Good morning!!!!
   / Good morning!!!! #132,501
Thinking I'll pick up one of those blade sharpeners from Harbor Freight and give it a try.
Is this the one you're thinking about, Paul?
I have one kicking around the garage somewhere, and it sorta worked. The positioning adjustments for the chain weren't very solid, and I had a hard time getting the saw to cut straight. But I was also taking too much off, which ruined the temper of the steel and gave me different tooth lengths on the two sides of the chain. I bought the Oregon sharpener the HF one is patterned after, and now think the HF one would have worked if I'd have adjusted it so that the wheel came down without touching the chain, and then put side pressure on it to just kiss each tooth very briefly, just enough to get it sharp. It might even work better on the HF unit, being plastic and pretty wobbly.
Anyway, if I've still got that HF unit, it's yours for the postage if you wanna try it. I'll look around today and see if I can find it.
   / Good morning!!!! #132,502
I use these diamond coated burrs, chucked into a Dremel to to sharpen chains. They're available in 5/32, 3/16, and 7/32 to match your chains.
   / Good morning!!!! #132,503
Can’t beat that deal ...
   / Good morning!!!! #132,504
67°F and .65 inches rain.
Need to make a PO run this morning.
Should get my light boxes in place. Will try to get the circuit breaker panel installed but as I don’t have the meter enclosure that might be a challenge. Once in place I can start the home runs.
Zoom Happy Hour this afternoon.
Prayers for all
Be safe
Have a great day
   / Good morning!!!! #132,505
I'm sure you all know that txdon and I, and some other TBN members, have the EGO battery powered lawnmowers. Of course I also have the EGO string trimmer and the leaf blower. I bought mine from a lawn equipment place, but the Home Depot had also been selling them. Recently I had read that the Home Depot dropped EGO and Lowe's took it over. So this morning, I just went into the Denton, TX Lowe's just to see. WOW! I'd never seen so much EGO equipment in one place. Both push and self propelled lawnmowers. boxes and boxes piled up, string trimmers, leaf blowers, and even a back pack blower. But the most interesting thing was that this was the first time I've ever seen one the new EGO riding mowers. I see that the Denton Lowe's store website says THIS ITEM IS OUT OF STOCK but they sure had one sitting on the showroom floor.
   / Good morning!!!! #132,506
Yup, that's the one.
I watched a couple YouTube video reviews of them, and they all said pretty much the same thing ... adjust is so it just barely touches the tooth.
If you find it and want to part with it, let me know. That's a very generous offer, so long as shipping from Cali to Illi isn't ridiculous. If not, there is a HF in Fairview Heights IL that I pass every day on the way home from work.
   / Good morning!!!! #132,507
Pretty Monday in St. Louis area. Sunny and 70’s.
Supposed to rain tomorrow.
We had 1 1/2 hours of tennis this morning, so exercise done for the day.
I put in my Medicare application (on line) on Saturday. Got a notice today it’s being processed at KC office. Once I get the Red, White and Blue Card I can go shopping!
Think it’ll be an easy day today. Read a little, hang out with the cat and rest. My wife has to work a little today. I’m going to try to get the cat to like me more while she is gone - maybe an impossible job!
Have a great one everybody.
MoKelly
   / Good morning!!!! #132,508
I was looking into one of those but I need a bigger yard, not much bigger. It holds 6 EGO batteries but only comes with 4. The replacement batteries - 56V 10ah - are $450 each. The zero emissions zero turn, also dubbed double zero, probably will be mandatory in California soon.
   / Good morning!!!! #132,509
59F with a light steady rain @ 13:15, supposedly heading to a high of 69F later (this evening apparently)
Timberlink Station (just down the road a piece) shows they have received .55" so far ... which sounds about right.
Just fixed second cup.
Did a check of the bluebird nest boxes yesterday:
No. 1 has a nesting pair of bluebirds in it (didn't have to open the box, could see one flying out every time I got anywhere close it with the mower)
No. 2 had a house wren or house sparrow in it I think but no nest yet (bird flew out so fast right into my face that I couldn't make a positive ID)
No. 3 looks to have house sparrows in it
No. 4 appears to have a pair of bluebirds in it (again flew out so fast right into my face so I couldn't verify what it was) Definitely need to verify that one, because the nest looks more like a house sparrow nest.
No. 5 was not checked, but may have a pair of bluebirds in it (a pair has been hanging around the nest box, but I need to check the box itself)
Will probably go ahead and put out some live mealworms in the two feeders sometime later once the rain lets up, since weather like this (extended periods of cool, wet weather) are when they have a hard time finding food.
Got notice from Amazon that the Chapin spreader has shipped out of Schertz, TX, they are saying it will arrive on Thursday.
They delivered the rest of the stuff needed for the light install earlier today. I now have what will probably be a Lifetime Supply of butt connectors. Will spend some time down at the electrical bench today getting the Weatherpack connectors soldered on and heatshrinked and loom put on. Maybe see about getting them mounted and wired up as well.
Everything here is really greening up and leafing out, dogwoods in full bloom, along with the magnolia - looks very lush.
Ten Day shows enough rain in it, that I might be tempted - like Paul - to over-seed the lawn - after I core it again.
One of the items in the order that's waiting to be picked up at Menards is a 25' roll of 2' wide, 1/8" hardware cloth. Thinking I'll go ahead and make up another screen for the soil screener and use it to screen compost so I can top dress the lawn. That assumes that I can get the screenings dry enough that the spreader will spread them and they won't pack up in the hopper.
Arm still sore from vaccination, but otherwise no other symptoms.
Hope everyone has an enjoyable, productive, and safe day ... (y)
   / Good morning!!!! #132,510
We started doing the free 14 day Forks over Knives meal planner. It includes grocery list and meal recipes for a week at a time. So far it has been very good. Lunch was peanut noodles with vegetables. We might continue with the paid program later as it really increases variety and ideas for plant based meals. It cuts the figuring of complete nutrition for each day and the grocery list is a big plus.
LayMor Sweepmaster 300 8HC (A55314)
LayMor Sweepmaster...
2016 FREIGHTLINER CASCADIA (A58214)
2016 FREIGHTLINER...
1607 (A57192)
1607 (A57192)
New/Unused Agrotk YC-32G Sawmill (A57453)
New/Unused Agrotk...
2013 CAT 312EL Excavator (A59213)
2013 CAT 312EL...
2017 BOBCAT T595 SKID STEER (A52709)
2017 BOBCAT T595...
