Good morning!!!!
   / Good morning!!!! #43,261
My day did not start off well, but at least it improved.
Just as light was coming up I looked out the rear deck door and saw heat shimmering off the new gas grill.
Oh no.
They turned it on to show me it lit and we didn't turn it off.
So.............
from 1pm yesterday to 7am this morning my new gas grill went full blast. Seems unharmed except the grate looks slightly warped in the rear.
I don't blame it...
Otherwise, and they say clearly not to run it full out while cooking, just to heat it up. Well, I sure did the heating part right...
And of course I then had to walk out to my 500 gallon propane tank, which had just been filled, to see if there was anything left, which
of course there was, but geez what a waste of money.
24K burner appears to have used 30-50 gallons of propane over that whole time. Groan. It's one thing to screw up when all you waste is a little
portable tank. It's another thing when it's hooked up to that big pile of tanked cash in the rear lawn. I better be awfully careful with this thing.
Maybe I need a loud alarm clock inside just for the grill. Like an old Big Ben.
Once that little mishap was corrected, I spent many hours landscaping around the barn and new shed, finally got it done, raked way more crusher run stone than I should have, but was pleased when I was done. All the pipes are now buried, and I think I got the levels right so the water will run where it should.
Will be interesting to check it out tomorrow afternoon after an inch of rain comes down to see where the new low spots are. There are always some...more raking.
Then I pulled the water roller until I heard a snap and there it was a ways back. Great.
One of the frame bolts had snapped, NOT grade hardware..., so after about half an hour on my back in the cold not so dry field, I got it fixed and
finished. I put grade 5 bolts and lock washers back on, and will give them a little shot with the impact gun in the near future. That towing frame takes a huge amount
of abuse pulling the heavy roller over bumps and dips and I should have seen it getting loose. One bolt must have loosened to the point where it torqued around and snapped the bolt.
Gravely still would not start, dead as the proverbial door nail. Checked the only two nanny switches on it, they were fine. Going to take apart the one contact switch on the hand clutch as that is the likeliest culprit. Then on to the next possibility. It was running perfectly and just died like the switch was turned. Definitely electrical.
Had a burger for dinner on my very well seasoned new grill. It worked fine but every time I try a prepacked burger I'm disappointed. Unidentified chewy things inside.
Never had that problem with the store ground chuck. So the grill was fine, the burger not so. I bought these burgers on sale and it was a swing and a miss.
Actually the first thing I did today for several hours is crawl around and build the raised garden, and then insulate it just like the bottom of my mold remediated house...
Not hard to do and didn't have to be too neat, am covering the top with another piece of wood. Topsoil goes in next, then many bags of compost and garden soil.
Friend is coming over on Saturday to test my soil; he's in the ag chemical business and he does this often. I need to apply long acting fertilizer to the orchard and figured it was long overdue to get the soil tested. I was told the ph was normally off and that decreased the effectiveness of the fertilizer by almost half.
   / Good morning!!!! #43,262
Drew that sounds like a very overdone burger :). Sorry, but sure glad no major damage.
But that ground in front of your shelter looks great - and never appreciated how big it is until seeing it dwarf your tractor.
Well, already had some snow flurries this afternoon here, and the forecast has been upped to 3 to 5 inches tonight.
   / Good morning!!!! #43,263
Cold today, and now they've changed our mix to rain forecast, to include three inches of snow.
   / Good morning!!!! #43,264
Took a bit longer to fashion my brackets, got the safety railing installed at Cottage. At 4ft I don't anticipate anyone attempting to scale it.
Sent from my iPhone using TractorByNet
   / Good morning!!!! #43,265
Those of you in snow country, please ignore this!
Set record high temperature, for this date, this afternoon at 85 degrees. Luckily the humidity was low. Hope this isn't early sign of upcoming summer?
   / Good morning!!!! #43,266
Drew, don't feel alone. A few years back I forgot to turn my grill off for about 12 hours. Luckily it was on a low setting, but I didn't have the heart to look at our tank. What was worse, about year and s half or so I'm making breakfast and the stove goes out. Shouldn't happen with a 250 gallon tank! One of the underground pipes had developed a leak, about 100 gallons gone. We were paying about $5.25 a gallon at the time. :(
BTW, your property is looking great!
   / Good morning!!!! #43,267
2016-03-04, 0244
11 degrees right now..high will be 37...not too bad.
   / Good morning!!!! #43,268
The smoke detector - which is an Ademco, and which requires a a magnet to test - may have a battery it ... but if so, we haven't replaced it, at least that I can recall (that would be "haven't replaced it for 15 years ...")
Most sensors that are wired back to a control panel get their power from the panel, so they don't need a battery. The magnet test was really only a marketing ploy that was possibly useful to installers to confirm they had fitted the detector in the right place. The magnet only triggers the electronics, it doesn't test that the chamber can detect smoke.
A good simple test is to trap a little smoke into a plastic bottle with the end cut off and hold it over the detector for ten seconds or so.
   / Good morning!!!! #43,269
Good morning all. We were told to expect snow today and the radio is saying it's arrived, although there is nothing here. The radar map shows it's all happening in a big swirl just to the north and I don't mind if the people there decide to be selfish and keep it.
For the last few days my wife has complained that the hot water isn't so hot. With grey skies most of the time, the solar panels will do no more than pre-heat the incoming cold water. The storage tank needs bringing up to temperature by the ground source heat pump, which is set to cut in at 5pm each day (by that time any contribution from the solar panels is over). I checked the pump was working in manual mode on Wednesday and it came on just fine, with all sensors giving sensible readings.
Late yesterday evening found that we were back to luke warm water again. It's next on the list to look at, once I've finished this cup of tea and fed the rest of the sheep. Last night I was thinking what it could be and realised it started playing up from about the beginning of March. It may just be coincidence, but makes me suspicious. The heat pump has some fancy software internally. I wonder if the manufactures tested that it correctly handles leap years ?
Thanks Drew, by the weekend our weather is coming from America. Your gas burn may be just enough to keep the frost away. ;)
   / Good morning!!!! #43,270
30 degrees this morning a light dusting of snow on the ground high of 45 later today major warm up coming. Eric I'll bet the soft ware missed leap year
   / Good morning!!!! #43,271
10F over cast mid 30's for high.
By the looks nasty winter mix well stay south of us :) weekend not all that bad.
Friday :cool2:
Enjoy the day all.
   / Good morning!!!! #43,272
37 degrees in rain ending shortly, cold windy nasty day out there.
Good day to stay inside and I need a break anyway.
Actually Eric I probably just burned a tiny hole in the atmosphere with my gas grill emissions...
I wonder when we will need catalytic converters on our gas grills?.........
I would really love to have a timer switch on the gas grill that automatically turns off the gas, but that would be seriously complicated I'm sure and likely
unsafe if not done exactly right. I need to replace the pull strings on my farm bell on the rear porch. One of the ropes swung over on the grill while it was on and melted, dropping down and neatly landing on the grill side, luckily not the top. I had a few little carbon chunkies left from the rope but they will clean off.
David/Sodamo, that deck looks wonderful and I like your patriotic colors! You have the ten million dollar view, might as well enjoy it.
   / Good morning!!!! #43,273
31 and the snow is ending...only an inch or two. Should get to 46 and melt.
   / Good morning!!!! #43,274
Yes, you are right, it got to midnight then didn't know what to do next.
   / Good morning!!!! #43,275
Never mind Drew, if you feel the need to save the planet, you could always resort to John Montagu's favorite food instead. They say the Earl invented it as a way to stay at the gambling table, although it's what we mostly eat outside.
   / Good morning!!!! #43,276
<snip>
Oh no.
So.............
<snip>
Reads like a very successful "burn in" testing the system. We used to require a "burn in" on our computers to test the system
   / Good morning!!!! #43,277
now you knew I'd have to look that up, The Earl of Sandwich...
and what I have most days though now I'm looking at all that bread with suspicion.
The modern sandwich is named after Lord Sandwich, but the exact circumstances of its invention and original use are still the subject of debate. A rumour in a contemporaneous travel book called Tour to London by Pierre-Jean Grosley formed the popular myth that bread and meat sustained Lord Sandwich at the gambling table.[21] Lord Sandwich was a very conversant gambler, the story goes, and he did not take the time to have a meal during his long hours playing at the card table. Consequently, he would ask his servants to bring him slices of meat between two slices of bread, a habit well known among his gambling friends. Other people, according to this account, began to order "the same as Sandwich!", and thus the "sandwich" was born.[22] The sober alternative to this account is provided by Sandwich's biographer N. A. M. Rodger, who suggests that Sandwich's commitments to the navy, to politics, and to the arts mean that the first sandwich was more likely to have been consumed at his work desk.
   / Good morning!!!! #43,278
29° and a couple inches of snow. Roads are clear.
My heat pump water heater has failed for the 2nd time.
   / Good morning!!!! #43,279
Poured first cup of coffee. 60° with mostly clear skies this morning. Heading to 87° with lots of sunshine. Another lazy day on the patio planned. Maybe a few miles on the bike before it gets too warm.
Good Morning All.
   / Good morning!!!! #43,280
Good morning! 44˚ clear skies. I looked over the horizon this morning and it looked like a big mirror was reflecting the sun at us, but it also looked like a fire. I took a zoom pic of it and still can't figure it out. Since there was no smoke and it was gone after 5 minutes when the sun moved fire as the source of the light has been eliminated.
JOHN DEERE 7230R TRACTOR (A60430)
JOHN DEERE 7230R...
KBH 25 TON TENDER (A56438)
KBH 25 TON TENDER...
Forklift (A56857)
Forklift (A56857)
2016 Cat TL1055D Telehandler (A56438)
2016 Cat TL1055D...
15200 (A56857)
15200 (A56857)
2019 Jeep Grand Cherokee SUV (A59231)
2019 Jeep Grand...
