Good morning!!!!
   / Good morning!!!! #196,611
Della finally hit 50 lbs
Wow Della is getting BIG! As they grow up it is sad to lose a puppy but nice they start learning commands and behavior.
45F going to 85F here in California. Today I am going to split some firewood for this winter's supply.
Everyone have a great day !!!
   / Good morning!!!! #196,612
Scott, I get my starter blocks from the Dollar store, but I also have wax blocks I make myself with egg cartons. We will both be going into the dollar store at the end of the month and cleaning them out of fire starter. A package of 15 for $1.25 is easy to take.
   / Good morning!!!! #196,613
and here is Eastern Nevada and I'm going to spend four hours driving West on 80 to the very edge of the state.
Drew, a couple of things of interest on your journey West.
As you get around the Fallon / Fernley areas, you'll probably find the semis doing at least 75mph, often 80.
When you see the "Mustang" exit from I-80, that is the exit to the "world famous" Mustang Ranch brothel. Lots of history there, ahem. Joe Conforte, founder of Mustang Ranch, originally 3 purchased tracts of land-- right where the County boundaries came together. He put trailers on there and operated a brothel, at least until the County Sheriff got to the point of trying to shut him down. If it got to that, he simply moved the trailers across the boundary and into the other County. Problem solved. County Sheriff couldn't do anything since he was no longer in that County. Plus the Sheriff's problem was "solved."
Many years later he was eventually prosecuted for tax evasion and the Federal Government seized Mustang Ranch but kept it operating. So the Feds were serving liquor and operating a brothel. Somehow they ran it into the ground and it was losing money by the time they sold it off.
Also, in this same area, South of I-80, is the largest industrial center in the world. The Tahoe/Reno Industrial Park. Much of it cannot be seen from I-80, but it is massive. Tesla has a gigafactory there. Amazon, Google and all the other big hitters have set up large operations there. It is fueling a lot of growth in Northern Nevada.
Finally, make sure all the nuts on the RV are tight. Much of I-80 over Donner Summit was recently resurfaced. For some reason, all they did this time is saw cut strips of concrete where the tires make contact with the freeway. Then pour long "strips" of concrete going miles and miles and miles. Except the strips don't match up too well with the original concrete so there is some jostling around as you drive.
   / Good morning!!!! #196,614
Scott, 8200 miles at 10 mpg @3.50 gallon, all figured out ahead.
This is my version of taking a cruise...
Suburban propane furnace clean as could be, despite all the original construction dust and bits, which I vacuumed up. Cleaned the outside filter and put it back together. There's only an exhaust outside I think and I have screens over them. Going to fire up the furnace again and see how stinky it is. I took flashlight and peered inside the cabinets and it all looked ok.
   / Good morning!!!! #196,615
Drew, I'm griping because our small town's gas stations have kept regular at $2.99/gal, where as 25 minutes away it is going as low as $2.47/gal.
This tells me the stations are collaborating to keep prices high. They used to compete and prices were competitive.
Last night's football game was lost in the first quarter with 4 fumbles that the opponent capitalized and scored afterwards....
Scotty, I was hoping the mill's clutch would be an easy to get to and adjust thing. If I have to remove the table, this project will get done by hand feeding the axis for now and work on the table later.
TxDon, is that screw in your shoulder metric or standard? Glad it is working out. Don't over do it.
It is getting dry around here and the fields will turn brown if they don't get a splash of rain soon. It has been a rare summer to have green fields until now.
I hope all have a blessed day.
   / Good morning!!!! #196,616
thanks Plowhog.
looks like I'm driving through the Great Basin today
and I watch my side mirror for traffic from the rear and it's always two hands on the wheel when the semis go past, particularly if I can tell their overtaking speed is fast. They push a big wall of air.
   / Good morning!!!! #196,617
Good morning
From a dew-covered hay field
Endless hay mowing....
Listening to a little Allman Brothers
   / Good morning!!!! #196,618
I did the annual chimney sweep yesterday, for the wood stove. I got a bit dirty, but it was needed. I do it every Sept. Firewood has been split and stacked since July.
   / Good morning!!!! #196,619
Kyle, I'm looking forward to less expensive gasoline, my best so far is 2.80
I only do name brands, though out here there are some different chains; I figure most truck stop gas is fresh. I usually need to take the right end pump with the fillup back by the rear axle.
happy to report heater/furnace seems to be ok, raised the temp but not as fast as my electric heater, likely because it has outlets all over. Little bit of smell, but much better, and thankfully a hint of the citrus cleaner I used liberally on the intake cover.
I need to save propane for fridge while driving and hot water heater. Until I get the transfer switch replaced I'm not running the electric hot water heater. that's what pushed me over the resistance edge last time.
Normally I would always use campground electric if I could.
this campground filled up and appears full, took a short walk, cool morning but should be a nice day to drive. Not in a big rush, at least I'm already in the Pacific time zone.
now what exit is the Mustang Ranch? :rolleyes:
something I've never done.
pretty disease phobic so very unlikely...
   / Good morning!!!! #196,620
Morning all, 70 going to 85 and the sun is up.
Today is our anniversary, snuck out earlier and got some flowers/plants.
Yesterday just did pool and yard maintenance.
Watched what will be the last Grand Tour on Prime. They were in Zimbabwe , which was one of my favorite trips, even if a hippo did attack us while canoeing the Zambezi.
Today might take a last dip in the pool. Will probably close it soon as it is filling with leaves.
Drew - if you want fancy high priced market in California try reEwhon market , Like Whole foods on steroids. I had a few of their pre-made sandwiches and they were really good.
Be well,
VERMEER D9X13 SERIES II HORIZONTAL DRILL (A52707)
VERMEER D9X13...
2011 Toyota Corolla Sedan (A53117)
2011 Toyota...
2017 Ford Taurus AWD Sedan (A55853)
2017 Ford Taurus...
2004 MACK CV713 MIXER TRUCK (A55745)
2004 MACK CV713...
43030 (A51691)
43030 (A51691)
New Holland T2420 (A53317)
New Holland T2420...
