scott_vt
Super Member
- Joined
- Oct 5, 2004
- Messages
- 7,719
- Location
- east wells,vt
- Tractor
- 1986 MF 1040, 1942 Farmall A, 1949 Farmall Super A
Good Afternoon Ken,
Prayers to your family !
I have a guy coming out on Monday to chip out all the ice, and then I was going to install the cables they have at Home Depot. I think you were saying that those cables don’t work if you have the leaf guard on, but would they work OK with no leaf guard?If it's the ice in the gutters you are worried about, good luck.
Gutter leaf guards will make it even worse.
I just had gutters put on about 1/3 of the house last year, I was worried about ice buildup in the gutters causing issues. According to the salesmen it wouldn't be an issue, I didn't believe him then and I now know he was lying through his a**. I had them install roof deicing cables on the roof and in the gutter. They used standard roof cables such as you can get at Home Depot or Lowes. They did not run them so they function worth a damn. They zig zap the roof one as per all the drawings but it does not reach down to the gutter guards, they also ran one down the gutters and down spouts. This does not work the roof cables will clear the roof in the V pattern which drips down into the snow on top of the leaf guards and while some gets down into the gutter it all ices up and fills up excepting for a tiny channel in the gutter.
I have used considerable ice melt to much of it out a couple of times.
I'm not sure what the best and most effective cost method to clear this out is going to be.
I am thinking at this time the "industrial" self regulating heat trace cableing run in loops in the gutter so the ice can be melted with channels reaching the bottom of the leaf guards and the bottom of the gutter and the inverted V runs on the roof brought down to and on top of the leaf guards to make a system that has channels completely through the ice buildup.
Also I am going to install some smart switches to control the cables remotely.
Glad your wife is doing better ! Lobster roll sounds good and I betWife is doing a little better and is able to do some cooking. She made an amazing lobster roll with some crunch in it
If you can get the bottom of the V's down in the gutter but still have room for the lower gutter run you'll likely be good. The only issue is that those cables can not touch or make contact with the other run.I have a guy coming out on Monday to chip out all the ice, and then I was going to install the cables they have at Home Depot. I think you were saying that those cables don’t work if you have the leaf guard on, but would they work OK with no leaf guard?
