Good morning!!!!
/ Good morning!!!! #48,601
Good Morning! 65F @ 6:45AM. Sunny. High 93F. Winds SW at 5 to 10 mph.
Lenny, your job as a granddad is to spoil the little dear rotten, then hand her back to her parents. But it seems they've already beat you to the punch, so you might have to un-spoil her a bit just to make it through the visit. :confused2:
Don, glad the Whip is feeling better. But you'd think after five bites she'd learn to steer clear?
Drew, I still have the headliner I pulled out of the van if you want it. It's only got a few water stains on it, but it's held in with steel stays, not glue. It's yours if you want it. Keep in mind it's German, and might not get along with that English contraption you've latched onto though.:laughing:
Instead of another day sanding and priming, I detoured into a few small projects that had been hanging. One was to put the microwave door back together, as the epoxy I'd hoped would fix the handle should have cured overnight. But first I had to get to the lower screw that held it on, with no visible way to do so. After an internet search I stumbled across a Youtube video that showed how to do it on a similar model, and this one worked the same way. But when I threaded the screw into the epoxy it wouldn't hold, as the glue was still soft. Must not of gotten enough hardener into the batch, so I scraped and pulled it all out, then re-did it. Then tried to keep using the microwave with the door even more torn apart, what fun!
Then there was the little plastic console that held the 4WD controls for the van. It had cracked into several pieces when I removed it, and I'd glued it back together leaving the seams unfilled and mismatched. So I dove in with some rough sandpaper and worked them smooth, at least as well as I could. But that left the rest of the fake leather grain on the plastic a mis-match, so I sanded all of that off, too. Now it's ready for primer and paint.
There are two dashboards available, but the one for the keeper van is all split and cracked, sort of like dried mud. The older one is almost all sheet metal, and will clean up nicely with a light sanding. All except for a narrow bit of plastic padding that looks like it's been attacked by a woodpecker. Got out some paintable latex caulk and filled the holes, then pulled out all the switches, cigarette lighter, and other goo-gaws. Today I'll trim up the caulk repair, then sand the rest, getting it ready for yet more primer.
A shipment of sound deadening sheet arrived last week, and I wanted to get some into the under dash area before it went back to the mechanic for the A/C installation. That meant removing the old blower housing, which he said was just a matter of pulling four screws. But with four screws removed it was still in there tight as a tic, so I started prying and jerking on it until I found a fifth screw hidden deep in the shadows. And a bunch of cables and wires that needed disentangled and clipped. That got it loose, but I wasn't prepared for what was revealed (see photo from yesterday). Only gagged a couple of times sopping up the mouse mud with paper towels and bleach water, and that was while wearing a respirator. I've got a funny stomach that way I guess. So with that out of the way and hopefully dry today, I'll stick on the deadener and be done with that job.
I'd better get up and fill the hummingbird feeders. There's a half dozen of them on the one outside the bedroom slider, and more hovering round looking for a place to land. All that buzzing and squawking comin' outa such little birds!:shocked:
/ Good morning!!!! #48,602
I picked a Cub Cadet 3208 yesterday to use as another utility tractor, can't have too many!
truer words have never been said...;)
that looks like a high end model with the Kawasaki engine, shaft or belt drive?
Shaft drive, power steering foot controlled hydro.
/ Good morning!!!! #48,603
less sugar is always good as long as it doesn't taste sour. I eat it every day, mix up the brands, try a lot and try to avoid the ones with what amounts to
marmalade down at the bottom. I guess if I flavored plain yogurt with peach or pineapple juice, that would work nicely. But the juices are all sugars so I wonder
if the Splenda sweetened variety is best. Lots of different Greek yogurts now being marketed, about half the case of yogurt at the supermarket.
So since I doubt much of this yogurt really comes from Greece, the process must be different. I wonder if the original yogurt was made from goat milk.
I've been sprinkling some sunflower kernels into mine, bought some for a healthy munchy for guests and no one wanted it. So I'll use up the sunflower kernels
in something else. Usually I dump blueberries into the yogurt. Which I wish came from my own blueberry bushes but not this year. Critters got everything.
Need to build some serious protection for my three flower beds, all of which have now been munched by deer, the roses, half killed, blueberries and blackberries, they only ate the blackberries which thankfully are coming back, and the veggie garden, where I now see the tomatoes up high have been munched.
I now realize my electric fence, which I put around the veggie garden, and nothing bothered it, until now, really needs to go around all three gardens; they are lined up in a row. But the birds are another story. So at least over the berries, i would need a roof. It all sounds too complicated but I'm tired of my gardens being wrecked.
Half the roses did not survive a denuding, particularly during that high heat spell. Too much of a shock I suppose. Perhaps plants get rid of their heat through their leaves...and without any leaves I wound up with dead sticks. Am learning absolutely everything has to be fenced. Otherwise I am just providing feeding stations for the locals.
Nothing new, just a lot more critters and invasive species than I've been used to.
And i sure wish they allowed year round deer hunting. Yummy
venison burgers for all.
I bet some hunters here know...how does deer stack up to beef and chicken as far as protein and fat content?
Though I doubt we'll be seeing a Bambiburger at McDonald's anytime soon.
You always have to stir yogurt before eating. It doesn't hold together in storage like a lot of the processed foods. I've tried several brands, and for the price difference, there is not enough taste difference for me to justify buying anything other than the Walmart store brand. For my breakfast. I mix some of the vanilla yogurt in with it, with a 1:4 ratio of sweet to plain. But then my breakfast is quite the hodgepodge anyway. It's a quarter ounce each of four kinds of granola {3 protein ones, and 1 of the chocolate kind}, pumpkin seeds, sunflower seeds, flax seed meal and Whey protein powder {I favor the chocolate or peanut butter myself}, a half ounce each of two kinds of soybeans and a Kashi cereal, then 100 grams of PGY, 25 grams of VGY and 80 grams of grapes. I add just about 3/4 cup of water. Haven't used milk in my breakfast in a couple of years.
I have some stinky stuff to help keep deer out of the garden. {I have a 5' fence, but still use this along the fence} It is called Repeal All and works pretty good. I bought the spray the first time, and the bottle didn't last very long, so I went with the bigger jug of granules the next time. I think it is sulfur based. My old gardening buddy down the road has some stuff that is egg based. It really stinks, and works better than my stuff, but costs more too. And some tricks we learned about putting up electric fencing to keep deer out while trying farm. Use a rubber bungee cord at all the corners {and don't attach it to any of the insulators in between} so it doesn't break the second they run into it. And like with goats, you really need to put one strand down low attached straight to your steel posts. This creates a ground so they will be shocked.
Deer are very lean. Except for the ones you try to fatten up with corn, and they are still pretty lean.
/ Good morning!!!! #48,604
We finally got a good shower. Little more than a 1/4 inch in half an hour. Only downside, I was transplanting Tommy toe tomatoes earlier, and my kiddie pool of soil mix was uncovered.
/ Good morning!!!! #48,605
71°F and .24 inches rain last 24 hours.
Be safe
Have a great day
Sent from my iPhone using TractorByNet
/ Good morning!!!! #48,607
71 this morning and made it to 90 so far. Looks like it might be raining around the house.
I'm at the doctor with wife. They put a device on her c-section that is supposed to reduce the risk of infection. And today is the day it comes off. Don't want a repeat of last time.
/ Good morning!!!! #48,608
I had visitors, or at least the van did, a good while ago. Found this behind the heater blower housing today:
Those are the main air intake ports for the fresh air/heater/AC. Not so fresh, eh? :yuck:
Pulled on a respirator, snagged the big chunks out, the doused everything in bleach water. Of course the mouse poo turned to mud, and I used half a roll of Bounty mopping up the mess. Only gagged a few times, so I guess it wasn't that bad. :shocked::yuck: Yeah, I :censored:ing HATE meeses to pieces!
I recently was watching an episode of "Chasing Classic Cars" tv show, and the host discovered a barn find...a 1921 Stutz Bearcat that hadn't been driven in 80 years...guess what he found in the cubbie holes - huge mice nests - he went right after them barehanded and bare faced. I at least put on gloves, most of the time, when I find them. I hope you got it all out.
/ Good morning!!!! #48,609
Billy, do you have an online source for your good coffee? Or just a local store?
do you roast your own coffee and what kind of roaster?
I can smell that Sumatra coffee from here, wind is blowing this way...;)
Drew
I order my coffee as green beans from an importer, and then roast a couple of pounds each week...drink some, give away some...always thinking about how to turn a little profit, but I'd have to upgrade to a bigger roaster...mine only roasts a half pound at a time.
Lots of fun discovering different tastes from different beans and different roast profiles. I keep a log to record what works best on different beans and under different weather conditions.
/ Good morning!!!! #48,613
Found a Everlast 256 S Tig, Stick, Plasma cutter on Craigs list this morning. They said they had used it about 6 hr and it looked like it was true. Has an air cooled torch and a water cooled torch with a cooler, electrode holder, regulator, foot peddle, plasma torch and a fancy ground clamp that looks like vice grip C clamps. He threw in a bunch of little things and I brought it home for $1750. That is what the machine costs without the water torch and cooler. Don't need it but it will be fun.
Don glad to hear Whipper is better so fast.
Drew put some PB on your electric fence.
Have a great day Ed
/ Good morning!!!! #48,614
Drew
A bit more than self emptying rain gauge but I think you would enjoy a Davis Wx station
I run a Davis Vantage Vue here, and just this morning the outside temperature sensor started reporting about 12 degrees too high. Last fall both the outside humidity and temperature sensors stopped reporting. I disassembled and repotted them, and they started working again. Don't have time to mess with it now, but you'd think for $400+ it would last more than three years...:thumbdown:
/ Good morning!!!! #48,615
I run a Davis Vantage Vue here, and just this morning the outside temperature sensor started reporting about 12 degrees too high. . . .
I had the same problem with my Accurite and it turned out a spider had web stopped the solar air circulation fan and the temp would report 10-15˚ hotter when the sun hit it.
/ Good morning!!!! #48,616
Thanks, Don. But now it's stopped reporting altogether. Maybe my potting job melted? :eek::laughing:
/ Good morning!!!! #48,617
Can you give a few more details. That's what my accurite is doing. I was thinking about going to a Davis.
/ Good morning!!!! #48,618
Good evening all. 81F this morning partly cloudy with near calm wind. Made it to 100F some cloud build up but no rain. Yesterday had some pop-up storms nearby, but no rain here. Consulting all day :(
/ Good morning!!!! #48,619
Take the screws out that hold the top and bottom half together (but not the middle screws or you will mess up the rain gauge). Look for spiderwebs around the little fan that is powered by the little solar panel and clear it. After the fan gets going again you should get closer to the actual temperature but on a hot day with a lot of sun it will still read up to 5˚ hotter than it really is. There is a good youtube that shows how to do it - I'll look for it.
Here it is:
AcuRite 5-in-1 Sensor Maintenance - YouTube
/ Good morning!!!! #48,620
I had a Vue also was not happy with it only lasted about 2 years but the Vantage Pro I have had for 9 years now sent it in for a refurb and only cost $125.00 to totally redo it! Much cheaper than buying a new unit after 9 years!
2020 Chevrolet Tahoe SUV (A59231)
2020 Chevrolet...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
2025 HT360W Mini Stand-On Track Loader Skid Steer (A59228)
2025 HT360W Mini...
2017 Ram 2500 4x4 Crew Cab Pickup Truck (A60352)
2017 Ram 2500 4x4...
John Deere 1025R (A53317)
John Deere 1025R...
2016 Chevrolet Traverse SUV (A59231)
2016 Chevrolet...
