Good morning!!!!
   / Good morning!!!! #164,561
Morning all, going up to 45 and sun is out.
Worked on pole saw yesterday and got the oiler pump working again. The M18 attachment seems to always need maintenance and really needs to be clean to operate properly. When it works it does the job and have a lot of hours on it.
Got tractor front end greased and need to tend to one nipple as it is getting tough to get grease in.
RNG - I have the 3m Worktunes with BT and only need to turn off tractor or saw to answer calls/speak to people.
David - sounds like good progress on eyes, life is good
LS feel better.
The other night with the moon almost full.
   / Good morning!!!! #164,562
Still testing out the mini split but so far it is working perfectly.
If your experience is the same as mine with a similar unit you won’t be disappointed. I don’t even have the Hyper Heat and it was making great heat in the single digits, which is as low as it’s been since I installed it. AC works great as well.
   / Good morning!!!! #164,563
61°F and 1.63 inches rain and raining
The gals took much pleasure in beating us again.
Another day of reduced activity. Not that difficult given the weather, but my mind tends to wander to the ever growing list of things that need attention. Oh well, they aren’t going anywhere.
Looking forward to reading how Drew makes improvements to his newly acquired home on wheels. I sense an adventure ahead. Wonder how we can get him a travel companion?
Prayers for all
Be safe
Have a great day
   / Good morning!!!! #164,564
Seemed like I was stopping way too often to answer the phone yesterday. Lots of fun when you're operating a tractor: Kill the ignition, pop off the earmuffs, undo the seatbelt, fish the phone out of the pocket, and work the phone with gloves on to answer the call before it goes to voice mail.
My solution was to put a Bluetooth stereo in the cab of the tractor. I usually stream music to it, and can answer the phone when it rings.
For open station equipment I got the 3M Bluetooth work tunes, but generally use a Bose Quiet Comfort noise cancelling headset with Bluetooth.
The Bose is definitely more fragile, but the audio quality and noise cancellation is light years better than the 3M, so I use them on a machine, but not for tasks like running a saw.
   / Good morning!!!! #164,565
33F with abundant bright sunshine @ 11:15, heading up to around 44F for the high.
Got hopper feeder refilled yesterday, will refill the deer feeder later today since it's gotten chilly again.
Got the hole drilled for the dust collection port drilled out on one of the side boards for the portable downdraft sanding table.
Also got short set of saw horses put together.
Hooked Shop Vac up to the belt/disc sander and took that for a spin, working a section of 2 x 12 which will be used as a base plate for the HF hose reel that is used to store the 10 gauge extension cord.
Some additional cleaning/organizing done out in the garage.
Tore into the shower valve, discovered that it's apparently easy to pooch the seats by cocking it if you're not real careful with the seat wrench I have.
The wrench is 90 degrees and has a continuous taper on both ends, hex on one, square on the other. The Depot has a Husky wrench with a T-handle with stepped ends that looks like it might be a better device ... might have to pick one of those up and give it whirl.
At any rate I cleaned up the now-knicked seats with a stone and reinstalled. No soap, still leaks.
So at that point I ran down to the local Ace to see if they had the seats. Yes they do ... but only with new stems @ $18+ a pop.
Guy down there suggested bevel washers so I grabbed an assortment of those and headed back to the house and tore down the valve again.
Still dripping even with the bevel washers.
So took it apart again and did a close examination of the new seats vs the original one I took out and discovered that they are slightly different: the new seats are slightly taller and have a bigger gap between where the threads end and where the flanged mating surface is that seals against the valve body. Not sure if that makes any real difference or not ... but it is the only seat that Danco offers for Gerber valves so they ought to work (in theory)
At point I decided to have a closer look at the area of the valve body where the seats flange form their seals and discovered that appeared to to be some corrosion and pitting in one spot on the hot side of the valve.
This wasn't easy to do, since the crapper sits right next to the tub and it isn't easy to get down there close and low enough to see into the valve.
So at that point I worked over the seating area with a wire brush for cleaning 3/4 female copper.
Then wrapped the new seats with some teflon tape, stuck them back in, reassembled the valve and turned the water back on.
It's been almost 12 hours since I pressurized the lines and not a single drip so far ... although I haven't cracked either the hot or cold side of the valve yet.
Figured I'd just enjoy the no-drip situation for a while ... before I tempt fate and open them up ... :LOL:
I have two sets of new seats coming from Amazon which should be here Monday.
But if it ain't leaking, I sure ain't gonna tear it apart just to put them in.
Hopefully the remainder of the day today will involve other activities which are more fun.
Like figuring out where in the #$%^ I set down my Bluetooth ear muffs.
I did find another can of red enamel in my travels down in the basement yesterday, will likely use that for the dust collection drum ...instead of spending additional money on another can of paint which is an exact match. Close enough.
Hope everyone is having a great Saturday ... (y)
   / Good morning!!!! #164,566
Last time I needed to replace my hearing protection earmuffs I got the bluetooth version...now I can answer the phone while it's in my pocket by pressing a button on the ear cup. The pair I bought doesn't have a mike, so have to yell until I get the phone out of my pocket, but can answer a call quickly so it doesn't go to voice mail. Also, can listen to tunes, of course.
I have a pair of muffs that do that, too, but the charge doesn't last long enough to get through a day of use. By the end of yesterday, doing the drill to get to the phone was almost muscle memory...:ROFLMAO:
:ROFLMAO:
   / Good morning!!!! #164,567
Good to hear recovery process is starting off well! You really don’t need to pick up anything heavier than you tablet or a sandwich for the next week…
or a box of beer.
rs, it is good to hear you got the drip stopped.
I got all the plowing done, including the new one that I only have until the 20th.
One lady I plow for has a shed roof that dumps onto the path that I push the snow over a bank. She had forewarned me that the shed roof had unloaded, the pile was four feet high and twelve feet long. I already had a full bucket of snow I was pushing when I got to that pile, stuffed it into low range (I plow in the mid range normally), stomped on the power divider pedal and shoved all of it over the bank. Made her snort a little, but that just helps to keep her running smooth.
I managed to drop both front wheels into the ditch (2' deep) just to the east of my driveway. I pried myself out with the bucket. Zero damage.
Now for the you tube rabbit hole.
   / Good morning!!!! #164,568
Picked up the IMAC after the wipe and install MacOS Ventura, chrome and Webroot. So what I did not realize my wireless keyboard and mouse will not allow me to log in because they are not set up yet and I don't have plug in USB keyboard and mouse. So either back to get that done or go get the wired ones to set up
   / Good morning!!!! #164,569
Woke up at 530 to get to the arena for my daughter's game. Hate early games....
She did good but we still lost. My kid made alot of shots on goal but that tender was good.
   / Good morning!!!! #164,570
I also get those sneezing fits. Never counted them. Most often they seem to be triggered by the sun, but have had at night also, so who knows.
17307 (A55853)
17307 (A55853)
2021 WANCO, INC LIGHT PLANT (A58216)
2021 WANCO, INC...
UNKNOWN 500BBL WHEELED FRAC TANK (A58214)
UNKNOWN 500BBL...
1621 (A58375)
1621 (A58375)
2019 CATERPILLAR 259D SKID STEER (A52705)
2019 CATERPILLAR...
2811 (A58376)
2811 (A58376)
