Good morning!!!!
   / Good morning!!!! #26,481
34F and cloudy @ 20:00
Got a little clean up done in the shop and then got some stove wood split just before I came down for dinner.
Earlier I hosed off the regular loader bucket (upcoming mods and paint touch up), snowblower, and wood chipper and then moved the wood chipper into the shop for maintenance, modifications, and general TLC:
I'm going attach a couple pieces of 4" x 6" x 48" PT lumber to the bottom of the base to raise the unit up so that the PTO shaft isn't running at an extreme angle, cut off the feed roller bar and move it to the back and make it foot-operated, add a couple of pieces of plate into the throat of the feed chute to prevent small stuff from wrapping around the feed roller rod/axle, and, if I can scare up a suitable chunk of sheet/plate, modify the side wings on feed chute so that they angle outwards. Also need to modify the top link attachment point for clearance with the quick-hitch hook.
Might even have a look at modifying the output chute so it can be rotated ... :rolleyes:
And I need to grease the unit, check belts/alignment, sharpen the blades, and set the anvil/blade clearance ...
   / Good morning!!!! #26,482
Finally remembered to take the pictures.
Dabsgt nice new tractor. Might think about some chains.
Thank you all. Loaded the tires and I'm hoping that the chains from my 855 will fit.
   / Good morning!!!! #26,483
farmer2009: The slab looks fine. a 1/16th or even an 1/8th of an inch is nothing to fret over.
I'm not Dave. Concrete will never be perfect but the flatter you shoot for the better off you are.
   / Good morning!!!! #26,484
2014-11-13, 0323
28 right now...high of 43 today...
   / Good morning!!!! #26,485
28F partly cloudy mid 40's for high.
Bet one could hear mouse burp outside the air that still.
Enjoy the day all.
   / Good morning!!!! #26,486
30 degrees and heading up to tee shirt temps, nearly 45 F
Another partly sunny day
   / Good morning!!!! #26,487
41 this morning high of 47 later tomorrow high in 30s. The ground is starting to get dry
Thomas great one about mouse
Good Morning
   / Good morning!!!! #26,488
Need to get second cup of coffee poured. 28° with cloudy skies this morning. Heading to 34° with possibility of some lake affect snow in the afternoon. Off to Dentist for 6 month cleaning and checkup. Neighbor has a 100' trench that needs filling in. May wait a day to do it. Should be a little warmer with sun tomorrow.
DABSGT, nice green tractor. :D
Good Morning All.
   / Good morning!!!! #26,489
44 out now headed to 46. Today will be shop cleaning day
   / Good morning!!!! #26,490
42 cloudy and breezy headed to 47. Rain/snow chances tonight now up to 60%.
Will try to mulch leaves (finally finished falling around the house yesterday) then change oil in 4Runner before rain starts this afternoon. I still need to take the bush hog off the tractor, so maybe the rain will hold up a while.
2013 MACK CHU613 (A50854)
2013 MACK CHU613...
2024 AGT INDUSTRIAL HR-230 3-WHEEL LOADER (A51242)
2024 AGT...
2019 JCB 457 ZX T4F Articulated Wheel Loader (A49461)
2019 JCB 457 ZX...
INDUSTRIAL SAND BLASTER (A50854)
INDUSTRIAL SAND...
1991 Gmc Top Kick Dump Truck (A50514)
1991 Gmc Top Kick...
SHOP MADE  MANIFOLD TRAILER (A50854)
SHOP MADE...
