Good morning!!!!
   / Good morning!!!! #151,381
Rigged the chipper, but the adjustable top link threads were frozen, so I couldn't get the QH upper hook engaged...bummer!! I used a helper (12" crescent wrench)...wouldn't budge. Soaked the threads with PB blaster and we'll try tomorrow (24 hour soak)"
Also happen to me couple time good heavy spraying of brake cleaner in short time free up.
"So, change of plans...mowed the lawn instead
Beautiful day..
Glad your getting outside enjoy yourself Roy, yup tad jealous here tho. ;)
I know what you're going through...my first pacemaker was 2009...replaced in 2016...
You'll be your old self within a week or two
   / Good morning!!!! #151,382
73F mostly cloudy nice breeze.
Decided give Ms. Kubota little exercise several buckets of dirt fill small holes here and there...not smart move on my part :rolleyes:,after lunch before putting Kubota under cover need good hosing from the heavy pollen in air :eek: gotter admit where wind blew pollen on hood rims etc. collected gave nice pin striping looks...John Deere pollen green. ;)
Plans..Mrs. like to stop at HD purchase handy size wax buffer for car,sooo I guess I'll tag along and bat my Bambi blues eyes she buy bucket KFC chicken 🤞 other than that on the deck smooth cigar waiting for mother gray fox couple deer and baby Boo come to visit.
Enjoy your evening all.
   / Good morning!!!! #151,383
Did my first regen of the tier 4 engine in the 4052R today. Soot percent was 79% and, I'd noticed the last day or two, once started, the RPM would not drop to idle (1100 RPM). My habit (for this tractor and and all previous tractors) is to increase RPM to 1500, once oil pressure was up.
I always dropped RPM to idle before shutting down...but as I'd written...it stayed at 1500
Anyway, I did notice the regen light was on (I had mistaken the indicator light for another function, previously)...cranked the RPM up to 2200 and went about my business.
Took 20 minutes or so (don't wear a watch, so that's an estimate) and the soot percentage went from 79% to 6%
A completely simple process, although I would think it's a bit more of a hassle for farmers and other "professional" tractor users.
My tractor has a vertical stack for regen...and I'd seen on YouTube the exhaust gets hot during regen...and I can attest, yes it does!!!
   / Good morning!!!! #151,384
Sky starting to clear, looks like sun might come out.
68° and only 68% humidity now. Only got .05” rain.
I stopped shed work at 3, came in for lunch and a shower. Did not get rotten piece of floor replaced, but did get the back left corner cleaned out, had raccoon crap. 2 bags stuff ready for trash pickup.
Burned a bunch of old osb siding, posts, scrap wood, cardboard. Had to stop piling more on fire when wind decided to kick up a little.
Moved old rain barrels to side of barn. Need to get rid of them.
Overall satisfied with amount of work I got done.
   / Good morning!!!! #151,385
My model plane experience was similar to RNG. As I recall, Cox gas engine as well. Saved up and bought a balsa wood kit that I enjoyed building. Not an RC type, but the kind at the end of some strings, 2 I think. Nice take off and almost immediate power dive into the ground. Did spend some time trying to fix. I remember buying different pieces of balsa, but it never flew again. Decided to use my meager resources elsewhere. Anyone catch a finger flipping the prop?
I almost lost a finger about 40 years ago when a glow plug igniter was stuck on the plug. It suddenly let go and my little finger went straight into the prop at full revs. About 30 stitches from memory.
Still have the scars to remind me.
   / Good morning!!!! #151,386
Absolutely !!
Most of the larger engines I spin up with an electric motor with a rubber cup on the spinner. Of course the battery to run that and fuel transfer pump is long dead like all the others.
   / Good morning!!!! #151,387
Heat works wonders freeing things up. A torch and Kroil are my go to tools for tasks like that. Soak it then heat it.
   / Good morning!!!! #151,389
Good Morning.
It’s 68, overcast and likely to rain soon.
With that in mind, I got going early this morning, got the mowing finished up that I started yesterday and got the rebuilt mailbox installed.
Yesterday’s trip to Concord was effortless, beautiful day, good views of Manhattan. We could see the Atlantic Ocean as soon as we took off. And the best part was that we were back by 10am and heading home.
I had the post hole auger on the loader, so I had to take that off, and rig up a 4 wheel dolly to store it, because I need a bucket on the loader to remove it from the tractor. Got all that done, and hitched up the Progressive mower and got everything cut with that. Parked it, refueled the tractor, and hopped on the Lazer until I got hungry. After a quick dinner I did the final assembly and graphics on the mailbox before putting my feet up.
Good flight!!!
Is your post hole auger hydraulic? Just curious...I have no need for one, but other than one rigged to a skidsteer, I've never seen one rigged to the FEL/bucket
   / Good morning!!!! #151,390
Good Morning all
I'm taking a day or two to load up my truck (with canopy) for a dump run ... exciting times :) Next week I'll add the new to me grille guard for the truck. New All Terrain tires, used rims are pending. It's raining, so too wet to do any yard maintenance, the brush cutter / weed whipper will have to wait for a dryer time. I put a deposit down on the Zero Turn while I wait for the fabricating to be done. Bit of a slow day, giving my knee some T3s and a rest - had the El Camino out last night, so the knee is a bit strained from getting in / out. Having a coffee, and checking emails, so I thought I'd respond to a few things here... (credit to MostlyGas for the idea). I'm skimming over the past 15 pages, so I will certainly miss a lot ... I really should be washing more eggs also, and checking the incubator.
Alien, LS, Popgadget, and others - I like the RC planes a lot (great photos) - friends, and my neighbour, were big into the planes. My hobby was always the Model Railroading, still with the local club, but my trains are in boxes yet again, while I find some new space to run them. The church is having a Trains theme for the week long Kids Day Camp
Buckeye - we had a mudslide here last week due to the rain, closed the hwy for 5 hrs
rswyan - I like gardening, but mostly from a greenhouse table height at this point. need to get a greenhouse yet
I'm joining in on the prayer concerns, it's tough to keep up sometimes, so that was a great summary for me. Strength everyone. Buppies - all the best with the surgery, today or soon.
Popgadget - love the mailbox, can't miss that one
wngsprd - reminded my wife to have the wheels re-torqued, i've seen too many roll aways
RedNeckGeek -here in BC it is $2.19 per litre for gas (over $8 per US gal) - uggh, but some travelling is needed
sodamo - my trips to town (20 min away) are less frequent, and loaded with errands, makes for long days
LS- I need to respond to the son (3rd child) comment :) I too have a BS in Psychology / Criminal Justice (not science), I had a good 26.5 yr career in Corrections ... Probation, Parole, Bail Supervision etc - hopefully he'll figure it out sooner.
Kyle - I REMEMBER that song, always made me laugh
newbury - take care
txdon - I recall fire and earthquake drills, no bomb drills
RoyJackson - sounds like a similar weekend over here, clean up and dump run
daugen - and I was just going to guess garlic scapes (haha, ya sure I was - nope) - had 2 boxes of them a few weeks ago, initially thought they were string beans - they were old, so the chickens enjoyed them
I think I caught up - PHEW !!! :) going outside with the dogs
2014 INTERNATIONAL MA025 (A52472)
2014 INTERNATIONAL...
2005 Chevrolet Silverado 1500 Pickup Truck, VIN # 1GCEC19V35Z257979 (A51572)
2005 Chevrolet...
2008 FREIGHTLINER B2 BUS CHASSIS (A52576)
2008 FREIGHTLINER...
JOHN DEERE XUV835M (A53084)
JOHN DEERE XUV835M...
1992 Effer 7600 2S Knuckleboom (A51691)
1992 Effer 7600 2S...
