Good morning!!!!
   / Good morning!!!! #168,411
So I can save on that and get an additional bucket instead.
what size buckets do you use? I am thinking of a 12” and a 24”…
I think if remembering right my digging bucket with teeth is 18 inches and works well for me. Going smaller will cause clay to plug it and be a pain. Smaller buckets are good for narrow excavations and ripping up tree roots but the 18 works for me. Bigger excavations is not a problem because with the blade you can backfill it in a minute.
The other bucket is 36 inch with no teeth and is very good for back dragging to smooth out excavations and digging in looser soils
   / Good morning!!!! #168,412
I think most of us like to think we set fairly high standards, but
I always keep in mind Mickey Mantle. My childhood hero.
He only hit one out of three. So I knew early on things regularly don't go
as you want...but consistently do good work, and you can be a star.
Popgadget's my star, however with an rv with no tail light assembly, it is now parked.
With hopefully a brand new one on the way.
If I had scratched my paint or dented something, I would be next level annoyed.
Have to realize I don't have distance beepers on this thing. Likely able to retrofit.
have been looking on e-trailer web site, considering adding a steering stabilizer and small Sumo rubber springs in front.
Allegedly bolt on, no drilling, and not hard to do.
Rv has MorRyde upgrades but no doc on what you actually got. Probably better leaf spring shackles, probably a front sway bar, it has one, and maybe heavier duty shocks.
The problem with adding suspension upgrades to rv's is you immediately void the long term warranty as they specifically prohibit it, at least GulfStream does.
I'm sure the primary reason is to keep folks from overloading their rv. Which in reality is done all that time. They have to take a defensive posture assuming
their product will be abused.
But I now have a four year rv out of warranty so I can do what I want. I don't want more weight carrying capacity, am looking for better ride and handling.
I did this once before on a prior rv and had good results. Then I bought a more loaded rv and it had all this stuff standard. Now starting back over with a suspension stripper.
New tires and alignment accomplished. New flexible valve extenders nicely attached to wheel cover so no whipping around, no valve stem neck breaking again hopefully.
The brakes are fair and the handling is whale like at times.
E450 commercial chassis I guess is even less capable compared to their traditional F53 Class A gas motorhome chassis.
Unless you drive like a snail around curves, they all need some oem upgrades. The big name brands build it all in now.
   / Good morning!!!! #168,413
This coming week I anticipate quite an influx of returning migratory birds. I have far too many picture that I have taken to ever share here, but I will share these 2 taken last month. The Barred Owl was just off our driveway and was very tolerant of the photoshoot from the truck.
   / Good morning!!!! #168,414
Jay, I started a separate thread a while back here on Diabetes, since I'm trying to avoid it. Just crept up to 6.0 AIC
103 glucose, my endocrinologist told me not to be overly worried, I'm likely to get the treatment discussion when I see my primary in two weeks.
I think wait another six months and see if it stabilizes. A real love/hate affair with sweet things.
And bread, oh do I like bread.
great owl pics, one of my favorite birds.
   / Good morning!!!! #168,415
If you can swing it the hydraulic 36 inch smooth bucket is very useful for slopes and ditch work. Backdracking it at an angel
Often wish I had that
   / Good morning!!!! #168,416
Good morning, 66 going to 70 today with rain in the forecast for this afternoon
May be able to get a little mowing in before the rain.
Run to pick up meds and avocados on sale
Will likely go up to barn when rain starts and catch up on pending items waiting for me up there
Security briefing before Austria trip was heavily focussed on electronics and Russian aggressive snooping and getting access
   / Good morning!!!! #168,417
Good Morning!!!! 65F @ 6:00AM. Sunshine and a few afternoon clouds. High around 85F. Winds NW at 10 to 15 mph.
Could be the warmest day of the year so far.
One thing I forgot to mention is that the Kx33-4 use the diesel engine that does not need pollution controls which was why I did not go bigger when I got it. The complications of emissions crap they put on the diesels is something to avoid if you can.
I used to worry about the regeneration cycle on the M62 when I first got it. Kubota uses a Diesel Particulate Filter on it, and all the regeneration cycle does is push extra fuel to the engine to raise the temperature in the DPF to burn off accumulated carbon. Turns out the only thing to worry about is being in tall, dry grass when it kicks in. Don't want those hot exhaust gasses starting a wildfire. The easiest thing to do is just work the tractor until the cycle is over. If it happens when I'm finished for the day, I just park it on the gravel and bump the idle up to 1500 RPM with the hand throttle and let the cycle complete. That's a little inconvenient, but I don't have to mess with putting the blue stuff into a reservoir. And FWIW, the backhoe came with a 24" bucket, and I purchased a 12" trenching bucket used from an outfit called Hunt Tractor in Medford, Oregon. Saved enough to pay for the fuel it took to get up there and pick it up, but they said they could ship it for not much money. It was worth the trip just to see all the used attachments they had in their yard, and it took all the self discipline I could muster to keep my money in my pocket while I was there. It also turns out that the 'hoe on the M62 uses the same buckets as the Kubota mini-exs. Changing is easy with just one screw in pin to remove and replace.
Spent some time looking into RAM ProMaster vans, and forwarded a copy of a custom build sheet to the local dealer. It's the same outfit I got the Camry from, and I'm wondering if I'll end up with the same salesman, which would not be a bad thing. Nothing but automated replies so far, though.
When the old porch cover took flight, it somehow broke the terminal posts off one of the outdoor speakers that were hanging on it. Fortunately, it left both speakers behind instead of smashing them to bits. But one was full of water when I found it, so I thought it was a goner. Well yesterday I found time to take it apart and learned that the water got in through the base port opening. And that the speaker cones are all plastic, and nothing was wrong inside the enclosure. So I just dried it out and put it back together, and found a pair of binder posts on Amazon to replace the broken ones. Enjoyed margaritas and some Van Morrison under the new porch cover last night with a neighbor, sitting next to a camp fire of wood scraps left by the contractor. Last weekend a buddie and I revisited an old time record store in San Luis Obispo, which is where I picked up a few new-to-me Van Morrison CDs, and others, for four to six bux a piece.
I also got a notice from Netflix that this would be their last season distributing DVDs through the mail. The last ones will go out in September, and from then on, they'll only offer streaming plans. Starlink came just in time.
Not sure what I'll get into today, but it could very well be some mowing. Last night I watched a deer lay down in the meadow, and all that showed above the grass there were its ears.
   / Good morning!!!! #168,418
I wonder if you have a backup camera on the RV, Drew? One came standard on the Camry, and the lines it projects on the display have so far kept me out of trouble. I put one on the F250, too, which displays on the double DIN size radio I also installed, so maybe something like that would work for you, too.
   / Good morning!!!! #168,419
Your A1C is great as well as your glucose level IMO. The past 10 years I've been running 6.3 - 6.5 which are great #'s for an insulin dependent diabetic. Last year I started running ~6.7 which freaked me out, but my PCP told me that for my age 6.7 is a "good" #. I do not have a sweet tooth; but I am a fat and grease addict. The martinis do not help. For all my "stuff" my bloodwork is really decent.
Thanks for the compliment for the owl pics. Bluejays tipped me off to its presence while I was drinking my coffee. I drove/coasted down the driveway in the truck. At 3 frames/second in "burst" mode I got quite a few pictures. The owl remained there for quite a while after I left and returned to my coffee.
I might over time post some Warbler pictures. I "captured" 7 different species; some of them considered "rare" last year.
(1) HD 24ft Free Standing Corral Panel (A57453)
(1) HD 24ft Free...
7ft Workbench (A57453)
2013 Nissan Sentra Sedan (A56859)
2013 Nissan Sentra...
Unused 2025 CFG Industrial QH12R Mini Excavator (A59228)
Unused 2025 CFG...
Unused Quick Attach Plate (A55272)
Unused Quick...
Poly Fuel Tank with Electric Pump (A55851)
Poly Fuel Tank...
