m7040
Elite Member
- Joined
- Sep 15, 2006
- Messages
- 3,960
- Location
- Frederick maryland
- Tractor
- Kubota M7040, MF 203 industrial, ZD331, RTV 1100 , Kubota Minix excavator, Unimog 404
good afternoon, 62 nice outside rain is on the way later this afternoon
Planted a bunch of plants for wife and weeded flower beds. A lot more to plant is in shipping
Worked on the yard hydrants that stopped working. Got one adjusted and functioning again.
One had a bent pipe that will not straighten out by pulling because it swivels when trying.
Made up a clamp to pull from that holds it in place and pulled against a 4x4 at the bend. It worked perfectly and is now straight as an arrow
The coupling piece at the top was broken. It is the short 7/16 inch shaft with the short broken inside tread tip that broke off so the long rod that goes down to the valve at the bottom did not lift to operate the valve
Will be looking for a replacement if available. If not may braze it together
