Good morning!!!!
   / Good morning!!!! #194,881
K series Kohlers are good engines. Today's gasoline isn't good for sitting in carburetors. If the deck and rest of the mower is decent, I'd rebuild it.
I have a K engine I've been on the fence about rebuilding, but not sure if the welder it supports is worth it.
I just got a Craftsman M100 mower running. Cousin's husband gave it to me. Crankcase was waaay too full of oil, maybe some bad gas in it, it did not smell bad. Anyway the carburetor is about 98% plastic, no adjustments, just a small bubble to depress 3 times to start it. Drained and changed the oil, put some good ole Castrol GTX 20-50 in it. Started on the 4th pull and burned out the old oil that was in the cylinder and exhaust port. Stopped smoking after a minute or 2 and good to go.
Glad you got rain, and safe travels.
Happy Anniversary you 2 !!! I hope for many more.
Thanks for sharing.
My hair got real shaggy if I tried to grow it past my neck. Sticking out from under my motorcycle helmet, it would curl up and get split ends...
Now, I actually have a true "red neck" from mowing this afternoon.
Bill, sorry about y'all's kitty. hope the trike works out for you, don't forget to put clothes on when you go to town.
I just made tuna fish salad with boiled eggs.....Everyone is about to kill me for smelling up the house. It sure smells bad, but tastes great. I put sweet relish instead of dill pickles. I like sweet and dill relish, just happened to have the sweet in the fridge.
Almost too hot to do anything. I'm having to watch myself from over heating. Fixing the push mower got me hot. Just not enough breeze flowing through the barn. Heat index getting up to 106F and higher. Temp is 98F
My 1/2 ton SUV was pulsing as you come to a stop. Not pulsing in the pedal, or the steering, but just in the seat of the pants while coming to a stop. My experience is that it is usually the front rotors, so I ordered new drilled and slotted front rotors and pads and installed them. Sounds easy, but the heat was brutal. Had my son helping. Took a trip to Canyon Lake and quickly found out the front rotors did NOT fix it. Also found out that even after coming to a stop, when you took off, you could feel the pulsing slightly while accelerating. Ordered new rear drilled and slotted rotors, and caliper rebuild seal kits for the back. Jacked up the whole vehicle. Took off the front wheels again, this time to sand the faces of where the rotor and wheel bearing mate (Just to make sure the front rotors were running true). Then pulled off the rear wheels and took off the calipers and rotors. Rebuilt the rear calipers. Caliper rebuild was straight forward, the old seals get hot and old and they become almost brittle, not supple. So the pistons can stick. 120psi air from my rubber tipped blow gun shot them out. Pistons are phenolic. Did I mention it was hot and humid??? Oh and the mosquitos....( I believe mosquitoes were stowaways on the Arc). I went ahead and used my really old cheapy vacuum hand pump to pull about a cup of old brake fluid thru each side while I'm in there... Emergency brake shoes looked good. I even put new Jounce Bump Stops in the rear above the axle. Put everything back together and bled the rears and took it for a drive to break in the new pads and rotors. Multiple times braking from about 55 to 15mph. At least 15 or so times. Brakes are working great and NO PULSING!!! I'm calling that a win. Parts were about $300. I told my wife that a shop would have charged us at least $1200. It took me about 6-8 hours total at my slow heat reduced pace. Even with my Milwaukee impact and ratchet.
rear emergency brake shoes
Front rotors, I remembered they are directional, and had to change sides after this pic.
Rear rotors, with anything I could find to temporarily attach 2 wheel nuts so I could bleed and test them prior to putting on the wheels.
You can just barely see the new white bump stop in the back ground. Old bump stops were rotten and just turned to powder if you squeezed them.
Don, I know scorpions can fit through a credit card sized crack. After checking the normal places outside around the house last night with my black light, my wife saw a baby running across the kitchen floor. Arghh.
GREAT PICS Y'all! Thanks for sharing.
Ken, I have a professor friend teaching engineering at SUNY college. It is supposedly a good college. (But we all know the one I work at is the best!) If they are going to pay off student loans, I'm quitting and going back into the classroom.
Prayers for our team, our nation, Ukraine and ******. Peace in the world. Times are looking bad around the world. Problems that go back hundreds, and some that go back millenniums.
Kyle,
Most of my emergency projects always show up what seems to be the hottest days of the year. Last major in August was front axle bearings on youngest son’s half ton Chevy pu. Never done that project before and what should have been a half day took all day due to the heat. Left side was bad, figured right wasn’t far behind so did that as well. Along with new stabilizer bushings. Two weeks later his fuel pump started leaking. Removed the bed (easier than dropping full tank of gas), and swapped the pump out ( fitting on pump rotted out). Two days later he stumbled upon a newer (2018)crew cab and traded in the one (2011)just repaired! I could skinned him.
   / Good morning!!!! #194,882
That Kenworth is a 1965/66? Not sure on the Pete in the background. The pickup looks like a '52 Ford.
I had one that ran good, I got it for $100.oo, drove it home with no plates or Insurance and parked it in from of the barn (I wasn't living here then) for a week and a guy in a 'Vette came along and offered me $500.oo for it. By, by Ford. 500% profit in one week. I can handle that.
Junior is across the street at the neighbours' having his birthday supper. He is 57 today.
Sign in windshield said KW was a 79’. Ford was a 51’ with a flathead V8.
   / Good morning!!!! #194,883
Kyle,
Ain't that how just how it goes sometimes?
   / Good morning!!!! #194,884
I almost forgot, I haven't ever shot a Winchester 94/22, but I have shot at least 2 Browning BL-22's which I see are going for over $800 now.
The little Brownings are sweet, but I did see one fire w/o being fully closed/locked. It shot, and blasted gun powder and debris into the person's eyes. She did not fully cock it closed prior to pulling the trigger. This is on an older one (buddy's grandfather's gun), so no telling how old it is. I see they were first made in 1969, and I would guess in that era.
Work is crazy busy, preparing for the fall semester starting on the 19th. One week from tomorrow.
   / Good morning!!!! #194,885
I'm glad Debbie did not do y'all in a bad way. We are getting dry after having a wet July.
Personally I was disappointed. Was expecting a good bit of these
   / Good morning!!!! #194,886
Happy Birthday to your son L4N sorry about the kitty the rainbow bridge is very real they are waiting to greet us again.
Grass mowed in for the night sorry about the heat Kyle.
Nice car show pictures gentlemen
   / Good morning!!!! #194,887
Good evening all. Made coffee to start, Chapel set up, attend chapel, and tear down chapel, breakfast with group, leaf removal front front porch, putter on computer till lunch then nap after lunch, watch some recorded news, dinner, then started working on posting.
Resuming posts Wednesday 2:50:pM CDT post 194,651 :
David good luck with insurance inspection.
David good story on rookie backhoe experience.
Frits glad you got rain. Sorry wife has cataracts. Sounds like gearbox change complete. Thanks for excavator info.
Ken thanks for insurance info feedback.
Drew glad niece ok.
Paul thanks for operator info.
Bill thanks for operator feedback.
Randy(wag) glad you have a light day not planned.
Thomas glad Mrs gave you thumbs up for grilling.
Ted glad you got snake relocated.
Ted my wife was same way. When Dr planning medication she would ask for half normal dose. That was a much better stating point.
Ted why push when hot outside? Glad irrigation done.
Thursday morning 1:43 CDT AM CDT:
David neat story, George knew his business.
David I had to come home to rest and recover :)
David good to hear great report on Sophie's eye.
Drew glad nice cool morning. Hope you get visitor prep done. Hope car show can go on. Hope you find sturdier glasses you like.
Ron good to hear foot ok, hope grocery shopping went well. Hope friend's RV sell quick.
NHBX glad you got some rain. Nice you got some outside puttering done. Hope mowing went well.
Billy sorry about MIL no room, no transport situation. Dog mix breeds 12 pound to about 150 pound. Not good with breed identification. Glad good hike on your trail.
Thomas hope your Thursday went well.
Phill glad good progress on apartment. Hope refurb on vanity goes well. Hope you got your agenda done.
Buppies sounds like your drought will be eased. Prayers sent.
Frits glad you have gotten rain and more on the way. Hope neighbor overflow not tearing up driveway
Paul nice spacers. Hope house ready for foaming and countertops and tile picked out. Thanks for pics
Scott(vt) glad you did not get soaked. Hope you are happy with the results so far. Tough decision on Wheel Horse. Nice pics
Bill hope new ride works out. Hope not much to setup.
Plowhog hope Rigby training went well. Old house are such a Pandora's box. Sorry about the lack of proper standards in the wiring.
Dennis sorry about the rebuild experience. Glad you are getting rain.
Drew never lived in a house with glass fuses. No glass fuses in any building. Sorry Lake Drew may not get filled.
Don glad you didn't miss appointment. Sorry you missed your work window. Pool plenty warm.
Ken sorry pool is already full and will need more salt. Sorry case worker no show. Hope bicycle touring went well. great pics.
Lou thanks for information on control layout.
Frits adapting the backhoe to three point attachment sounds like a fun project.
Ted hope you got rain. Hope Costco and Lowe's trip went well.
Drew hope dinner worked out with foodie friends. Sorry you can't mow.
RNG Glad you got insurance squared away. Hope dentist ans Dr better than the recommendation.
Drew hope you can see Bird.
Buppies glad you are getting good rain.
David hope Sophie's eye exam and pressure check was good and guys did well at H&F
Dennis hope water flaw not problem at lot. Hope you got to pick up water softener.
Bill hope you got the trike on Friday.
RS plenty of humidity. Sounds like work continues. Glad you got a good milk shake.
Bill sorry no perks. Hope you can use spring seat post.
Buppies that is a lot of grass to mow, especially if it gets too tall.
Bill from what I hear hard liquor not as bad as beer for diabetics.
David probably they are not sure how to pull that off either. Looks like a neat trip.
Drew interesting some many Irish trips. Glad enough accomplished for the day.
Dennis yes, most people I know would have gone straight back. Hope you get is fixed.
Dennis glad new softener was easy install.
Dennis nice pics
Randy(wag) glad good retired day for you :)
Engineer 2 tractor shows, nice! Hope you got good pics.
Don glad you are making use of pool. Busy day transplanting two fig trees and making lemon cookies.
Ted Gas Buddy even has the member only prices at Sam's Club and Costco.
Friday morning 3:32 AN CDT post:
Ron glad shopping went well. Hope PT went well and you are close to having RV ready to sell. Nice pic
Bill hope trike arrived.
Drew sounds like you have a good system. Plenty of rain fallen. Sorry about slow internet.
NHBX Hope Debbie doesn't dump too much rain.
Drew I was on road Friday after feeding dogs. Glad worst of storm missed you. Hope you were able to enjoy car show.
Thomas hope you had some inside puttering to do.
Billy hope no damage from storm. Glad Della like rain now.
Buppies good to hear pond full and fish happy.
Drew looks like Union Pacific has north south railroad, Southern Pacific had a east west line, east half may be in use by a short line railroad.
Bill have to wonder why someone would keep gators in his basement.
Drew that would be rude shock start a 10 stay and now 6 months. Hope you got home before the heavy rain.
Frits sorry about tornado watch. Glad neighbor pond not overflowing on driveway. Glad you didn't get hit by branch.
Paul glad floor covering and countertops picked out. Hope trip to Philly was was good.
Frits glad pond didn't overflow on your driveway.
Buppies glad pond water not muddy.
Scott(vt) hope storm prep went well.
prayer for all, especially Jay/Peg, Kyle /Daughter, /mom's breathing, /son's migraines, Bird /aging issues, Ron /heart, Billy /mom hypertension & congestive heart failure, David(moss) /remodel, /divorce, Buppies /cancer, parathyroid,blood sugar /wife healing, Thomas /gout, Phil /reflux, Frits /veteran son with mental issues, /granddaughter with Evans Syndrome, Ken /dad possible dementia, /chronic fatigue, Diet not working, Steppenwolfe /son-auto immune disorder, Grev /wife's eye, Ted /knee recovery, /retirement & disability red tape, /family issues, Lou /eye issues, /heart issues, /wife hip replacement, Doug and wife/health issues, / hand nerve and surgery, /fall and recovery, / wife headaches and heart eval, / David(sadamo)/Sophie's hip or leg pain, Scaredy/shoulder dislocation, /marriage dissolving, / friend stop drinking, Dennis /retirement, /neighbor issues, /land development, /favorable winds not in the forecast there, /dad surgery recovery, Drew /back operation issues, /friend's wife cancer diagnosis and recovery, Scotty /back pain, Helogabals /wife's friend situation, Fatjay /father broken hip, ******, Ukraine war, and Country.
   / Good morning!!!! #194,888
Good (Monday) morning. Overnight Low of 3.4C and it's presently 18.7C, clear & calm.
Lovely day, yesterday. The 'Mad Agisting Horse Woman' came by in the late arvo and reported that the possum was still 'nesting' at the front of her lucerne & was barely responsive. I called a Mate of mine who has a .22 rifle & he came over to dispatch it.
Compared to a N.A. Opossum, an Aussie Possum is, almost, "too cute to shoot".
Nothing 'pressing' on for this week... just tootlin' along.
Edit: Oooh, bugger... it looks like I wrote but neglected to post this entry until now (4 hours have passed) and it's now the late arvo. Better late than never.
   / Good morning!!!! #194,889
Good morning,
61° now highs around 75° and mostly sunny AM, clouds and maybe a shower by evening. Winds W 5-10 mph, dew points staying in the mid 50’s again today.
Yesterdays mowing went slowly, noticed some low hanging branches around and decided to trim a few before getting started, three fork loads added to brush pile. Did get about half the mowing done, just so much easier when you aren’t getting slapped in the face with branches lol. The Mrs called a time out around 3:30 so took a quick shower and relaxed with some wine and waited for supper. Spaghetti with meat sauce and a few cherry tomatoes tossed in for good measure.
Plans for today, finish mowing, trimming and maybe start cleaning up the garden a bit. That should do for today.
Enjoy your day everyone
Stay safe and healthy
   / Good morning!!!! #194,890
Poured cup of hot coffee. 75° with clear skies this morning. Heading to 79° with mostly sunny skies. Got JD mower maintainace completed. Then spent rest of they day conserving energy. Today I need to do some house cleaning.
Starting from bottom of suet cake.
Everyone stay safe and well.
Good Morning All.
1993 Generac Olympian 93A 100kVA Towable Diesel Generator (A56857)
1993 Generac...
CASE CX160 (A55272)
CASE CX160 (A55272)
(INOP) CHEVROLET C-50 GRAIN TRUCK (A52708)
(INOP) CHEVROLET...
OMEGA 20 TON CRANE (A58214)
OMEGA 20 TON CRANE...
2018 ARIENS RIDING MOWER (A56859)
2018 ARIENS RIDING...
Club Car Utility Cart (A55851)
Club Car Utility...
