Good morning!!!!
   / Good morning!!!! #169,842
Jay any chance you can replace fuse yourself?
David- The production stopped ~5.06.23. I thought it was a communication problem which usually resolves itself after a couple of reboots and maybe a day or 2 to reconnect. After the 4th unsuccessful reboot I walked down to the array and there were no LEDS, blinking lights, nothing. In the same timeframe I got an email from the energy collaborative with which We are members basically stating that through their energy tracking they knew that We were not producing and would not approve a non licensed electrician installation. It was a similar situation with the installers. I bet that We are not the only residential producers around here who met the same fate. I am already in their service queue which will be in a couple of weeks. 🤬 I really do not want to create "problems" after getting that recent +$500 quarterly dividend deposit from them. I really can not complain We have received only 2 electrical bills since 12.2017. This is a copy and paste of their email:
"Please find attached a detailed report of these alerts. Note, if you are a system owner, all troubleshooting steps indicated in each alert should be handled by a qualified installer and not by an unauthorized person."
I know what you mean about the fuses..... so simple I could easily fry myself 🤪
   / Good morning!!!! #169,843
Guess who just showed up. It was starting to froth up after tasting that "loaded" suet. I guess some of the feeders will becoming down. I rarely see bears messing around with the nectar feeders and they apparently do not like oranges (yet)>
   / Good morning!!!! #169,844
easy job moving the box blade thanks to very fancy tilting trailer of friend's including winch.
pretty warm out
electric mower showed up, battery put on charge, will fiddle with it tomorrow
   / Good morning!!!! #169,845
pretty warm out
That's a really nice trailer Drew. We call them car haulers down here. Would love to have one.
   / Good morning!!!! #169,846
Flail back in service
While lift pins pointed outward was my preferred fix, it didn’t work. Could only attach if the extendable lift arms were fully extended
Pointing inward did but had to use a short bushing in the pin side hole as it was Cat2 size and a double washer due to non threaded portion.
Still wish the threaded portion about 1/2 “ longer. Will have to monitor nuts.
Will do a test mow after lunch.
   / Good morning!!!! #169,849
just emailed my neighbor and told her to tell the lawn guy, who we both use, to weedeat every week, not every two as now. Grass is growing too much.
I just did the whole place and back is not happy.
need to sit and take the proverbial load off.
very pleased to see my honey and borax mixture works like a charm. Supposed to take up to 48 hours to work
but those guys are moving awfully slow after I put it down yesterday. If I could only find where they are getting in.
This is over by my house plants inside. Need to check the two I put in rv.
Drew,
Just a thought. Does your power cord stuff in a hole in the side of the tv or does it connect via a female plug?
   / Good morning!!!! #169,850
Drew,
plugs into a standard receptacle on outside of rv.
I have soaked a line of mint spray all around rv, and really soaked the drainage plumbing pipes with the mint spray.
I think I'll spray the power cord tomorrow, good idea. But that would only get them on outside of rv. I have no water leaks so don't believe they are getting in through
windows. They aren't coming in the shower drain. Not any more.
best thing I can do is poison them and have them go die somewhere else.
I even used a little borax in last load of clothes with very dirty jeans.
I have plenty of honey and plenty of borax, and plenty of cardboard, so need to make some more.
Friday night. what kind of mischief can we get into tonight?...
New/Unused Heavy Duty Brush Cutter (A57454)
New/Unused Heavy...
New/Unused Heavy Duty Mower (A57454)
New/Unused Heavy...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
Ford 8510 (A53317)
Ford 8510 (A53317)
New/Unused CFG Industrial NT18K Mini Excavator (A57453)
New/Unused CFG...
15 35ft. Commercial Black Metal Light Poles (A56858)
15 35ft...
