Good morning!!!!
   / Good morning!!!! #213,641
67°F and .04 inches rain.
Nothing that great yesterday as it started out wet. Did get the storage carrier for Sophie’s EGO assembled and started on rehabbing the old wheeled sprayer. Goal is to have the sprayer mounted on the EGO mower. Just might give up football and try to get that done.
A nice visit in afternoon from Michigan friends.
Prayers for all
Be safe
Have a great tractor day
   / Good morning!!!! #213,642
Good afternoon, I am a little late today. Low 41 going to 46°F. Wind WSW 11 mph. A mix of sun and cloud.
Went to bed last night at 11, got up at 3, stayed up till 7 then went back to bed and got up again at 10. Forgot all about posting in the morning.
I've got 7 clocks in the cave, three are right twice a day, my alarm clock, wrist watch and the clocks on both my phone and the PC.
I was going to send the Chelsea Ships Bell clock down to Boston to get repaired, but with the current situation I think it will be staying right here at home.
I am conserving energy in preparation for the North Bay trip tomorrow.
After the trip I will fish out the block heater cord that is hiding under the hood of the Dodge and set up the remote control for that.
That will be the very end of my winter prep.
Have a safe day all
   / Good morning!!!! #213,643
Do you have an idea of how thick the water bearing sandstone is at your location?
Somewhat.
Neighbor's recently drilled well hit a mix of sandstone and shale @ 60' all the way down to the bottom of the well @ 160'.
The texture was described as "hard" (bedrock) on the drilling report.
The strata in the wells drilled on the adjacent road coming to our home are either shale or sandstone ... or a mix of both like above.
Earliest wells on that road were drilled in the early 1950's.
Total depth of wells ranges from 50' to 160', with static water levels supposedly ranging from 12' to 85'.
I say "supposedly" because sometimes the entries in the ODNR database are incorrect. One of neighbor's well was listed as having a static water level of 175' ... an impossibility since the well is only 54' deep, total depth.
Pull up the actual drilling report on that one and the static water level is listed as 17' ... :rolleyes:
Interestingly that 160' well above was drilled in 1956 ... clay, sand and gravel to 20', then shale 20' to 40', then sandstone (with streaks of shale) 40' to 120', then shale from 120' to 160'. One hour test was run @ 10 gpm with no draw down, static water level @ 20'.
That property is due west of us (800' ?), but slightly north (probably less than 50' to 75')
I'm just asking because my back of the envelope for a 5" well is that it would add less than a gallon of storage volume for every three feet deeper it gets drilled.
A 5" bore (diameter) will hold slightly over a gallon per foot. 1.02 gallons to be exact.
So it would have to quite a bit deeper to add much in the way of storage capacity.
(But deeper might certainly bump up the flow)
Yes ... particularly if it hits additional fractures in the rock.
My mental map for your area is lots of rainfall, and surface water, but I guess that doesn't say much about the aquifer, which just goes to show how bad my mental maps can be.
Yeah ... we typically have pretty significant rainfall ... at least when we are not suffering under drought conditions.
ODNR has a snot load of info on Ohio's strata, hydrology and groundwater on their website. One example:
Groundwater Vulnerability Map of Ohio
Another (huge pdf):
Hydrogeologic Settings of Ohio
Are you and your neighbors all on sewer, or is it septic and the water is returned to the soil (and perhaps the aquifer)?
Pretty much all on septic, city/county has started to put in sewer and connect it to an adjacent city's wastewater treatment plant via a trunk line ... but that's mainly along a main road corridor for commercial development.
No plans for widespread residential sewer at this point, other than maybe those along the above route.
Similar thing with city water. They have entered into an agreement with a company to provide "city water" along that commercial corridor.
Cost is fairly significant but probably slightly cheaper than having a new well drilled:
Tie in is voluntary.
Not really an option for us as we are well off the route.
   / Good morning!!!! #213,644
51F and cloudy @ 13:30, calling for a high of around 53F with light and variable winds.
Got up to the shop yesterday and fired up the double barrel stove.
Collected up most of the steel for friend's project and started cutting those to length.
Still short some angle ... but there might be a piece sitting outside that can be used, will have to look.
Then started tacking up pieces:
Gave up and called it quits when I tacked a couple of pieces of 1" square tube in the wrong orientation ... 🤬
Sometimes ya just got to walk away for a bit ... :LOL:
Did get the shop warmed up to around 77F ... will be interesting to see how much it cooled off overnight.
Came back down to the house and ate and then got a little more work done on plumbing and insulating in the basement.
Knocked off around 23:30 and came up and caught the tail end of Game 7.
Slept for close to 12 hours.
Going to grab a shower and then head back up to the shop and see if I can't get this little project finished up.
Hope everyone is having a decent Sunday ... (y)
   / Good morning!!!! #213,645
Got about an hour sleep, didn't make it to morning service. But was on the phone with my son in TN taking care of stuff. So far "Visible by verizon" has sucked at the house, either 1 bar or sos mode.
wife complaining about lady bugs trying to get in now..
   / Good morning!!!! #213,647
39F clear sky.
Been good day for outside,leave control finally caught up :) front field leaves chop blown into woods,quick run for critter food,game cams relocated,rider mower got bubble bath now in hibernation.
Plans for the evening....catch ending of NASCAR,share bowl ice cream with blueberry pie :) hold down recliner till pillow time.
Enjoy your evening all.
Muzzleloader hunter got little trigger happy before shooting time allow,guessing hunter sights were on this fellow and miss,saw buck at 330pm heading for the apple trees.
   / Good morning!!!! #213,648
Good (Monday) morning. Overnight Low of 14C and it's presently 20.4C, mostly cloudy & calm. Rain is predicted later on.
The 'Mad Agisting Horse Woman' + Daughter's horses returned yesterday arvo. Plus, the last ton of firewood was delivered... so, I've got to 'gird my loins' and start stacking.
Except I've got an 'in house' visit by a pharmacist to revue all of my medication. That's scheduled for 1115.
   / Good morning!!!! #213,650
you have 35 degree cold soak on that steel, have fun.
Just needed to get it dry enough to lightly sand for final coat! :D
many a squiggly paint job for me when I painted on surfaces too cold.
Then I got an IR temp gun and stop doing that.
I brushed the primer and first coats, because I was working piecemeal as I was welding mod's and working rusty areas with the needle scaler or wire brush, but decided to spray the last coat.
I'm figuring around 2pm today in full sun will be perfect for you.
I was targeting noon, since it was supposed to be nearing 60F by then, but ended up shooting from about 1:15 - 2:30 pm. So, pretty close to your figuring!
somewhat perplexing that my prior post was held for moderator approval.
does squiggly mean something bad??
You kiss your mother with that mouth?!? 😲
@daugen I've seen some higher performance electric boats coming in from overseas, but personally, I have some concerns about the battery quality, and I'm pretty sure that I don't want to be too far from shore if a lithium battery short circuits.
I can't imagine they're going to be less reliable than some of the older single-engine boats I grew up on. It's not like gasoline marine engines are all that reliable, in that harsh environment.
2008 Ford F-150 Ext. Cab Pickup Truck (A56858)
2008 Ford F-150...
VALMAR AIRFLO 8600 PULL TYPE FERTILIZER SPREADER (A58375)
VALMAR AIRFLO 8600...
2018 Chevrolet Equinox AWD SUV (A56859)
2018 Chevrolet...
2021 Ford F-150XL (A57148)
2021 Ford F-150XL...
New/Unused Agrotk Wood Splitter (A57453)
New/Unused Agrotk...
2020 ISUZU NQR BOX TRUCK (A58214)
2020 ISUZU NQR BOX...
