Good morning!!!!
   / Good morning!!!! #169,881
PTO flippy-thingy didn’t get done, but everything else on the list did. I call it a win for the day.
On my 430, the pull rod for the PTO took the arm over center and that’s what kept it engaged. To disengage it you had to move the handle on the rod a bit sideways to get it off the over center position. If yours is worn, maybe a simple spring to keep it over center
   / Good morning!!!! #169,883
Good morning.
70 with high of 75 today under a grey sky, not much chance of rain, but grey nonetheless.
Yesterday was busy all day. Nice trip to the zoo, but the bears there didn’t look as healthy as Jay’s.
Grandson held up very well, but I understand that he went to bed early and slept really well.
Did a few chores when we got home, mowed a occupied areas with the Lazer that I missed along the lower part of the lane, and then flew some RC, the drone pictures and video show promise
Played music with boys after that, all in all, a good time was had by all.
I’ve got some tinkering to do today, and I should get back to the little airplane in earnest, it we’ll see what happens.
   / Good morning!!!! #169,884
Good Morning!!!! 75F @ 6:00AM. Sunny. High 98F. Winds WNW at 10 to 15 mph.
No rain in the 10-day.
Yesterday's high reached a warm 88F, but today will make that seem like a nice spring day. Maybe it's time to get the shower head and valve replaced on the back porch so I can do the dunk'n'sun routine again. Seems way too early in the year for that, though.
Got in touch with the fella that builds Subaru conversion wiring harnesses and placed an order for one. It'll come with a new engine computer, an intake manifold with sensors, and what he says is everything needed to replace the existing harness. But when I asked if there's any documentation I could look over, he said all the wires are labeled, and I wouldn't need any. Hmm...
The contractor finished as much painting as he could yesterday, and a building inspector bought off on the stucco prep work. Hope to get stucco crew back next week, and roofer should be coming week after that. Sure hope everything goes according to plan.
Not sure what the rest of the day will bring, but there could be a siesta when the heat gets here.
Hope everyone enjoys their weekend!
   / Good morning!!!! #169,885
all the wires are labeled.
sounds almost too good to be true...
little Greenworks cordless mower worked fine. Very quiet, cut fine, this
is no Honda for sure, but lightweight enough I almost didn't mind missing the self propelled.
Almost...well, I need the exercise.
   / Good morning!!!! #169,886
Billy- There is a Chemical Dependency treatment center the next hill over. I'd bet that this bear is a habitual dumpster diver there.
Popgadget- I am happy to read that the visit to the zoo went well. Our bear does look healthier than that zoo bear. And thanks for sharing the family picture; a good looking family. I really like the drone picture. My homebuilt is now a hangar queen.
It was a mix of filtered skies and some mid and high level clouds with 52ºF as this morning's low temp. These weather conditions continue and it is currently a very pleasant 66ºF with a nice breeze blowing and 13mph gusts recorded. I may see a little more sun this afternoon and increased wind as the approaching mid level "dry" cold front builds in as the day progress and a high temperature in the low 70ºF's.
I did the dump run early and have no real plans to do anything productive today, but appreciate this beautiful weekend here.
I hope that everyone has a decent weekend without any unexpected "surprises."
   / Good morning!!!! #169,887
Flail back in service
While lift pins pointed outward was my preferred fix, it didn’t work. Could only attach if the extendable lift arms were fully extended
Pointing inward did but had to use a short bushing in the pin side hole as it was Cat2 size and a double washer due to non threaded portion.
Still wish the threaded portion about 1/2 “ longer. Will have to monitor nuts.
Will do a test mow after lunch.
Looking at your pictures it seems to me that you mower was originally designed to use thru pins with the lift arm sandwiched between the side plates.
Have you considered getting a second plate and bolting it on outside of the torn out piece?
Some of the through pins are stepped for implements with two different hole sizes, some are just straight pins.
   / Good morning!!!! #169,888
Light rain mid 60s. It will be an inside day.
I had two very nice afternoons mowing at the farm. Nice and warm after a long cold spring. Mowed the lawns Thursday and got the farm lane and the meadows Friday. There is always more that could be done but it is looking pretty good. I don't like leaving clippings on top of the grass but I can't mow often enough to keep up with how fast the grass is growing. It should slow down soon.
The wheat at is looking good at the farm. It won't be that long to harvest time.
Have a nice weekend
Chris
   / Good morning!!!! #169,889
Raining as I type. About an inch since midnight. Plenty of L&T. Some close strikes to get us out of bed, well, me out of bed.
supposed to rain all day and tomorrow too. The water is now running off, as the ground is soaked.
Taught son how to run the Shindaiwa Weed eater yesterday evening. He has ran it before, but only handed to him. I explained and he did. He had to remove the pole saw attachment, connect the weedeater. Stressed that ONLY premix gas used because of 2 stroke. He said "why?", I tried to explain there is no oil sump in a 2 stroke engine, but without a diagram it went in 1 and out the other. Showed him how to load the easy load string head and wind it up. By the time we got to actual weed eating, I had to hold a flashlight for him. Killed about 4 or 5 scorpions. I had set off a bug spray can but apparently not strong enough. Raid Ant and Roach spray will kill them in a minute if sprayed directly.
Wifey cleaned the chicken coop yesterday, and put the poop on the compost pile.
Daughter has to pull "a double shift" at work today. She works at the restaurant that Ron, Don, me and our wives met at years ago. I told her to wear comfortable shoes.
I got my hair shortened too yesterday Mostly.
   / Good morning!!!! #169,890
I think Lou is correct. Thanks Lou.
2017 Yamaha VX1050B Deluxe Jetski (A50324)
2017 Yamaha...
2016 PETERBILT 579 (A52472)
2016 PETERBILT 579...
706075 LOT NUMBER 81 (A53084)
706075 LOT NUMBER...
CONTACT INFO (A53084)
2019 POLARIS RANGER XP PROSTAR 900 HD DOHC UTV (A51406)
2019 POLARIS...
2020 VOLVO  A40G (A52472)
2020 VOLVO A40G...
