lot of water had flowed. So anything on top is headed down to the River.
Any application techniques that can minimize this? First I'm going to disc the granular in and then I'm going to drag rake it. So it should be pretty thoroughly mixed in. But then after the hills are made, the gulleys are natural water drains and anything in those drains, well, drains...
I had planned for the rows to go parallel with the tree line, so they are aiming right at the main ditch. Perhaps I should furrow in the opposite direction. In this veggie garden I can. Out in the main field everything is aimed at the ditch anyway. I don't think my farmer neighbors lay awake at night worrying about their fertilizer runoff. Versus Farmer who has 86 different regulations to comply with and probably isn't even close to water.
My hats off to anyone who has to scoop poop out of a chicken house, I don't care how high tech the equipment is, and those looked pretty cool.
It would take me a long time to get used to that. Very happy and appreciative others do it. All I see is the finished product on that plastic tray.
I watch a lot of farming videos and watch application of huge waste flingers and sprayers, pig stuff looks particularly nasty.
That stuff smells so bad I can smell it coming through the computer! :cool:
The ironic part is a couple trailer loads of that foul smelling stuff is just what my gardens need I bet.
Instead, I bought ten more bags of cow manure and I'm going to go dump them now out in the field.
Then I just might screw around a little and disc it all in. Too early otherwise, but it gives the local farmers something to chuckle
about when they drive by seeing me out there thinking what is that fool doing now? Or they may think it's my infamous neighbor until they see the shiny
paint on my tractors...then they know it's not him. And that makes them doubly curious. I watch the trucks slow way down for a look see.
   / Good morning!!!! #68,195
Good morning from Houston. Well for us southerners it is Cold 29* sleet and snow. Second time this winter. All the overpasses are freezing over and traffic is getting crazy. I could not get up to the ranch today if I needed to. So I値l just hunker down and try to recover form a sinus infection.
   / Good morning!!!! #68,196
Good morning to all! Low of 12 last night, only going to a high of 36 today. Freezing fog caused a bunch of accidents on the roads. Going to work on the organization of the shop (seems like a never ending project). After building the addition and deciding to make one side "automotive" and the other side "woodworking / tractor house", moving all the tools, organizing, and general clean up / declutter, seems to be a daunting task. Never new I accumulated so much stuff. "I'm going to save this small useful piece of 'whatever' because I might need it later for something" has to stop. I have already taken 2 trailer loads stuffed with this junk to the dump already and working on my 3rd! Haven't even gotten to the 'storage area' yet. I wonder what 30 year old something I'll find and say--- I was looking for that!.( I just know I'm gonna need something that I'm getting rid of)(already went back to the scrap metal pile and took stuff back out!) LOL!
I'm glad some of you guys seem to be getting over the hump that life has sent your way. For those still struggling, our thoughts and prayers go out. Have a great day! (Or a better one at least).
   / Good morning!!!! #68,197
Colder this morning 3*, yesterday high was 45*. Today it going be in the high 30's and partly cloudy. They are saying that we are going to get a good storm Friday into Saturday.
Not much going on today. I'll see how it goes.
Hope everyone has a nice day.
CWB.
   / Good morning!!!! #68,198
Hard to believe now, but there was a time when I liked that job when I was about 13 years old because it gave me a legitimate excuse to driver the tractor.:laughing: I'd hook that little 1940 John Deere L to a little trailer, back it up to the chicken house door, load it, then go spread it on the garden to be plowed in later.
   / Good morning!!!! #68,199
24F, hazy sun with light snow falling. An easy day planned moving some firewood, feeding the wood stove, harassing the squirrels at the bird feeders, and prepping for my anticipated 7" of snow tonight/tomorrow. No big deal. It usually takes me about the same amount of time to move snow (~2 hours) if it's 4" (minimum) or +2'.
We had 6 male (probably overwintering) robins in our Russian/Autumn olive trees going after the berries this AM. Those berries are nasty bitter. They are some of the last "native" fruits to be eaten by the birds around here during the Winter.
"..... I'm going to save this small useful piece of 'whatever' because I might need it later for something" has to stop."- LS_mt125_owner. I wish you the best. I can not stop. I get anxious thinking about getting rid of all my "stuff." :eek: If there is an Hoarders Anonymous Program I should join. Wifey would see my membership as a needed household expense.
CWB- your anticipated snow may become my rain early next week.
   / Good morning!!!! #68,200
11F and mostly cloudy @ 11:30 ... the snow has moved to the south and east, looks like we picked up another inch or two. Overnight low headed down to 0F tonight, back into the 40's/50's starting this coming Saturday.
Stay safe and warm ...
2018 JCB Truss Jib Telescopic Hydraulic Boom (A53421)
2018 JCB Truss Jib...
BrushFox XHD-78HF 78in Rotary Brush Cutter Skid Steer Attachment (A55787)
BrushFox XHD-78HF...
2025 MS380R Mini Stand-On Track Loader Skid Steer (A53421)
2025 MS380R Mini...
2010 MITSUBISHI FUSO SINGLE AXLE DUMP TRUCK (A56129)
2010 MITSUBISHI...
UNUSED Folding 4-Step Stool Ladder (A53117)
UNUSED Folding...
CATERPILLAR 336GC EXCAVATOR (A52706)
CATERPILLAR 336GC...
