Good morning!!!!
   / Good morning!!!! #66,091
Got the flooring down in the pantry today. Wife thinks it is great so I do too. Not as worried about a litter box smelling an just having to clean it and to many feral cats around here for a doggy door.
Rip, praying for you and your wife and will keep at it.
Drew go over to your neighbors and ask if he has an old junk microwave and get the magnet out of that. Tie it to a stick and :D
Have a good night. Ed
   / Good morning!!!! #66,092
Ron,
How far is the shop and barn from the house ?
IOW: What distance are you covering with that extender ?
I think I'm at around 400' or so up here the shop from the house.
About 150’ with each. Don’s pool and garage are about the same distance. His tractor barn is about 400’. But he may be looking for more coverage in the house. Costco and Sam’s club have good routers for in-house on sale. Get the most powerful your pocket book will allow.
Going 400’ may require specialized antennas to transmit that far. My main router claims 600’. But the signal does not work good in metal barn or shop. The extenders solved that problem.
   / Good morning!!!! #66,093
Don I have a 3 band Netgear router. R8500 I believe. It does a good job in the house. But not in shop and barn. Added a Netgear N300 extender to these buildings. They work great and cost about $30 on Amazon.
Ron, where did you install your extenders? At house or in / near your out buildings? I’ve got same issue here but my shop is probably 1000-1200 ft. from ranch house.
   / Good morning!!!! #66,094
My out building isn't that far away from my wireless router (Netgear R7000), but both it and the house are stucco, and the wire mesh stops radio signals cold. I ended up running CAT6 cable between the two, and using another Netgear R7000 as a repeater. PITA to dig the trench, but there's no speed halving like when using a wireless extender.
I also ditched Netgear's firmware and installed Toastman Tomato. Easy to set up and simple because it drops all the bellz and whistles I'd never need or want.
   / Good morning!!!! #66,095
The extenders are inside the 2 building. My iPhone and iPads work work well with the extenders. I have 5g in the house. It works well while inside. Our house is concrete block. Lucky to get any signal outside.
If I needed to go further. I would do like RNG did. Run hard wire.
   / Good morning!!!! #66,096
Thanks Ron.
   / Good morning!!!! #66,097
Thanks RNG.
   / Good morning!!!! #66,098
Found the lay z boy issue, piece wearing, and im not a metal worker, but might file it some, might help.
I use to stock all those parts, La-Z-Boy sent them to me free of charge to service their customers, I still had a bunch in my building that burned. If you get the model number and contact them, they will often send a replacement part or entire unit. They have lifetime warranties.
   / Good morning!!!! #66,099
Thanks, might give it a shot. Chair is 30 yrs old. 1216171448.jpg if you zoom in, you can see the wear in the notches.
   / Good morning!!!! #66,100
Good evening all. 35F this morning, clear, light wind. About noon sky started to cloud up, wind was blowing 15+ from south, and a high temp of 60F was reached. Rain started about 5:30, forecast for .17 inches best rain since August ! :cool: Bike ride, lunch, shower, nap, dinner, stove duty. Have a real good shot at 6K miles on bike this year, last year total was about 4800.
2001 CATERPILLAR D400E 6X6 OFF ROAD DUMP TRUCK (A60429)
2001 CATERPILLAR...
2017 Toyota Camry Hybrid Sedan (A59231)
2017 Toyota Camry...
VOLVO ECR25 ELECTRIC EXCAVATOR (A60429)
VOLVO ECR25...
2022 Greenworks CU400W Commercial Work Utility Vehicle DEMO UNIT (A56438)
2022 Greenworks...
2024 JCB 35Z (A60462)
Brock 48'x16' Flat Bottom Grain Storage Tank (A57148)
Brock 48'x16' Flat...
