Good morning!!!!
   / Good morning!!!! #66,081
Ed
All our cats started with a litter box but migrated to outside. Easy to do. Our Simba uses the doggie door even more than the pups. I too, dislike litter boxes, the smell and the work.
I have a box for the indoor cats, use the proper litter, clean it once a day, change it when it needs it, anywhere from two weeks to a month with my cats. Smell is very little issue if done properly. It痴 like anything else, it doesn稚 need to be any worse than you let it.
If I had a pet door I壇 have coons, possums and goodness knows what else.
   / Good morning!!!! #66,082
Don I have a 3 band Netgear router. R8500 I believe. It does a good job in the house. But not in shop and barn. Added a Netgear N300 extender to these buildings. They work great and cost about $30 on Amazon.
   / Good morning!!!! #66,084
What happens if you get your finger in-between the magnet that strong and and metal?
Farmer nailed it. And once the magnet is stuck to something, you'll have a heck of a job prying it off. I put one of those hard drive magnets on the refrigerator door, and couldn't even lift a corner of it. Ended up sliding it to an edge so I could get a finger under it, and it left a big scratch in the paint.:mad: I wouldn't hesitate to drag one of those HF floor sweepers through an ash pile, as long as I knew that the fire was out and cold. I might, however, wrap it in plastic to keep the ash out of the mechanism. HF also sells an inexpensive pallet wrap that would be perfect for that job. I don't think I'd enjoy the job of pulling nails off a magnet. I tried that when the concrete contractor left all the nails from his forming on the ground around the driveway. I sure found a LOT of nails, but none of them wanted to let go of the magnet without a tug-o-war.
   / Good morning!!!! #66,085
3 years ago I cracked the left front fender flare on my Jeep and had to replace it. They only come/are sold in pairs, that is a good thing because this morning when I went to get the mail the windrow from the plow was too close to the ditch and in I went ( about 2' deep) and got the mail boxes too. End result, I need the right front flare which I have from 3 years ago, complete with the hardware to install it. A job for the garage on Monday. I would do it myself IF I had a heated shop, but with temps in the single digits my hands wont allow me to do it. It is a good thing I have 4wd or I would be shelling out for the flare and a tow.
With regards to stinking litter boxes, I use baking soda in the bottom and chick starter is the litter. It is cheap and I am cheep, 55 lbs for $17.oo. Instead of Sweet Scoop (wheat) which is a 30lb bag for $40.oo/bag.
   / Good morning!!!! #66,086
Found the lay z boy issue, piece wearing, and im not a metal worker, but might file it some, might help.
   / Good morning!!!! #66,088
Ron,
How far is the shop and barn from the house ?
IOW: What distance are you covering with that extender ?
I think I'm at around 400' or so up here the shop from the house.
   / Good morning!!!! #66,089
Yeah .... you probably wouldn’t want to do that. Losing a finger might sting a bit?
I’d been looking at all magnets, on Amazon, to make a ”portable” mount to have a video camera on front end loader when using pallet forks, stump bucket, and tree / post puller.
   / Good morning!!!! #66,091
Got the flooring down in the pantry today. Wife thinks it is great so I do too. Not as worried about a litter box smelling an just having to clean it and to many feral cats around here for a doggy door.
Rip, praying for you and your wife and will keep at it.
Drew go over to your neighbors and ask if he has an old junk microwave and get the magnet out of that. Tie it to a stick and :D
Have a good night. Ed
   / Good morning!!!! #66,092
Ron,
About 150’ with each. Don’s pool and garage are about the same distance. His tractor barn is about 400’. But he may be looking for more coverage in the house. Costco and Sam’s club have good routers for in-house on sale. Get the most powerful your pocket book will allow.
Going 400’ may require specialized antennas to transmit that far. My main router claims 600’. But the signal does not work good in metal barn or shop. The extenders solved that problem.
   / Good morning!!!! #66,093
Ron, where did you install your extenders? At house or in / near your out buildings? I’ve got same issue here but my shop is probably 1000-1200 ft. from ranch house.
   / Good morning!!!! #66,094
My out building isn't that far away from my wireless router (Netgear R7000), but both it and the house are stucco, and the wire mesh stops radio signals cold. I ended up running CAT6 cable between the two, and using another Netgear R7000 as a repeater. PITA to dig the trench, but there's no speed halving like when using a wireless extender.
I also ditched Netgear's firmware and installed Toastman Tomato. Easy to set up and simple because it drops all the bellz and whistles I'd never need or want.
   / Good morning!!!! #66,095
The extenders are inside the 2 building. My iPhone and iPads work work well with the extenders. I have 5g in the house. It works well while inside. Our house is concrete block. Lucky to get any signal outside.
If I needed to go further. I would do like RNG did. Run hard wire.
   / Good morning!!!! #66,096
Thanks Ron.
   / Good morning!!!! #66,097
Thanks RNG.
   / Good morning!!!! #66,098
I use to stock all those parts, La-Z-Boy sent them to me free of charge to service their customers, I still had a bunch in my building that burned. If you get the model number and contact them, they will often send a replacement part or entire unit. They have lifetime warranties.
   / Good morning!!!! #66,099
Thanks, might give it a shot. Chair is 30 yrs old. 1216171448.jpg if you zoom in, you can see the wear in the notches.
   / Good morning!!!! #66,100
Good evening all. 35F this morning, clear, light wind. About noon sky started to cloud up, wind was blowing 15+ from south, and a high temp of 60F was reached. Rain started about 5:30, forecast for .17 inches best rain since August ! :cool: Bike ride, lunch, shower, nap, dinner, stove duty. Have a real good shot at 6K miles on bike this year, last year total was about 4800.
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2019 FREIGHTLINER...
1667 (A57192)
1667 (A57192)
2019 CHEVROLET SILVERADO LD CREW CAB TRUCK (A59823)
2019 CHEVROLET...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
2005 John Deere 7320 (A60462)
2005 John Deere...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
