Good morning!!!!
   / Good morning!!!! #178,121
   / Good morning!!!! #178,122
Good Afternoon Guys,
Scootr, best of luck with surgery!!
RNG, I bought a Craftsman pressure washer with the Honda GCV engine a few years back ! I think around 3000 psi, have had good luck with it so far ! I am partial to Honda engines, pressure washer, log splitter and portable generator ! They need to start without too much pulling ! 😉
Beautiful day, have a great afternoon !
   / Good morning!!!! #178,123
68°F and .01 inches rain
No clue what I might get into today.
first off is appointment with eye doctor if I get dilated that’s pretty much it as it takes me all day to recover.
Zoom Happy Hour this afternoon.
Prayers for all
Be safe
Have a great day
   / Good morning!!!! #178,125
There is a eye drop coming on the market soon to reverse medically induced dilation.
I have been watching that space for over 20 years.
   / Good morning!!!! #178,128
if at first you don't succeed, do it three times.
that's how my morning went.
Started off greasing the spindles, then put the new blades on
but the deck was so clogged with wet grass I couldn't leave it that way so made a big mess with that.
then took mower outside and degreased/cleaned/powerwashed the mower deck.
looking spiffy, blew it all off with air and decided to run the blades to dry everything out.
wack wack wack wack
sigh
I realize the new blades don't fit the same way, and took one off to compare with old one.
Aha, different size center hole, new one about 1/16 too small. So blade was not seating properly.
Ok, jack up the mower for second time and replace with spare set of sharpened blades.
take it outside to check and
wack wack wack wack
now I had lost my sense of humor.
went inside for some lunch to regain it, came back out,
jacked it up again, and
got it all installed properly and it ran fine.
had to be careful in jacking, tire kept trying to climb out, got it put back in where it belonged
sat outside for a few moments and watched stink bugs run along rv window.
UNUSED JCT " HYD TRENCHER (A58376)
UNUSED JCT " HYD...
2015 Ford Explorer AWD SUV (A56859)
2015 Ford Explorer...
Z Spray Ride On Fertilizer Spreader (A57149)
Z Spray Ride On...
24in pin on tooth excavator bucket (A56436)
24in pin on tooth...
Sprayer Specialties XLRD 1250 Sprayer (A59814)
Sprayer...
(8) Ten Hole 23- and 25-Inch Steel Rims (A57454)
(8) Ten Hole 23-...
