Good morning!!!!
   / Good morning!!!! #192,851
I always look inside the Weber before I turn it on.
never know what has taken up residence.
induction burners sound like a great safety idea Ron
this morning going to run gen and a/c in rv and see if I can smell the
hot wires smell I got before. Will have gen compartment open with IR heat gun used.
am concerned with connectors and ends. AC draws 7 amps, should not be
making smells. Where there is smell, there is smoke preparing to arrive...
also going to check under the bed where the main AC panel and converter is.
gen oil all changed and unit cleaned up, putting up a stink is not allowed.
And the smell of hot wires is pretty distinctive; not a pleasant smell to an old fireman.
   / Good morning!!!! #192,852
Don and other Texans, prepare for a lot of rain, that storm is headed your way Monday and Tuesday.
   / Good morning!!!! #192,853
Lots of bangs around last night, but didn’t see any for the trees.
Son’s cat very skittish around strangers, yet curious enough to check us out. I got to pet her last night. She won’t come downstairs, will lay at top of stairs and watch us, then zoom into his room if we get too close.
Supposed to be 98° today.
   / Good morning!!!! #192,854
Daugen fyi my generator has a precaution to keep the door shut and unit sealed otherwise it can overheat
   / Good morning!!!! #192,856
Good Morning
It’s 75° with 98% humidity. High over 90 forecast. Overcast now, might gets breaks of sun later, and then good chance of thunderstorms.
We had a line pass of weather through last night, left us about 5/8” of rain, but that was after we had already retired for the night.
I made some more progress on the plumbing, got the 3/4” hot and cold supplies run from the boiler room to where they will branch out to all 1/2” home runs to fixtures and appliances.
Pretty sure that I got all the studs drilled for the 1/2” runs, but it’s entirely possible that I missed a few. We will know when I go to run the lines, probably today.
Ordered some more material from SupplyHouse.com, they have been a great resource and the order arrives the next business day with free shipping.
Spent some time at the pool in the shade, taking it easy.
   / Good morning!!!! #192,857
Morning all, 77 going to 94 and overcast.
Got some needed rain last night.
Got some pool time while the sun was still out.
Today head into Manhattan to pick up son.
Did see, and certainly heard lots of fireworks last night.
Just did a small fountain and a few sparklers.
Be well,
First figs, in a month earlier than last year.
   / Good morning!!!! #192,858
good morning, 77 going to 84 today
The neighbors pole building contractor worked yesterday and the pictures show progress after one day of work.
   / Good morning!!!! #192,860
Good Morning,
Vt, 67 to start going to 84 with high humidity!
Drew, I am the same way ! The Fire may have not started yet but there is extreme possibility that it will !
Well I ended up cutting up that maple on the north side of the property so no work got done on the saw horses !
We took everyone out on the pontoon boat yesterday , all 10 of us. We bought one of those floating mats and tied it off to the boat, the kids had a ball on that thing !
No big plans for today yet but with the heat I’m thinking water related !
Hope all have a blessed Friday! 🙏
EZ-GO Freedom TXT Electric Golf Cart (A57149)
EZ-GO Freedom TXT...
NEW HOLLAND TS115A TRACTOR (A58375)
NEW HOLLAND TS115A...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
EVERETT METAL CUTOFF SAW (A58376)
EVERETT METAL...
2024 RAM 3500 CAB & CHASSIS (A59575)
2024 RAM 3500 CAB...
(4) TOYO M/T OPEN COUNTRY TIRES (A58376)
(4) TOYO M/T OPEN...
