Good morning!!!!
   / Good morning!!!! #191,151
But trying to get stuff done with most of the proper tools not here is getting old.
And buying a second set of tools is getting REAL expensive.
I've been split between 2 houses, one in Virginia, one in Mississippi since 2010. Spending one to 3 months, then go to the other.
For a while duplicates (hand tools, small power tools, lawnmowers, weedeaters etc.) were not too bad, and often solved by judicious splurging on sales. For instance the local Lowes was clearing out some Kobalt "household" tool sets. They had sets "retail" over $100, for $10. I bought about 7. Gave one to each child. Still have one unopened.
But now with the increase in prices and needing a duplicate cordless leaf blower I spent ~$300 for a DeWalt "flexvolt" leaf blower for use in Mississippi because my son has to use my previous model (that cost ~$100) in Virginia.
Still better than toting it back and forth.
IF I get to "retire" someplace I'll sure have a lot of duplicate tools.
/edit - and one of the problems I have is that I lived a long time using the MacGyver method of making do with whatever tools were handy.
Now I find it frustrating to not have the proper tool I own, but it's 900 miles away.
I just had to take off a hydraulic hose in a tight space. I needed a short 23mm wrench to have a "full" turn. I'm in Mississippi. I know where it is in Virginia. I ended up using my "long" 23mm, about 1/8 turn at a time.
   / Good morning!!!! #191,154
One can never have enough tools
That is the philosophy that I live by. My wife has slowly (50 years in August) come to terms with it.
She wanted a significant amount of pasture fence work done, I told her that I wasn’t going to do it with the 3PT auger, it lacks down pressure for our shale infested soil, and is tough on my back to twist around to see it.
I said that for what a hydraulic auger for the front end loader would cost, we could hire someone to do the fence posts and gates. Her reply was “but then you wouldn’t have an auger”.
That’s why it will be 50 years.
   / Good morning!!!! #191,155
Good morning, the low is 48 and the high going to 75°F. Wind WSW 3 mph. Sunny!
With a 3 mph wind I am glad I got the grass all cut yesterday. The bugs will be bad today if I had left it.
A dump/town run is in the cards for today.
Have a safe day all
   / Good morning!!!! #191,156
Smart girl, you can't have too many toys er tools.;)
   / Good morning!!!! #191,157
Good Morning!!!! 50F @ 5:00AM back in Orcutt, CA. Mostly cloudy early, then sunshine for the afternoon. High 68F. Winds WSW at 10 to 15 mph.
I do wear my cartridge respirator and gloves out of habit…
Me, too. I also changed out the spray nozzles on the spray bar so the droplets are bigger and don't drift in the air.
Hope the move goes smoothly, Don. Anything would be smoother than mine...
Easy trip yesterday. Really surprised how much difference in mileage the small trailer made. I was seeing almost 19 MPG on the first tank of gas with the small trailer yesterday, and still had 250 miles of range showing on my arrival. The box trailer averaged 12-14 MPG, and I'd have to stop twice for gas.
At the first gas stop I got a couple estimates for shipping the old motorcycle engine. I was pretty shocked at the $360-$460 prices. I was even more shocked when the shipper left voice mail that the shipper he contacted added a hundred for a "fuel service fee", and another hundred dollars for residential pickup. And that he was unwilling to drive the thirty minutes to drop it off at a freight terminal of the shipper. I'll have a go today to see if I can find a better way, but at this point it could easily turn out that the shipping costs more than the parts are worth.
Took several tries to back the trailer into the side yard, but with the help of a friend we got it done. Fortunately the neighbor's driveway directly across the street aligned perfectly with the two concrete wheel tracks in the front yard that lead up to the gate into the side yard where the trailer will be parked. And the ramps made from pieces of 2x8 held the weight of the van with no issues. Just took a little fiddling to get everything lined up. But we did end up unhitching the trailer, putting the wheel back on the jack, and then armstronging it to the parking spot. The whole side yard is concrete, a very nice upgrade from the gravel I'm used to. And there's still plenty of room left for either the van or car.
Unloading and a bit of unpacking today, and going through the stack of accumulated mail.
TGIF gang!
   / Good morning!!!! #191,158
M7040
Man that spring for the idler is very strong but used a ratcheting load strap to pull the idler arm enough to get slack to get the belt off.
I cut the spring hook off deck. Then made a bracket and adjusting screw to adjust spring tension like OEM.
   / Good morning!!!! #191,159
M7040
nice work
   / Good morning!!!! #191,160
Good Morning,
Vt, 42 to start going to 71 ! Another beautiful and sunny day !
Went down to the marina yesterday afternoon and fixed two broken items on the pontoon boat. The front door latch was broken and replaced that and the floor mount for the table in the bow had loosened up so o rotated it a few degrees and reinstalled the screws! Seems to be good to go now ! We were going to go out for a ride but it was really windy with white caps out on the lake so we just sat on the boat and had a glass of wine together!
Cool this morning so I’m thinking of getting the tractor out of the barn and mow part of the property with the bush hog ! Will try not to take out the power today ! 😳
Newbury, same thoughts here, I have double of everything! 😉
Drew, sorry to hear about your laptop! Maybe worth bringing it to a repair facility !
Dennis , beautiful camper, not bad mileage pulling that thing !
RNG, crazy shipping costs ! 😳
Hope all have a great Friday ! 🙏
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2006 CATERPILLAR 304C (A58214)
2006 CATERPILLAR...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
2016 Kia Optima Sedan (A56859)
2016 Kia Optima...
2014 Ford Taurus AWD Sedan (A56859)
2014 Ford Taurus...
40ft T/A Gooseneck Flatbed Equipment Trailer (A55851)
40ft T/A Gooseneck...
